PennSilverTaco's "Perfect 5-Lug Regular Cab" Build, Aspergers, and General BS MegaThread!
Discussion in '2nd Gen. Builds (2005-2015)' started by PennSilverTaco, Jul 15, 2014.
  1. Dec 14, 2019 at 9:01 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    No They are not. 2 Drawers in there are kind of a weird material so I am planning on having a couple replacements custom built.
  2. Dec 14, 2019 at 9:02 PM
    PennSilverTaco
    PennSilverTaco [OP] Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    Get dovetail! And granite countertops! Is your stove propane?
  3. Dec 14, 2019 at 9:06 PM
    shakerhood
    Southern Ohio
    No its an electric stove, propane is only for the furnace. Really want some kind of heat source in the garage, way too damn cold in there, thinking one of those electric units I showed you before.
  4. Dec 14, 2019 at 9:08 PM
    PennSilverTaco
    Charlie
    You want a gas stove...
    What year was the house built and was it originally a heat pump?
  5. Dec 14, 2019 at 9:11 PM
    shakerhood
    Southern Ohio
    I am happy with the electric stove, it works fine. This place was renovated back in the late 80s or early 90's, probably had a wood stove originally, lol.
  6. Dec 14, 2019 at 9:12 PM
    PennSilverTaco
    Charlie
    No central air originally? Obviously it was not built in 1993...
  7. Dec 14, 2019 at 9:13 PM
    shakerhood
    Southern Ohio
    Right, I highly doubt it had an original AC.
  8. Dec 14, 2019 at 9:15 PM
    shakerhood
    Southern Ohio
    I have a generator for power outages, its a bit of a pain running extension cords so on my to do list is to have a transfer switch installed.
    PennSilverTaco[OP] likes this.
  9. Dec 14, 2019 at 9:15 PM
    PennSilverTaco
    Charlie
    Unless it was a heat pump; My dad's friend in Cincinnati has a house that was built in the late 1980s and I believe it has a heat pump. From what I've seen in houses for sale online, electric heat is common in Ohio...
  10. Dec 14, 2019 at 9:17 PM
    shakerhood
    Southern Ohio
    Yeah no chance this place had a heat pump, most places around here use propane for heat but there is one very small community that has natural gas.
  11. Dec 14, 2019 at 9:21 PM
    PennSilverTaco
    Charlie
    When your house has a heat pump...
    And outside...
  12. Dec 14, 2019 at 9:24 PM
    shakerhood
    Southern Ohio
    The heat pump sounds too expensive for me with not enough positive benefits.
  13. Dec 14, 2019 at 9:25 PM
    PennSilverTaco
    Charlie
    By itself, yes...
    But with propane backup you'll save money!
  14. Dec 14, 2019 at 9:28 PM
    shakerhood
    Southern Ohio
    I don't know if I would ever see a return on investment, with the current ancient system I spend about $1000 - $1200 per year on propane and I expect that number will go down with a more efficient furnace.
  15. Dec 14, 2019 at 9:29 PM
    PennSilverTaco
    Charlie
    Get your technician to give you a quote on a heat pump/gas furnace version of that same Rheem system, just to humor me...
  16. Dec 14, 2019 at 9:36 PM
    shakerhood
    Southern Ohio
    The "Heat" part of the 2 systems is far more important to me as I am always cold plus it sounds like a back up for a heat pump is needed, I would assume a heat pump would probably be about double in cost up front.
  17. Dec 14, 2019 at 9:41 PM
    shakerhood
    Southern Ohio
    Seems like I would be dipping into the backup frequently thus eliminating most of the savings.
  18. Dec 15, 2019 at 6:21 AM
    disconnected
    disconnected LOST
    Greg
    Pittsburgh
    19 TRD Off-Road
    Icon 2,5'' coilovers and rear springs, RCI full skids, caliraised sliders, Warfab hitch skid, UpTop roof rack, kb voodo bed rack, Diode Dynamis Pro fogs, Seat Jackers with Molle, taco garage mounts..... and other stuff
    What’s everyone doing today?!
  19. Dec 15, 2019 at 9:20 AM
    PennSilverTaco
    Charlie
    @ColoradoTJ
    @El Duderino
    @shakerhood
    I've been thinking...
    All producers of milk seem to use the same design of gallon milk jugs; Can you imagine how much the inventor of the modern gallon milk jug must be making?!?!
    El Duderino likes this.
  20. Dec 15, 2019 at 9:36 AM
    shakerhood
    Southern Ohio
    It is an efficient design.
