PennSilverTaco's "Perfect 5-Lug Regular Cab" Build, Aspergers, and General BS MegaThread!
Discussion in '2nd Gen. Builds (2005-2015)' started by PennSilverTaco, Jul 15, 2014.
  1. Feb 18, 2017 at 7:11 PM
    #2501
    LuckyToy
    LuckyToy Well-Known Member
    4x4 Offroad
    Anyone compared crash ratings between Tacoma and Ridgeline?
  2. Feb 18, 2017 at 7:12 PM
    #2502
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    It's a nice SUV, not a truck.
    PennSilverTaco[OP] likes this.
  3. Feb 18, 2017 at 7:13 PM
    #2503
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    What? The frame was bowed at the rear axle and bed mashed into the cab. The bloody AC system was the last thing on my mind at that point. Of course I lived in Washington at the time and AC was used as often as sunscreen.
  4. Feb 18, 2017 at 7:14 PM
    #2504
    4x4Runner
    Drunken Sailor
    1WD
    nuttin fancy
    And the opinions keep pouring in.
  5. Feb 18, 2017 at 7:46 PM
    #2505
    NM Lance
    NM Lance Well-Known Member
    Just open the tailgate and let it blow all over the highway. I don't even let that crap bother me anymore.
  6. Feb 18, 2017 at 7:51 PM
    #2506
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    I figured out how to get people to not use my bed as their trash can. Don't shop at Wal-Mart. :rolleyes:
    techbill likes this.
  7. Feb 18, 2017 at 8:50 PM
    #2507
    PennSilverTaco
    PennSilverTaco [OP] Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    If what happened to your truck happened to mine, I would be pissed if the insurance company fixed it. What I'm saying is that if I was involved a moderate wreck where there was damage to the A/C condenser but there was no structural damage and the truck was safe, I would still be worried that my A/C would leak...
    One of my favorite things about my Tacoma is that summer after summer, I turned on the A/C and it always blows cold...
  8. Feb 18, 2017 at 9:53 PM
    #2508
    2.7taco
    2.7taco Well-Known Member
    Texas
    2005 Tan Tacoma Base 5 LUG: Beaten , abused and still running strong.
    Fat Bobs 2.75 lift and level with short AAL, 16x8 Level 8 Guardian Wheels, 245/75R16 Toyo Open Country ATII, custom trans shift kit(home made), Trans temp. and Vac gauge, URD fuel pump upgrade(going back to stock soon).
    I'm on the same transmission. Feels about as strong as it was when I got the truck pre-owned at 20k. I've dropped the pan 3 times to clean out and inspect the transmission condition. During one of those times I installed some spacers to hydraulically alter the shift speed by reducing the accumulators ability to cushion the shift. The A340E has been around forever and used by everyone it has different names example in Jeeps it's known as an AW4.
  9. Feb 18, 2017 at 11:45 PM
    #2509
    TRVLR500
    TRVLR500 Well-Known Member
    Wyoming
    Tacoma SR5 4X4 2.7 4CYL
    There are a lot of 2.7's out there with well over 200,000 miles with nothing but routine maintenance. From what I have read they are just as good as the 2.4. Mine has 155,000+ on it and other than a water pump and a battery replaced under warranty when my dad (the original owner) had it I have done very little other than replacing my suspension. It does need a tie rod replaced but the play is very minimal at this point. Almost non-existent. I'm going to replace all the tie rods this summer. I already bought them from Toyota. I replaced the headlight housings also with factory Toyota housings because of the ridiculous plastic lenses used on every vehicle these days. I would have just polished them but I broke the tab off that retains the retaining clip for the bulb on the passenger side and so once I bought the new housing for the passenger side I figured I'd get a new driver's side as well since the plastic lens was all fogged up from oxidation like they all do. Then I applied about 50 coats of liquid glass to them hoping that will stall future oxidation of the cheap assed plastic lenses. There really should be a law against using plastic lenses for headlights. I drove a 1973 Cadillac Coupe DeVille for 18 years as my only car until I got this Taco and I replaced the headlights once. That was the best damn car I ever owned and I have owned many over the decades. So far, this Taco has already eclipsed the Caddy and I hope it will continue to do so. Maintenance wise. The Taco or any other car these days fails in comparison to the joy and sound of a huge V8 and the way an old Caddy floats down the road at 90 mph. I had to spend a whole lot of my time doing maintenance on the Caddy that I don't have to do on the Taco but that was just because of older engineering.
    I also replaced the suspension with OME 880's up front, Deaver J59's leafs in the rear and Nitrochargers all the way around which is normal for anyone who owns one of these trucks. The stock suspension sucks right from the show room floor but this one had 125,000 on it when I did that. My dad drives so slow he never even noticed how bad the suspension sucked. This Taco never even saw 3000 rpm until I got it at 119,000 miles. Other than that everything is still just as it was from the factory when new. I did replace the belts which I probably didn't even have to replace but I'm a maintenance freak when it comes to my vehicles. I like to replace things I even "think" might fail before I get stranded. Which is why this summer I will also replace the starter even though it works just fine. It is 13 years old after all. Well, I will at least buy one from Toyota and have it sitting here just in case. Having a break down along with a tow bill where I live in a winter blizzard is something I'd rather avoid. At least if it happens I don't want to wait for a new part since this is my only vehicle at this time and when it comes to electrical parts I spare no expense since I've been screwed so many times trying to save money on cheap aftermarket parts on other vehicles over the years. Laying on your back on the side of the road replacing an alternator or a starter in a parking lot to avoid a tow bill isn't my idea of fun. My truck gets nothing but Toyota parts so far and as long as I can afford them that's what it will get. Those two headlight housings cost almost $400.
    I've actually had my local Taco dealer talk me out of buying parts I wanted to replace prematurely. Almost everything I asked them about got a response of, "That part is good for the life of the vehicle". At 155,000 I guess the "life of the vehicle" isn't over yet. I have a Gen 1 4X4 5 speed manual and from what I have read 300,000 miles with the 2.7 is almost routine. I expect to go at least 250,000 before I have to start worrying about anything major. Mine idles rough when it's cold but I suspect I just need to clean the IAC or maybe even replace it and none of that may even be necessary since it only idles rough in the winter. I suspect it just needs a grille cover to get the engine temp up over 180 degrees so the computer and emissions systems work properly. I already bought the grill cover but it's been so cold outside I'll wait until summer to install it to raise the running temp when it gets really cold. Another winter below 180 degrees isn't going to kill it I don't think.
  10. Feb 19, 2017 at 3:39 AM
    #2510
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    I have the tyger cover from Amazon. It's a tri fold and I think I paid less than $200 for it.
  11. Feb 19, 2017 at 4:01 AM
    #2511
    OhioTaco68
    OhioTaco68 John 3:16
    Central Ohio
    16' Tacoma SR5 4x4 access cab Silver Sky Metallic
    AVS in channel window deflectors Predator steps Tinted front windows De-badged all chrome emblems Matte black tailgate lettering Matte black door badges Silver door sill lettering Weathertech mud guards Tacoma bed mat Interior LED lighting Lamin-X yellow fogs Hyper yellow DRL LED 3rd brake light bulbs CLEARZ 3rd brake light lens LED back up lights Access LITERIDER tonneau cover Console cover w/Toyota logo Hondo radio knobs NeoSupreme seat covers TRD shift knob Toyota Dark Satin Alloy wheels Toyo Open Country AT3 tires Red glovebox lettering Red vent rings/ control knobs Husky all weather mats Toyota bed mat
  12. Feb 19, 2017 at 4:02 AM
    #2512
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    25 Crosstrek Premium CVT (first ever automatic!)
    Years ago when i bought my access le, truckalterations.com had a special tacomaworld discount page for members. The prices couldnt be beat, and he has them drop shipped from the manufacturer. I think i had mine at my door about 2 days after i ordered. Cant find the specific page at the moment though.
  13. Feb 19, 2017 at 4:04 AM
    #2513
    OhioTaco68
    Central Ohio
    ^ I just posted the link above :thumbsup:
  14. Feb 19, 2017 at 4:55 AM
    #2514
    Doublecross
    Doublecross Well-Known Member
    Robbie
    New york
    Work in progress
    ARE cap, wade inchannel vent visors, weathertec floor mats, ranch hand grill guard, tuffy security boxes in bed, lockable tailgate handle. Still have stuff that needs to be installed and still have stuff ordered lol.
    Not be a wise a** or anything but alot of vehicles dont come with ashtrays or cigerette lighters anymore nowadays its an option
  15. Feb 19, 2017 at 5:17 AM
    #2515
    MarX
    MarX Hotdogs, spam and skittles.
    Mark
    NE Kansas
    2013 DCLB Tacoma TRD sorta Sport 4X4, 2009 Tundra SR5 workhorse
    RETRAX bed cover, Tailgate lock, TRD exhaust. 887's, LR UCA'S, Bilstein 5100's and Deavers AAL.
    I've got a Retrax but it's not cheap though. It locks rolls on bearings and will last the life of the truck. Due to moving regularly I needed to be able to secure my stuff between residences as well as a lot of other work too. I use to have a guy throw trash in the bed of my previous truck back in the day. I grabbed as much trash as I could one day and filled his up lol. He got the hint lol
    zackst and PennSilverTaco[OP] like this.
  16. Feb 19, 2017 at 5:36 AM
    #2516
    BDL5589
    BDL5589 Well-Known Member
    NE Georgia
    '14 MGM 4WD RC
    As someone who has owned a 22RE in a '92 pickup, I still don't know what the hype is. I sold the truck with 220k on it but it had needed more "maintenance" to get there than any other vehicle I ever had. Valve adjustments, timing chain eating the guides, a blown headgasket, etc. plus no power and mediocre fuel mileage doesn't add up to legendary status people give them.
    I like my new 2.7 much more but can't speak to long term reliability yet. Just broke 33k.
  17. Feb 19, 2017 at 5:44 AM
    #2517
    evansdmax
    evansdmax Well-Known Member
    Evan
    Western NC
    2017 TRD OR BBP 6 SPEED MT
    In the same boat I've had 3 94 pickups before my 06 they are 100k mile motors and need timing chain water pump and all that..... more times than not they need a full rebuild!!! I bought 2 of the 3 I owned knowing they needed rebuilt and did it myself parts are cheap for the 22.... my 2.7 runs smoother and with 140k I hope to drive it well over 250 with not many problems
    Mush Mouse likes this.
  18. Feb 19, 2017 at 6:15 AM
    #2518
    PennSilverTaco
    Charlie
    My truck did not come with ashtray and I somehow managed to break the cigarette lighter LOL. The outlet still works but I broke the actual lighter element...
  19. Feb 19, 2017 at 6:19 AM
    #2519
    PennSilverTaco
    Charlie
    Same one who is de facto head of security at the bar where I work...
    Instead of actually using a certain really vulgar word...
    C-U-Next-Tuesday
    He told me about some guy who showed up drunk and started abusing his ex-girlfriend right there in front of the bar, and instead of actually using the C-word, this is what he said...
    Bouncer's like, "He called her a C-U-Next-Tuesday and then things kinda went downhill from there."
    Dunkle likes this.
  20. Feb 19, 2017 at 7:31 AM
    #2520
    PennSilverTaco
    Charlie
    I went outside to bring in the garbage and this 20-year old guy who'd just been dishonorably discharged from the Air Force comes running up my driveway saying people are after him and he needs to hide...
    This is a true story, and it's long, but I'll let you just ask questions...
    Ask whatever the hell you want... You can't make this shit up...
