PennSilverTaco's "Perfect 5-Lug Regular Cab" Build, Aspergers, and General BS MegaThread!
Discussion in '2nd Gen. Builds (2005-2015)' started by PennSilverTaco, Jul 15, 2014.
  1. Nov 25, 2019 at 6:28 PM
    PennSilverTaco
    PennSilverTaco [OP] Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    @LivinOnEdge
    You don't think my entire rear axle is failing, do you?
  2. Nov 25, 2019 at 6:32 PM
    EdinCincinnati
    EdinCincinnati Well-Known Member
    Ed
    Ohio
    2014 4x4 TRD OR
    What did the OP @PennSilverTaco do to get banned? Or does the blue line through his name mean something else?
    SR-71A and PennSilverTaco[OP] like this.
  3. Nov 25, 2019 at 6:33 PM
    PennSilverTaco
    Charlie
    That is a LEO "blue line"; tcBob added it for me!
  4. Nov 25, 2019 at 6:34 PM
    EdinCincinnati
    Ed
    Ohio
    2014 4x4 TRD OR
    ahhh...cool!! Appreciate LEOs and will always have ones back!
  5. Nov 25, 2019 at 6:37 PM
    PennSilverTaco
    Charlie
    I had one less-than-pleasant encounter with police almost 7 years ago where I got stopped and interrogated for taking pictures (I have Aspergers Syndrome and it was my first encounter with police EVER, so it kinda traumatized me). I've decided that I need to let it go, and that police really need our support right now...
  6. Nov 25, 2019 at 6:39 PM
    EdinCincinnati
    Ed
    Ohio
    2014 4x4 TRD OR
    My truck blew its right rear seal last week. It’s sitting in my local shop getting new seals, bearings and drums/shoes tonight. 140K miles on the odometer. Paying that will be painful.
    Will be promptly doing the breather relocation mode Thursday while turkey is cooking.
    PennSilverTaco[OP] likes this.
  7. Nov 25, 2019 at 6:41 PM
    PennSilverTaco
    Charlie
    Do you have any idea what could be causing mine to repeatedly fail? The diff breather? Where is that located?
  8. Nov 25, 2019 at 6:43 PM
    EdinCincinnati
    Ed
    Ohio
    2014 4x4 TRD OR
    it’s the little silver plug thing on top of the axle housing just left of center. In rust belt states, they do rust and stop reliving air pressure when the inside heats up, which can pop either side seal.
  9. Nov 25, 2019 at 6:45 PM
    PennSilverTaco
    Charlie
    I live in Pennsylvania; How much does one of these cost to replace?
  10. Nov 25, 2019 at 6:46 PM
    PennSilverTaco
    Charlie
    My friend says "stop going to the dealer"...
    This is one of those "No shit, Sherlock" situations, but I have a feeling the dealer will pay to fix it for free AGAIN.
  11. Nov 25, 2019 at 6:48 PM
    EdinCincinnati
    Ed
    Ohio
    2014 4x4 TRD OR
    $10 bucks. For the plug itself.
    search in here for “Breather Mod” and get a threaded hose union, 6-8’ of fuel hose and relocate it up higher.
    or buy a pre-made breather mod setup...I think Toy-Tec sells one - but it’s just cheap sourced parts marked up.
  12. Nov 25, 2019 at 6:56 PM
    PennSilverTaco
    Charlie
    Where do I get the plug? I'll have my mechanic do it...
  13. Nov 25, 2019 at 7:00 PM
    EdinCincinnati
    Ed
    Ohio
    2014 4x4 TRD OR
    your dealer parts desk, Amazon or eBay.
    Use the search feature for “Breather Mod” and you will have all the info needed.
  14. Nov 25, 2019 at 7:05 PM
    LivinOnEdge
    LivinOnEdge ¯\_(ツ)_/¯
    Land of The Lost
    Four wheels and a refrigerator
    I have no idea friend. I’m not that mechanically inclined nor qualified. However, if that was the case, the technicians should have been able to tell you that right off the bat.
  15. Nov 25, 2019 at 7:06 PM
    LivinOnEdge
    Land of The Lost
    It means something else, but we may never know.
  16. Nov 25, 2019 at 7:07 PM
    PennSilverTaco
    Charlie
    It means "I support cops"...
  17. Nov 25, 2019 at 7:11 PM
    NM Lance
    NM Lance Well-Known Member
    The seal itself can be seated at different depths within the axle shaft tube to compensate for the groove in axle shaft. Or, purchase another axle shaft. It's a pretty easy job actually, if it is something you are willing to tackle. Brakes will be the hardest (assuming everything else goes well), but drum brakes are pretty easy...
  18. Nov 25, 2019 at 7:21 PM
    PennSilverTaco
    Charlie
  19. Nov 25, 2019 at 7:31 PM
    LivinOnEdge
    Land of The Lost
    Meh, wont bother him with petty things. :thumbsup:
  20. Nov 25, 2019 at 7:38 PM
    EdinCincinnati
    Ed
    Ohio
    2014 4x4 TRD OR
    don’t know. Don’t know if your breather valve is bad either. Possible the left seal hasn’t been seated correctly either prior time it was replaced...could be breather or just bad luck.
    I suggest checking breather valve though, cheap to replace, might as well replace and know it’s not a reason in the future.
