PennSilverTaco's "Perfect 5-Lug Regular Cab" Build, Aspergers, and General BS MegaThread!
Discussion in '2nd Gen. Builds (2005-2015)' started by PennSilverTaco, Jul 15, 2014.
  1. Nov 25, 2019 at 7:39 PM
    PennSilverTaco
    PennSilverTaco [OP] Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    I think I will have my mechanic do that though...
    Goddamn stealership!
  2. Nov 25, 2019 at 8:22 PM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Have your mechanic unscrew the rear diff breather, if a lot of air comes out it’s pressurized and not breathing. Most likely pushing gear oil past your axle seals. There’s been a few instances of this even read about it on other forums.
    Whichever the case, a good mod to do is the rear diff breather (completely open both ways) and relocate it higher behind the taillight. Helps if you ever submerge your rear diff and keeps it from pressurizing. This is an aftermarket mod, the dealer won’t do it.
  3. Nov 25, 2019 at 8:24 PM
    PennSilverTaco
    Charlie
    I have a 5-lug, I don't think I'll ever submerge my rear diff unless we get record amounts of rain and flash flooding here in the Philly burbs! I do agree with opening it both ways. One thing I do not get is why the right axle seal has not blown! Also, I've been having trouble finding the thread for this mod...
  4. Nov 25, 2019 at 8:29 PM
    Grossomotto
    2017 4WDV6LB6MT
    Here’s one of the threads, there’s a lot more. Also, here’s the part to use, it’s open both ways, you can use a fuel line hose that’ll fit over the end. I’ve done the mod with the much more expensive ARB one, but no need to.
    https://www.tacomaworld.com/threads/rear-diff-breather-mod.409814/
    https://www.amazon.com/dp/B00P2S0TKQ?colid=3LBJF1PVEYVXW&coliid=I11M7MN6NS7R2Z
  5. Nov 25, 2019 at 8:30 PM
    PennSilverTaco
    Charlie
    Does that come put in order to flush/refill the diff fluid?
  6. Nov 25, 2019 at 8:31 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Just have them check for a bent axle shaft, it happens and it was the reason a friend of ours kept killing seals.
  7. Nov 25, 2019 at 8:32 PM
    PennSilverTaco
    Charlie
    You mean the driveshaft?
  8. Nov 25, 2019 at 8:34 PM
    Grossomotto
    2017 4WDV6LB6MT
    That’s just the breather on top of the diff. The fill hole is much bigger and the drain hole is of course on the very bottom.
    If you do the mod, spray some Pb blaster or WD40 on the original breather and let it soak into the threads. Especially if it’s 10 years old and never taken off.
  9. Nov 25, 2019 at 8:34 PM
    Speedytech7
    No i mean the things your wheels are bolted (nutted?) to in the rear, theres one on each side. Whichever side keeps killing axle seals should be checked for true. A big enough pothole could bend one of the significantly smaller 5 lug shafts.
  10. Nov 25, 2019 at 8:36 PM
    PennSilverTaco
    Charlie
    A wheel bearing was "notched"; A technician failed to mention this and got thoroughly bitched out by his manager the second time I brought the truck in. The dealership replaced the "notched" bearing for free, as well as the axle seal.
  11. Nov 25, 2019 at 8:37 PM
    Speedytech7
    They should check that axle to make sure it is straight. Hell you can even check it yourself well enough just by jacking that one wheel off the ground and letting it spin in gear with some speed to see if it wobbles.
  12. Nov 25, 2019 at 8:37 PM
    PennSilverTaco
    Charlie
    How much could this end up costing?
  13. Nov 25, 2019 at 8:38 PM
    Speedytech7
    Whatever the cost of an axle shaft and the bearing /seal job is (the bearing and seal are pressed onto the axle shaft so they kinda have to be replaced if the shaft is found to be dicked)
  14. Nov 25, 2019 at 8:39 PM
    PennSilverTaco
    Charlie
    Over $2,000?
  15. Nov 25, 2019 at 8:40 PM
    Speedytech7
    Doubt it haha, I'm sure you can get an axle shaft cheap enough, 5 lugs are plentiful in the junkyards if it came down to it. The labor is the most expensive and it sounds like you've already paid for that before so you should know what it adds up to.
  16. Nov 25, 2019 at 8:41 PM
    PennSilverTaco
    Charlie
    I know of a totaled 2010 RC 5-lug in a junkyard, but the axle (along with the engine and trans) was long gone...
    I'm thinking of buying it for the cab and hood just in case.
  17. Nov 25, 2019 at 8:42 PM
    PennSilverTaco
    Charlie
    @Speedytech7
    It was wedged behind a Cadillac so I couldn't get the best shots of it...
  18. Nov 25, 2019 at 8:45 PM
    Speedytech7
    Looks like an axle shaft for a 5lug goes for about $75 used in Junkyards near Pottstown, PA
  19. Nov 25, 2019 at 8:46 PM
    PennSilverTaco
    Charlie
    Do I really want used? And do I have to remove the damn thing myself?
  20. Nov 25, 2019 at 8:47 PM
    Speedytech7
    Most of the yards will remove it for you and you just pick it up on car-part.com
    Used should be fine, kinda rare to have a bent one if that is what it turns out to be
