PennSilverTaco's "Perfect 5-Lug Regular Cab" Build, Aspergers, and General BS MegaThread!
Discussion in '2nd Gen. Builds (2005-2015)' started by PennSilverTaco, Jul 15, 2014.
  1. Dec 6, 2019 at 9:00 PM
    PennSilverTaco
    PennSilverTaco [OP] Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    So is this related to the brakes, the leaf springs, or both?!?!
  2. Dec 6, 2019 at 9:02 PM
    tcjacado
    tcjacado Well-Known Member
    They would be separate squeaks. Leaf packs will squeak once they get a little dirt in them.
    The brake shoes will squeak once warmed up. My brakes squeak/squeal occasionally if I am just kinda creeping forward but still applying pressure to the brake pedal.
  3. Dec 6, 2019 at 9:04 PM
    PennSilverTaco
    Charlie
    My rear brake squeaks and squeals when braking from higher speeds, sometimes from lower speeds.
  4. Dec 6, 2019 at 9:04 PM
    PennSilverTaco
    Charlie
    Revenue Generation Officers at their finest...
    Though have you learned your lesson and always worn your seatbelt since then?
  5. Dec 6, 2019 at 9:07 PM
    tcjacado
    Most likely the new brake shoe pads didn't get broken in/ seated properly on install, Or it may have some of the hardware out of adjustment. May be it needs new hardware and give the inside of the drums a light sanding.
  6. Dec 6, 2019 at 9:07 PM
    PennSilverTaco
    Charlie
    I would have fought it...
    You have a harrowing experience and they have the balls to write you a ticket!
  7. Dec 6, 2019 at 9:08 PM
    PennSilverTaco
    Charlie
    Will this make the truck unsafe or otherwise cause a problem if not dealt with immediately?
  8. Dec 6, 2019 at 9:09 PM
    tcjacado
    Nope, its most likely fine and will cause no long term issues, just annoying and irritating to listen to.
  9. Dec 6, 2019 at 9:09 PM
    PennSilverTaco
    Charlie
    I think their should be some sort of system where if you have a clean driving record you don't get a ticket unless you've done something particularly dangerous/illegal...
  10. Dec 6, 2019 at 9:10 PM
    PennSilverTaco
    Charlie
    Will it shorten the life of brakes? Also, is it possible that the blown axle seal was a coincidence the squeak was its own problem?
  11. Dec 6, 2019 at 9:12 PM
    PennSilverTaco
    Charlie
    Exactly! I always wear my seatbelt as a matter of common sense.
    Street racing, drunk driving, and going more than 15-20 MPH over the speed limit are among the offenses I believe should carry consequences...
  12. Dec 6, 2019 at 9:18 PM
    tcjacado
    It shouldn't shorten the life of the brakes... our trucks use like 80/20 ratio.
    Front brakes are 80 percent when brakes are applied
    Rear brakes are the other 20 percent when brake pedal is applied. Also used as e brake/parking.
    The truck is good to go and the axle seals are a item that needs to be replaced from time to time. The only question is how much oil got splattered around in there. If the drums or shoes were not properly cleaned off, it can cause your squeak issue also, but will not cause any major long term issues. Kinda sounds like a little bit of oil was not gotten off the shoes/pads or they are simply a little out of adjustment . If new shoe and drums were installed after the axle seal, then its just out of adjustment, not seated or not broken in. Again, shouldn't cause any major issues down the road. Wheel cylinders, shoes hardware, and drums are fairly cheap any how.
  13. Dec 6, 2019 at 9:19 PM
    PoweredBySoy
    PoweredBySoy Well-Known Member
    Jesse
    Minnesota
    2013 DCSB SR5
    tcjacado likes this.
  14. Dec 6, 2019 at 9:19 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    Yup. Just tightened it up. Silence.
  15. Dec 6, 2019 at 9:20 PM
    PennSilverTaco
    Charlie
    What I'm really pissed off about is that the previous set of drums had only 22K miles on them! I was hoping to get at least 100K!
    tcjacado[QUOTED] likes this.
  16. Dec 6, 2019 at 9:20 PM
    PennSilverTaco
    Charlie
    @PoweredBySoy
    You didn't post anything, just sorta quoted me...
  17. Dec 6, 2019 at 9:20 PM
    tcjacado
    It's an understatement with Charlie, but we love him despite what anyone says.:cheers:
    PennSilverTaco[OP] likes this.
  18. Dec 6, 2019 at 9:21 PM
    tcjacado
    It's ok.... some of us understand. :hattip:
  19. Dec 6, 2019 at 9:21 PM
    PennSilverTaco
    Charlie
    You should see the attention to detail I applied to putting Christmas lights on my parents' house!
  20. Dec 6, 2019 at 9:22 PM
    tcjacado
    I know all about it... I have been here a while;)
    As I said, you are good. Carry on. You be you.:thumbsup:
