PennSilverTaco's "Perfect 5-Lug Regular Cab" Build, Aspergers, and General BS MegaThread!
Discussion in '2nd Gen. Builds (2005-2015)' started by PennSilverTaco, Jul 15, 2014.
  1. Dec 11, 2019 at 7:43 PM
    PennSilverTaco
    PennSilverTaco [OP] Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    I got new ones; Would the cost of shipping from Texas to PA be worth it?
  2. Dec 11, 2019 at 7:44 PM
    PennSilverTaco
    Charlie
    No more stealerships for this guy!
  3. Dec 11, 2019 at 7:44 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    Prob not.
  4. Dec 11, 2019 at 7:46 PM
    PennSilverTaco
    Charlie
    I’m not a mechanic and I can tell you all the reasons why a Check Engine Light can come on!
  5. Dec 11, 2019 at 7:51 PM
    PennSilverTaco
    Charlie
    And the one thing I feel better about is that I got hundreds of dollars in free parts and labor from this dealer because they fucked up in the first place!
  6. Dec 11, 2019 at 8:07 PM
    Sasquatchian
    Sasquatchian Well-Known Member
    I put 300K on my '93 and still had at least half of the original shoes left. Unless you wear a brake shoe all the way down to the metal and drive it like that until it's grooved, your original drums should last a long long time. It's theoretically possible if you overheated the drums then immediately parked with the parking brake on full, it *might* be possible to warp the drums requiring replacement, but that scenario is a long shot. And, btw, they're made out of cast iron, not any variant of steel. Cast iron, just like your skillet.
  7. Dec 11, 2019 at 11:07 PM
    Waasheem
    Waasheem
    2007 xrunner
    Just like rotors, drums can be turned when replacing shoes. They’ll tell you when you bring them in if they’re worn too much and need replacing. I’m guessing they can be cut two or three times before they need replacing.
    Personally, I don’t like to cut them unless they’re grooved. If I don’t cut them, and they look glazed, I’ll rub them with emery cloth.
    Yes the braking surface has to be oil free and clean. Shop rags are oily so I use clean paper towels and brake cleaner.
    I like to pull the rubber boot back on the slave cylinders, if I find brake fluid in there I replace them.
    If you plan to do a drum brake job, do yourself a favor and do one side at a time and/or take pictures so getting all the springs and pieces back in correctly isn’t a guessing game. There are special tools for drum brakes but it is possible without them.
    If you have a saturated situation the drums can be cleaned, I’ve seen people clean the shoes but I replace them.
    PzTank likes this.
  8. Dec 11, 2019 at 11:30 PM
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    Factory drums are painted/coated and it holds up quite well. Cheap aftermarket stuff isn't, so it gets ugly pretty quickly.
    You can get decent aftermarket coated stuff as well. The dealership should be using factory parts unless you ask for aftermarket or at the very least you have a discussion about it.
    Jeff
  9. Dec 12, 2019 at 6:09 AM
    PennSilverTaco
    Charlie
    I authorized the use of aftermarket parts because they would have had my truck for two days if I’d waited for OEM parts to come in. I had no idea they’d be replacing the drums and did not realize they had until like a day after I brought my truck home.
  10. Dec 12, 2019 at 6:21 AM
    PennSilverTaco
    Charlie
    I’m fed up with dealerships in every sense...
    I worked at a dealership for ten months and I hated it. They take advantage of their employees and their customers. When I worked at the dealership, at the detail shop, I started to feel burnt out within the first three months!
  11. Dec 12, 2019 at 6:25 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Although the parts store that you work for may not carry painted drums, they are available - for a little more money. A quick look online will show you a good number of them. Most folks don't worry about whether or not they're painted because the drums are generally hidden behind the wheels and wheel covers. The style of wheels on most Tacomas does not hide the drums though.
  12. Dec 12, 2019 at 8:41 AM
    PennSilverTaco
    Charlie
    So one of my coworkers gave me a $50 Lowe’s gift card. Guess who’s gonna but a second star shower for the house?!?!
  13. Dec 12, 2019 at 8:43 AM
    PennSilverTaco
    Charlie
    My dad’s BMW never broke, but shit like oil and brakes cost more than in the 2003 Honda S2000 the BMW replaced, and more than in the 2008 Acura TL that replaced the BMW...
    shakerhood likes this.
  14. Dec 12, 2019 at 9:06 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    I have not replaced a drum on a rear axle since the 80s and most have gone to 200k + miles
    PzTank likes this.
  15. Dec 12, 2019 at 9:27 AM
    PennSilverTaco
    Charlie
    Taco critter likes this.
  16. Dec 12, 2019 at 11:44 AM
    PennSilverTaco
    Charlie
  17. Dec 12, 2019 at 11:46 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I bet I spent a good 6 or 7 thousand bucks at Lowe's over the past 6 months, gotta quit, lol.
  18. Dec 12, 2019 at 11:53 AM
    PennSilverTaco
    Charlie
    I spent about two grand on Legos over the course of a year...
  19. Dec 12, 2019 at 11:55 AM
    PennSilverTaco
    Charlie
    And my favorite meme of the year, again...
  20. Dec 12, 2019 at 11:56 AM
    shakerhood
    Southern Ohio
    I remember one time on Mythbusters they built a giant boulder out of Lego's and tried to roll it down a hill, lol.
