PennSilverTaco's "Perfect 5-Lug Regular Cab" Build, Aspergers, and General BS MegaThread!
Discussion in '2nd Gen. Builds (2005-2015)' started by PennSilverTaco, Jul 15, 2014.
  1. Jul 29, 2019 at 10:40 PM
    PennSilverTaco
    PennSilverTaco [OP] Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    How do I get the plastic intake cover off?
  2. Jul 30, 2019 at 4:25 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    Your excessive idling not only hurts your gas mileage but also your engine. I would not be shocked if that is a huge contributor if you are idling over an hour on each tank of gas.
    Fill the truck up and don't idle it at all this next tank and see what happens.
    Short city trips also crash mileage. I get 20mpgs normally if I do all highway. I get 16 driving in the city since I moved and no longer do virtually any highway trips anymore.
    This is why I opted not to go for any side hustles that use my truck. They are virtually moneyless jobs when you take out gas and wear and tear on these things out of the pay.
    Skyway likes this.
  3. Jul 30, 2019 at 5:15 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    FIFY. Duplicate what comes out. Mess with the next owners head if it’s sold....
    Edit: Never-mind. Just saw OP has a four banger.
    la0d0g likes this.
  4. Jul 30, 2019 at 5:34 AM
    CouchlessPotato
    CouchlessPotato Handcuffed to steering wheels still won firefights
    Zach
    You don't buy a truck for its fucking fenders!
    2.5" lift w/35's
    I believe toyota uses denso plugs. I put ngks in mine, but either is fine. Just check the gap. Not sure what it is on the 4 cyl. On the v6 the gap is about .044"
    Edit: yes you can do it in your driveway. Just clean up around the plug before you pull it so that no dirt falls into the cylinder and be careful not to drop anything in there. Take your time. Don't over tighten the nee plugs. Its a pretty easy job. There are tbreads on here on how to change plugs already.
  5. Jul 30, 2019 at 5:37 AM
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    Pretty sure I used 10mm on the coils? Unless the 4 cylinder is different.
    81shark likes this.
  6. Jul 30, 2019 at 5:57 AM
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    Didn't see anything said on a dirty air filter. Worth checking and replacing along with the fresh sparkys.
    Even with that, all the city driving/idling with A/C is the MPG killer for anything other than hybrids/plug-in electric cars. Chill out on the lead foot and that helps, too. Big difference in my MPG's when I just grandpa the truck around but it takes discipline.
    Gunshot-6A and blu92in99 like this.
  7. Jul 30, 2019 at 7:15 AM
    Hoyle
    Hoyle Well-Known Member
    Cookeville TN.
    2014 DCSB 4x4 Black
    A lot of stuff.
    CouchlessPotato likes this.
  8. Jul 30, 2019 at 7:21 AM
    CouchlessPotato
    Zach
    2.5" lift w/35's
    Took me about an hour the first time I did it on my v6, but I'm a mechanic and have lots of tools to help get around the stuff in the way so I barely had to take anything off.
    b_r_o likes this.
  9. Jul 30, 2019 at 7:24 AM
    CouchlessPotato
    Zach
    2.5" lift w/35's
    Same here, I didn't realize my engine was running so rough until I replaced the plugs. Original plugs had about double the gap they should have had due to wear. First time I drove it with the new plugs I noticed right away it was accelerating much smoother. I didn't think it was gonna make any difference, but I guess my original plugs were worse than I thought lol.
    E-Paz 732NJ likes this.
  10. Jul 30, 2019 at 7:38 AM
    TacomaSport86
    TacomaSport86 2010 Tacoma/2016 4Runner Pro
  11. Jul 30, 2019 at 7:41 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    DENSO #3493 sk20hr-a11 LONG LIFE IRIDIUM@ ROCKAUTO
  12. Jul 30, 2019 at 7:43 AM
    rara114
    rara114 Member
    2006 Tacoma Prerunner 2wd Access Cab
    That bracket in the way though...
    Oh, and don't over tighten the plugs when you install them as you'll be threading into aluminum.
  13. Jul 30, 2019 at 7:48 AM
    scocar
    scocar Patron of the Farts
    We don't know what tools you have.
    Do you have a torque wrench?
    Do you have a 3/8 ratchet with a long extension, the correct spark plug socket and some electrical tape?
  14. Jul 30, 2019 at 7:51 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Grab a magnetic spark plug socket: https://www.amazon.com/dp/B0014ZVSVK/ref=as_li_ss_tl?ref=idea_lv_dp_&language=en_US
    and gapper: https://www.amazon.com/dp/B00144AZ6K/ref=as_li_ss_tl?ref=idea_lv_dp_&language=en_US
    FishingPups and birry like this.
  15. Jul 30, 2019 at 7:56 AM
    JL8Jeff
    JL8Jeff Well-Known Member
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
    OME 885/nitros, SPC UCA, 305/65/17, AAL
    My guess is it's mainly the idling with the AC on. My last tank was almost 18 mpg and that was with multiple times towing the boat and no highway at all. I don't use the AC so that's not a factor and I'm running 33's with 3" lift.
  16. Jul 30, 2019 at 8:25 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Absolutely DO NOT use that style of gapper on the Irridium plugs necessary for the i4. You do not want to touch the tip of the center electrode with any other metal as the coating is thin. You want to use a wire style plug gaper where you pull the ground strap. That stated the plugs should come pregapped.
    BillsSR5 likes this.
  17. Jul 30, 2019 at 8:52 AM
    blu92in99
    blu92in99 Hates everyone, equally
    Justin
    Elk Grove, Ca
    Adding to this; tire pressures also play a factor in MPG.
    Torspd and Gunshot-6A like this.
  18. Jul 30, 2019 at 8:53 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
  19. Jul 30, 2019 at 9:07 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Denso copper
  20. Jul 30, 2019 at 9:13 AM
    Pibbles99
    Pibbles99 One more cast
    Brian
    Southern NH
    21 OR dbl cab
    Stealership wanted to charge me $270 ish for a plug change I’m like :eek:
    Four bucks a plug and a hour and a half and a you tube vid I can feel comfortable with and I had no issues.
    E-Paz 732NJ and birry like this.
