PennSilverTaco's "Perfect 5-Lug Regular Cab" Build, Aspergers, and General BS MegaThread!
Discussion in '2nd Gen. Builds (2005-2015)' started by PennSilverTaco, Jul 15, 2014.
  1. Dec 11, 2019 at 11:44 AM
    PennSilverTaco
    PennSilverTaco [OP] Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    My uncle (same one who accidentally put 87 in the Pathfinder) has a 2006 Dodge Ram 2500 DCSB 4x4 with the Cummins Diesel and automatic. He has reported 18 MPG on the highway while pulling his 1969 Airstream camper.
  2. Dec 11, 2019 at 11:45 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    lol, i doubt it
    PennSilverTaco[OP] likes this.
  3. Dec 11, 2019 at 11:47 AM
    PennSilverTaco
    Charlie
    Is your F350 a stick shift?
  4. Dec 11, 2019 at 11:52 AM
    El Duderino
    El Duderino Obviously, you're not a golfer.
    Jeremy
    HI->PNW
    19 nautical blue SR5 premium 4x4
    Stuff, things, this, an ADS
  5. Dec 11, 2019 at 11:53 AM
    PennSilverTaco
    Charlie
    Me too, but I’d never buy a new one unless I could pay cash!
    shakerhood and Taco critter like this.
  6. Dec 11, 2019 at 11:56 AM
    TacomaWilly
    TacomaWilly Well-Known Member
    20 MPG is a unicorn truck?
    I was getting 20 MPG until I got my frame and exhaust replaced. Now I get 18 MPG. Might be winter gas too though. Anyways I'm due for new plugs, so I'll see if that helps.
  7. Dec 11, 2019 at 11:59 AM
    PennSilverTaco
    Charlie
    What is your truck, exactly? Cab, bed, engine, tranny, etc?
  8. Dec 11, 2019 at 12:00 PM
    knottyrope
    Knotty
    Bahstun
  9. Dec 11, 2019 at 12:02 PM
    PennSilverTaco
    Charlie
  10. Dec 11, 2019 at 12:06 PM
    wheeliest
    wheeliest ///////////////////
    Json
    TMPE AZ
    05-SWB-DCSB-4X4-V6-SR5-SPORT
    NO SWAYBAR, Spacer lift with dirty4's
    if you only drive 35mph, down hill and enough distance to deplete the entire tank each time i guess not..
  11. Dec 11, 2019 at 12:31 PM
    knottyrope
    Knotty
    Bahstun
    I know a few with a transmission with 400k miles and no issues. Biggest killer is not using OD when towing which burns them out.
  12. Dec 11, 2019 at 12:33 PM
    PennSilverTaco
    Charlie
    I’ve been told that the manual 7.3Ls shift more like semi trucks than light trucks...
  13. Dec 11, 2019 at 12:48 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    My neighbor across the street had one for a year or two, he told me he always wanted one but decided it wasn't worth the expense.
  14. Dec 11, 2019 at 12:50 PM
    PennSilverTaco
    Charlie
    That’s exactly why my dad sold his BMW convertible after two years. He could easily afford the car, but the cost of just routine maintenance took the fun right out of it.
  15. Dec 11, 2019 at 1:00 PM
    TacomaWilly
    06 dbl cab long bed 4.0 5 speed auto
  16. Dec 11, 2019 at 1:03 PM
    shakerhood
    Southern Ohio
    This guy across the road bought a Suburban to replace it, he had a Hummer prior to the Mercedes but that was just more of the same.
  17. Dec 11, 2019 at 1:06 PM
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    Truck isn't stock.
    Hills are not compensated in the mpg for manufactures.
    Your winter blend up there is shit
    Drive like an egg is under the pedal
    How often is it downshifting raising the revs on small hills?
    I quit driving with my head out the window and tongue out and its saved me 0.8 mpg
  18. Dec 11, 2019 at 2:22 PM
    disconnected
    disconnected LOST
    Greg
    Pittsburgh
    19 TRD Off-Road
    Icon 2,5'' coilovers and rear springs, RCI full skids, caliraised sliders, Warfab hitch skid, UpTop roof rack, kb voodo bed rack, Diode Dynamis Pro fogs, Seat Jackers with Molle, taco garage mounts..... and other stuff
    Audi’s are expensive to work on too.
  19. Dec 11, 2019 at 5:07 PM
    Loco_Barbon
    Loco_Barbon Just deez nutz hangin’ out
    Hugh Mungus
    Where ever my 10mm isn’t
    i LiKe tRuCkS!!
    Penis valve stem caps.
    It is very frustrating to me as a mechanic to hear stories like this, I was at the stealership a few days ago to get the first oil change on my truck (only because it's free) and a older gentleman pulled up in a very clean 2wd 2nd gen, I heard him tell the service writer that he had two warning lights, the service writer looked in and with out missing a beat told him "the tire light is on because you probably have a bad tire, and the check engine light comes on when the vehical detects a engine misfire." He never even checked the tire pressure and sure as hell didn't plug in a scanner to see why the check engine light was on.
    Oil can not penetrate into drums and ruin them, if they were out of tolerance then you should have asked them what the specs are and to show you the measurements. If they were replaced because they were out of tolerance then somewhere the tech had to record his findings and pass them onto the service writer, it should be documented in your paperwork. At this point I would chalk this one up to a learning experience and move on, it's a shitty feeling thinking you were taken advantage of, but dwelling on it won't make it better.
    Tacosail, PzTank, Hobbs and 1 other person like this.
  20. Dec 11, 2019 at 5:09 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Want mine? I was gonna take them to the scrape yard.
