PennSilverTaco's "Perfect 5-Lug Regular Cab" Build, Aspergers, and General BS MegaThread!
Discussion in '2nd Gen. Builds (2005-2015)' started by PennSilverTaco, Jul 15, 2014.
  1. Dec 6, 2019 at 9:46 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    If your drums are aftermarket that may be the issue. I kept dealing with it on my corolla but it drove me nuts so I finally bought Toyota drums. Noise never came back.
  2. Dec 7, 2019 at 5:52 AM
    ctcz28
    ctcz28 Well-Known Member
    Texas
    2015 Blue Ribbon Metalic DCSB Prerunner
    Not clear from the above statements if the noise is constant or just initially upon braking. I'd pull the drums, pry the brake shoes slightly away from the backing plate and dab some anti-seize (a Q-tip works well) on the raised pads of the backing plate where the edge of the brake shoes contact the backing plate. Also, is there any chance that the brake shoes were installed wrong given one shoe on each side is normally longer than the other shoe of the pair, i.e., leading shoe vs. trailing shoe?
  3. Dec 7, 2019 at 5:57 AM
    J_Anthony_
    J_Anthony_ Well-Known Member
    RangerIsTheBestTruck.Duh.
    Naomi, Lana
    I had a squeak. There’s a thread on it somewhere. A good amount of us spent weeks trying to figure it out. Uploading photos here, uploading videos, trying everything. . We could think off.
    turns out it was my leafs. When I would accelerate, the truck front would lift ever so slightly and causes the leafs to squeak. Happened when I hit the brakes, and the front came down a bit while the rear lifted.
    Lithium grease is what solved my problem. I sprayed my leafs with it, and I’ve been squeak free for months now.
    GL
    PennSilverTaco[OP] likes this.
  4. Dec 7, 2019 at 12:55 PM
    PennSilverTaco
    PennSilverTaco [OP] Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
  5. Dec 7, 2019 at 1:25 PM
    PennSilverTaco
    Charlie
    At 30, I still love Disney movies! I just signed up for Disney Plus (Disney+)! $6.99 a month for all the Disney movies I could ever hope to watch, including the Marvel movies!
    :drool:
    Taco critter likes this.
  6. Dec 7, 2019 at 1:26 PM
    PennSilverTaco
    Charlie
    I'm taking the Tacoma into Doylestown again this evening to do a holiday-themed DoorDash run!
  7. Dec 7, 2019 at 2:53 PM
    PennSilverTaco
    Charlie
    It’s mostly to show off the truck...
  8. Dec 7, 2019 at 2:55 PM
    PennSilverTaco
    Charlie
    A post in the Doylestown Facebook page featuring pictures of my truck has gotten well over 500 likes!
  9. Dec 7, 2019 at 2:58 PM
    PennSilverTaco
    Charlie
  10. Dec 7, 2019 at 3:04 PM
    PennSilverTaco
    Charlie
    Made a friend while waiting for the DoorDash order...
  11. Dec 7, 2019 at 5:47 PM
    PennSilverTaco
    Charlie
    Watching Pocahontas for the first time since probably 1998!
  12. Dec 7, 2019 at 5:56 PM
    PennSilverTaco
    Charlie
    It came out in 1995...
    My parents took me to see it at the AMC 309 when it first came out. My mom bought it for me on VHS in probably 1996. I haven’t watched that tape since at least 1999!
  13. Dec 7, 2019 at 6:00 PM
    PennSilverTaco
    Charlie
    Did you take her to see Disney movies?
  14. Dec 7, 2019 at 6:02 PM
    PennSilverTaco
    Charlie
    I probably do too, but I haven’t physically any of them since 2002 or so.
  15. Dec 8, 2019 at 7:34 AM
    PennSilverTaco
    Charlie
    @Taco critter
    Watching Beauty and the Beast for the first time in nearly 25 years!
    disconnected and Taco critter like this.
  16. Dec 8, 2019 at 8:42 AM
    clenkeit
    clenkeit Well-Known Member
    Colin
    Lakewood, CA
    2010 White DCLB TRD Sport
    That should actually be fairly easy depending on your level of 12v electrical know-how. I'm actually kinda surprised that it doesn't already work in your car. From your other post you said you have a Pioneer stereo so I'm assuming you used an adapter harness to get it hooked up and working. That harness should be re-routing your factory aux wiring to your new head unit. Of course, the head unit may not accept that type of input and it may be looking for an RCA input. If thats the case you should be able to find the wires from the aux port and then wire them up to some RCA connectors and voila.
    Of course, you could also just remove the factory aux port and replace it with either:
    1) Factory Tundra USB/Aux port https://www.ebay.com/p/656717316?ii...tghg_um4gbGGr2gKk3siFu4sjYnLaOrBoCsfMQAvD_BwE Without the proper wiring connector it would be a little bit of a pain to wire but if you're familiar with 12v and audio electronics it shouldn't be an issue.
    2) Use a more generic USB/Aux port which would just wire right up to your head unit. The issue then would be finding a good place to mount it. You may be able to find a better one than I found in my 5sec search, which might allow you to install into an OEM switch blank that way you don't have to cut any interior panels.
    https://www.crutchfield.com/S-SqZhw...k0IevaShHZbRa6pNxO22S_xmVwht_sohoC534QAvD_BwE
  17. Dec 8, 2019 at 10:59 AM
    PennSilverTaco
    Charlie
    At a winery to see my friend’s band play!
  18. Dec 8, 2019 at 11:02 AM
    PennSilverTaco
    Charlie
    OLD Mitsubishi air-conditioner at the winery...
    shakerhood and Taco critter like this.
  19. Dec 8, 2019 at 11:03 AM
    PennSilverTaco
    Charlie
    Inside the winery...
    09A487DE-89E7-4491-82B1-AC851549B3E5.jpg E66FBD9E-9FB3-4E92-95B6-6006C71C7811.jpg
  20. Dec 8, 2019 at 11:58 AM
    PennSilverTaco
    Charlie
    This winery allows dogs!
    FE295744-ADBC-4572-9E6E-7E134A696244.jpg 717B90B4-3715-4E57-875A-A3AA7FA8A607.jpg FBC8BAA8-4ACA-4270-A9AB-35506EB67A6F.jpg
