PennSilverTaco's HVAC BS MegaThread!
Discussion in 'Garage / Workshop' started by PennSilverTaco, Feb 16, 2021.
  1. Jan 4, 2025 at 7:13 PM
    #1581
    PennSilverTaco
    PennSilverTaco [OP] Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    Lennox packaged A/C units at the Battleship New Jersey gift shop...
    Lt. Dangle likes this.
  2. Jan 5, 2025 at 7:49 AM
    #1582
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    L Series units. Kinda suck, but better than Carrier/Bryant of equivalent years IMO.
    Might be different from this, but close. I think the ones pictured are older as they are more grey than beige, but I don't know exact changes made during the run.
    https://www.climatesolutionsinc.com/wp-content/uploads/Lennox-L-Series-Brochure.pdf
  3. Jan 5, 2025 at 10:12 AM
    #1583
    PennSilverTaco
    Charlie
    They suck because of build quality, reliability, serviceability, or a combination of the three?
  4. Jan 5, 2025 at 10:16 AM
    #1584
    PennSilverTaco
    Charlie
    The brand new Carrier 1.5-ton heat pump running in the snow; I couldn’t tell if it was frozen or if that was just snow that had blown into the outdoor coil…
    Lt. Dangle[QUOTED] likes this.
  5. Jan 5, 2025 at 10:21 AM
    #1585
    PennSilverTaco
    Charlie
    @Lt. Dangle
    @steelcity2
    @TnShooter
    I would personally never set any central heating system above 72°F, but Emily likes it warm. Considering how cold it was, this heat pump was performing quite well; it did not go into defrost, nor did the emergency heat engage. I think the system performed well because the condo is only like 950 square feet with two windowless interior walls, and it only has one exterior entry/exit, as opposed to it being a particularly well-performing heat pump. This is just a base model Carrier with of no more than 15 SEER…
    Also, which one of you guys said you really liked the EcoBee thermostat?
  6. Jan 5, 2025 at 10:21 AM
    #1586
    PennSilverTaco
    Charlie
    View of the heat pump from inside the condo…
  7. Jan 5, 2025 at 10:24 AM
    #1587
    PennSilverTaco
    Charlie
  8. Jan 5, 2025 at 12:14 PM
    #1588
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Probably me.
    I put one in for my mother.
    It never gave any issue. And she likes it a lot.
    You can set alerts for too hot and too cold.
    I put on in after the contactor got stuck and the house was 85 degrees.
    Her poor dog was nearly cooked. That was it, off to get a smart stat.
  9. Jan 5, 2025 at 2:04 PM
    #1589
    PennSilverTaco
    Charlie
    @ABA180
    @ColoradoTJ
    @Just_A_Guy
    @Lt. Dangle
    @shakerhood
    @Speedytech7
    @steelcity2
    @Steves104x4
    @TnShooter
    Shit like this gives law-abiding scrappers like me a bad name. These units are located at the same shopping center where we ate at an Italian restaurant, a shopping center which has been largely vacant for years; I spotted the unit in the first pictures when we were leaving on the 30th, but it was dark and I didn’t see the other two. All three of the units are York commercial units from the 1980s or possibly the early 1990s; I was here almost 14 years ago exploring the HVAC equipment and I seem to remember that they were heat pumps. However, a lot of the buildings have gas meters.
    If they were heat pumps, the reversing valves have been taken by the copper thieves. My guess would be that the compressors were no taken because they were two heavy to carry, or they didn’t have the tools to undo the bolts. If you look closely, you can see how cleanly cut the copper tubing on the compressors are. This is indicative of a reciprocating saw like mine being used…
    IMG_3399.jpg IMG_3400.jpg IMG_3401.jpg IMG_3402.jpg IMG_3403.jpg IMG_3404.jpg IMG_3405.jpg IMG_3406.jpg
  10. Jan 5, 2025 at 2:12 PM
    #1590
    steelcity2
    steelcity2 Well-Known Member
    Pittsburgh Pa
    2013 MGM DCSB TRD sport
    Bilsteins 5100's all 4 corners 1 inch rear spacer
    Ask if u can clean up that mess. :D
  11. Jan 5, 2025 at 2:39 PM
    #1591
    Lt. Dangle
    Ohio
    Probably just sucking in blowing snow. A heat pump when low will freeze bands around it before freezing over. That looks too soft to be frozen from the pics.
  12. Jan 5, 2025 at 2:41 PM
    #1592
    Lt. Dangle
    Ohio
    Yes.
  13. Jan 5, 2025 at 3:02 PM
    #1593
    Just_A_Guy
    Just_A_Guy Rain is a good thing
    On the hunt
    A truck
    They don’t call it Pennslytucky for no reason!
  14. Jan 5, 2025 at 3:26 PM
    #1594
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
    I would melt.
  15. Jan 5, 2025 at 3:44 PM
    #1595
    PennSilverTaco
    Charlie
    I’m tempted; those compressors are worth a fortune and there’s still some copper!
    steelcity2[QUOTED] likes this.
  16. Jan 5, 2025 at 3:46 PM
    #1596
    PennSilverTaco
    Charlie
    :amen:
    Amanda routinely got into arguments with Emily when she lived with her, because she would run the damn heat in the summer!
  17. Jan 7, 2025 at 11:03 AM
    #1597
    PennSilverTaco
    Charlie
    Window fan is presently dormant because Amanda thought it was too cold, and window A/C is in fan mode…
    soundman98 and TnShooter[QUOTED] like this.
  18. Jan 7, 2025 at 12:00 PM
    #1598
    PennSilverTaco
    Charlie
    @TnShooter
    1st floor (Left; 2.5-ton) and 2nd floor (Right; 2-ton)…
    TnShooter likes this.
  19. Jan 7, 2025 at 12:30 PM
    #1599
    TnShooter
    Deogee
    STOCK
    Never owned a home with a split system.
    Hope I never do. I don’t intend to own a 2 story home, or a home much over 1,200 sq/ft.
  20. Jan 7, 2025 at 2:49 PM
    #1600
    PennSilverTaco
    Charlie
    You have a packaged unit, right?
