PennSilverTaco's "Perfect 5-Lug Regular Cab" Build, Aspergers, and General BS MegaThread!
Discussion in '2nd Gen. Builds (2005-2015)' started by PennSilverTaco, Jul 15, 2014.
  1. Jul 31, 2019 at 10:19 AM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Maybe Toyota is demonstrating that you don't need to have just one brand of plugs in your engine. You can have all different ones in all six cylinders!
  2. Jul 31, 2019 at 10:25 AM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    Off topic but I'm curious Charlie, when you idle for 30 minutes with A/C on does the compressor get really hot?
  3. Jul 31, 2019 at 10:38 AM
    Skyway
    Skyway Well-Known Member
    Ande'
    St.Pete
    White 2009 regular cab
    Looks about right!...
    No problems :woot::woot:
  4. Jul 31, 2019 at 10:55 AM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Its been around forever. My 2001 had both. Both companies (Denso and NGK) are Japanese, I believe, so I'm sure there are politics behind it.
  5. Jul 31, 2019 at 10:56 AM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Yes, A/C compressor will get hot when idling.
  6. Jul 31, 2019 at 12:41 PM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    Like 'too' hot?
    Everyone I know that does this on a rear wheel drive vehicle eventually blows up their compressor and it shits the bed of the whole system. I think you need a set of electric fans.
  7. Jul 31, 2019 at 12:49 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    im getting 22.3 MPGs[​IMG]
  8. Jul 31, 2019 at 1:11 PM
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    I've never seen anyone blowup an A/C and not sure what 2wd has to do with it. Your fan clutch should be engaged when the A/C is on. If not, it will overheat and blow. No need for E-fans.
    If you constantly idle, consider getting vents for your hood?
  9. Jul 31, 2019 at 2:56 PM
    81shark
    81shark Well-Known Member
    i'd would have changed them for $95.
  10. Aug 1, 2019 at 12:35 PM
    labmannn
    labmannn Well-Known Member
    Bill
    Mt. Juliet, TN
    2013 Tacoma TRD Sport Pkg 4WD
    window tinting, N-fab light bar, 4 Hella fog lights, N-fab step bars, 3" Pro Comp lift
    on my '13 4.0, V6 there are two nuts on the top of the plastic cover that have to be removed. They may be the same size as the 10mm needed to remove the coil pack. The cover should pull straight forward after removal. 2.7 liter motors are more simple to change and shouldn't take much more than 30 minutes.
  11. Aug 1, 2019 at 12:46 PM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    I run Bosch Iridium plugs in my V6. The V6s call for shitty copper plugs but the 4cyls call for the normal iridium.
    As long as you buy a compatible spark plug it really doesn’t matter what you get. They all work just as well.
  12. Aug 1, 2019 at 3:21 PM
    Freeheelbillie
    Freeheelbillie Well-Known Member
    Billie
    Saint Clair, MI
    2019 Tacoma SR, DCSB
    FRONT END King Stage 3 3” RR Coil Overs SPC UCA’s REAR END King Stage 3 BAMF Shock Relocation Rear AAL Heavy ARB Universal Diff Breather Kit TIRES & RIMS 16” Method Bronze BFG K02 (315/75/R16) ARMOR Demello Off Road Baja Hoop Front Bumper Main Line Overland Rock Sliders w/ Top Plate ¼” Aluminum RCI Fuel Tank Skid RCI Fuel Tank Straps RCI Rear Diff Skid RCI A-Arm Skids RCI – Front, Transmission, and rear Transfer Case Skid DRIVE LINE YotaWerx, BlackHawk Tune Re Geared w/ Nitro 4.56 Package Front ARB Air Locker Rear ARB Air Locker 8” Reverse Clamshell 3.73 & Down Carrier RECOVERY ComeUp Seal Gen2 9.5RS Winch, Synthetic Line ComeUp Seal Hawse Fairlead ARB On Board Twin Air Compressor LIGHTING Squadron-R Pro Amber Fogs (Wide Cornering) Baja Designs Rock Lights Squadron Sport Fogs (qty 4) Baja Designs Bed Light Kit SPODS, HD 8 Circuit Switch Panel
    Late to the party but when was the last time the plugs were changed? I gained an easy 7mpg after changing mine.
  13. Aug 1, 2019 at 7:35 PM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    Ask at city service garages how often their (our) vehicles crap out from all the idling, especially A/C and more so RWD because the fan does very little at idle. Even working corrrectly.
    Consider opening the hood if sitting. Seriously we just opened one that was black inside.
  14. Aug 1, 2019 at 8:02 PM
    redz80
    redz80 Well-Known Member
    Brampton, ON
    Tacoma SR5 TRD 4x4 SWB
    Thinkware f800 with the hard wire kit and rear camera. I have been running the thinkware f750 without any performance issues.
  15. Aug 2, 2019 at 4:09 AM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    These trucks just don’t get good fuel mileage. I just towed a 12ft trailer from Florida to Nova Scotia. Keeping in 4 instead of D, I got 200 miles/tank. What an expensive drive. I only get 240 miles per tank not towing and tranny in D.
  16. Aug 2, 2019 at 8:39 PM
    PennSilverTaco
    PennSilverTaco [OP] Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    So, I am in Carlisle for the weekend...
    I left the fairgrounds to check into my hotel, and when I came out of the hotel to move the truck into a parking space, this happened...
    The parking brake was not on. In parking lots, I will generally shift into drive and let the truck move under its own power. When I shifted into drive, the truck did not move for several seconds.
    I think it's an electronic/sensor issue rather than a problem with the transmission itself. I talked to someone at the truck show and he thinks the same thing. My dad says I probably have nothing to worry about. Another friend of mine thinks I might be low on transmission fluid.
    My truck has literally just over 102K miles and the transmission fluid was changed (and flushed) last year. The truck drove fine for the rest of the day and is currently safely parked in the hotel parking lot as I write this.
  17. Aug 2, 2019 at 8:46 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    During the time it was NOT moving, were you ever pressing the gas pedal?
    Or were you letting it “idle” and trying to have it roll under its own power?
    PennSilverTaco[OP] likes this.
  18. Aug 2, 2019 at 8:47 PM
    PennSilverTaco
    Charlie
    Combination of both, lightly pushing the gas but not gunning it...
  19. Aug 2, 2019 at 8:53 PM
    TnShooter
    Deogee
    STOCK
    When you did get it to move, did it jerk or jump it to gear?
    Or did it seem to take off normally?
    Just asking so we can get all the information we can to help you.
  20. Aug 2, 2019 at 8:54 PM
    PennSilverTaco
    Charlie
    It did not jerk or jump. It's as if it was in park and the computer or something didn't register. All of sudden it started rolling...
