PennSilverTaco's "Perfect 5-Lug Regular Cab" Build, Aspergers, and General BS MegaThread!
Discussion in '2nd Gen. Builds (2005-2015)' started by PennSilverTaco, Jul 15, 2014.
  1. Dec 1, 2019 at 12:15 PM
    GQ7227
    GQ7227 mw survivor
    J A Y
    it is nice, especially on light misty days
    whatstcp[QUOTED] and JC15Taco like this.
  2. Dec 1, 2019 at 12:17 PM
    PennSilverTaco
    PennSilverTaco [OP] Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    I think the Frontier is inferior because I rented one in 2014 and it had the turning radius of an aircraft carrier. The ride was also very harsh and I felt every bump. I thought the older Frontiers were good as long as they had tilt steering; I drove a 2002 without tilt steering and my knees touched the steering wheel; The brakes on newer Frontiers are good, but they don’t make up for the truck’s Nimitz-class turning circle!
  3. Dec 1, 2019 at 12:19 PM
    PennSilverTaco
    Charlie
    I have a receipt saying the wheel bearing was replaced, too...
    Muddinfun[QUOTED] likes this.
  4. Dec 1, 2019 at 12:19 PM
    PennSilverTaco
    Charlie
    Or have my mechanic send them the bill...
  5. Dec 1, 2019 at 12:20 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Oh I know, I'm just ribbing you. No vehicle is perfect, and I'm well aware of the turning radius - mine is the longest one they make. You get used to it, but my taco feels like a go kart in comparison.
  6. Dec 1, 2019 at 12:20 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    When I sold my 97 it had the original rear brakes at around 300K.
  7. Dec 1, 2019 at 12:22 PM
    4xdog
    4xdog Well-Known Member
    Santa Fe, NM
    03 DC TRD OR, 15 DC TRD OR, 08 RX350, 62 TR3B
    The cruise control on my Gen 1 (previous 2001 and now 2003) and Gen 2 (2015) Tacomas is better than nothing, but frankly not much better. On all of my trucks the cruise hunts and downshifts too soon and through too many gears. It'll roar from fourth to second on a mild grade and then not let go until well after the crest. Alternatively, managing it with my right foot and no cruise often barely needs a change in throttle. The cruise module on our Tacomas is really quite dumb by comparison to the one on my 2008 Lexus RX350, as well. That car's cruise control is nearly invisible and downshifts are uncommon and barely noticed.
    In even slightly hilly ground I turn off the cruise on my trucks 'cause the d**ned module is such a PITA. I wouldn't pay much to add it to a truck that didn't have it.
    PennSilverTaco[OP] likes this.
  8. Dec 1, 2019 at 12:22 PM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
  9. Dec 1, 2019 at 12:23 PM
    PennSilverTaco
    Charlie
    @Muddinfun
    I might bring my dad to the dealer tomorrow, as backup. The difference between me and my dad is that I am not as calm and collected as he is...
    whatstcp and Muddinfun like this.
  10. Dec 1, 2019 at 12:24 PM
    PennSilverTaco
    Charlie
    @maineah
    You quoted your own post...
  11. Dec 1, 2019 at 12:29 PM
    Sasquatchian
    Sasquatchian Well-Known Member
    Ditto here. My '93 had 300K when I sold it a year ago and it still had half the original shoes left. Every few years it's a good idea to take the drums off, blow out the dust and properly lube the points that need it. Other than that completely trouble free and that truck never had a rear bearing issue although the fronts did get replaced once.
  12. Dec 1, 2019 at 12:34 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Is it worth it?
    Used the cruise exactly twice, I think..., in the 12years I've had the truck. So to me, no it's not worth the trouble but it's your truck.
    JC15Taco and El Duderino like this.
  13. Dec 1, 2019 at 1:22 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Nice!
  14. Dec 1, 2019 at 1:37 PM
    TacoTuesday1
    SD CA
    blow the dust out?
    isn't brake dust harmful to inhale, whether it has asbestos (old cars) or not?
    because when you say blow it out, this sounds like using compressed air.
    What about rinsing the dust out with a liquid such as water instead? And if it needs to be dry, maybe a final rinse down with more expensive brake cleaner (because it evaporates when drying quickly) or even driving the truck after so that the brakes warm up enough to evaporate the water.
  15. Dec 1, 2019 at 1:58 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    I was going to suggest just doing away with them as they don't work anyway. No brake shoe should last 300K if they touch a surface on a regular basis. My Sienna went through them every 50K. I've written several times that I don't think they work unless weight is back there.
    I dunno man, I've had trucks that the rear brakes worked fine and never were a problem locking up. When you have ABS, I don't even know why people worry about over braking the rear.
  16. Dec 1, 2019 at 2:08 PM
    PennSilverTaco
    Charlie
    My first set of rear brakes was replaced at a little over 84K...
  17. Dec 1, 2019 at 2:19 PM
    DG92071
    DG92071 Well-Known Member
    If you give the dealer 3 attempts to repair a problem then you have the legal right to send them the bill that corrected the problem. If you don't give the dealer 3 chances then you don't...
  18. Dec 1, 2019 at 2:26 PM
    disconnected
    disconnected LOST
    Greg
    Pittsburgh
    19 TRD Off-Road
    Icon 2,5'' coilovers and rear springs, RCI full skids, caliraised sliders, Warfab hitch skid, UpTop roof rack, kb voodo bed rack, Diode Dynamis Pro fogs, Seat Jackers with Molle, taco garage mounts..... and other stuff
    Goodman rules-
  19. Dec 1, 2019 at 2:34 PM
    PennSilverTaco
    Charlie
    Carrier and Trane are better...
    shakerhood likes this.
  20. Dec 1, 2019 at 2:37 PM
    disconnected
    disconnected LOST
    Greg
    Pittsburgh
    19 TRD Off-Road
    Thought Goodman made those?
