PennSilverTaco's "Perfect 5-Lug Regular Cab" Build, Aspergers, and General BS MegaThread!
Discussion in '2nd Gen. Builds (2005-2015)' started by PennSilverTaco, Jul 15, 2014.
  1. Jan 2, 2020 at 8:53 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I think my unit is just old as I have to set it higher each year to keep the room temperature at 70, so far this year that requires me setting it at 74 - 75.
  2. Jan 2, 2020 at 8:54 PM
    PennSilverTaco
    PennSilverTaco [OP] Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    And I'm telling you...
    GET A HEAT PUMP! It will save you money on propane! A heat pump with propane furnace backup is a great system!
    shakerhood[QUOTED] likes this.
  3. Jan 2, 2020 at 8:55 PM
    shakerhood
    Southern Ohio
    I will find out what brand she is getting the next time I talk to her.
  4. Jan 2, 2020 at 8:57 PM
    PennSilverTaco
    Charlie
    Under $5K, it's probably one of these turds...
    Nordyne...
    Or Goodshit, I mean Goodman...
  5. Jan 2, 2020 at 9:00 PM
    shakerhood
    Southern Ohio
    I will make sure I let you know when I find out.
  6. Jan 2, 2020 at 9:02 PM
    PennSilverTaco
    Charlie
    I'm saying that you should get a heat pump in addition to a propane furnace...
    However, while it is okay to run electric backup heat at the same time as a heat pump, do not run the furnace simultaneously along with the heat pump or else the refrigerant will get superheated, the system will overheat, and something like this could happen...
    https://www.youtube.com/watch?v=9eTbFqkVdQc
  7. Jan 2, 2020 at 9:05 PM
    shakerhood
    Southern Ohio
    Yeah, it seems much easier for me to just stick with whatever that furnace guy has written for me.
  8. Jan 2, 2020 at 9:12 PM
    PennSilverTaco
    Charlie
    By the way, I was exaggerating there; Yes that is a central A/C unit that's actually on fire, but I don't know if it's a heat pump or just a straight-cool unit, or even what caused the fire...
    I doubt that running a gas furnace simultaneously with a heat pump will cause it to spontaneously combust; However, if you have a dual-fuel system with the indoor coil above the furnace, running both simultaneously will cause serious damage to the heat pump. When a heat pump is in HEAT mode, the refrigerant is hot. If there is a gas furnace blasting heat on the coil, the refrigerant will become even hotter and basically cook the whole unit!
  9. Jan 3, 2020 at 5:27 AM
    El Duderino
    El Duderino Obviously, you're not a golfer.
    Jeremy
    HI->PNW
    19 nautical blue SR5 premium 4x4
    Stuff, things, this, an ADS
    Half way down to Doylestown.
    PennSilverTaco[OP] likes this.
  10. Jan 3, 2020 at 5:31 AM
    PennSilverTaco
    Charlie
    Nice! When would be a good time to meet up for a beer?
    @BuxTaco17 bartends at the place I was telling you about!
  11. Jan 3, 2020 at 6:10 AM
    PennSilverTaco
    Charlie
  12. Jan 3, 2020 at 7:17 AM
    PennSilverTaco
    Charlie
  13. Jan 3, 2020 at 9:29 AM
    PennSilverTaco
    Charlie
    Junkhead likes this.
  14. Jan 3, 2020 at 9:47 AM
    PennSilverTaco
    Charlie
    I did not know that Black & Decker made 4-wheel drive Dustbusters!
  15. Jan 3, 2020 at 9:49 AM
    shakerhood
    Southern Ohio
    She said the guy is supposedly coming this weekend and doesn't know the brand yet other than he said something about a merger or someone building the system under another brand name. She also said that she told him that she would prefer Trane or American Standard so we will see what he brings.
  16. Jan 3, 2020 at 9:50 AM
    PennSilverTaco
    Charlie
    What did he quote her? Less than five grand? Ain't gonna be no Trane or American Standard!
  17. Jan 3, 2020 at 9:52 AM
    shakerhood
    Southern Ohio
    Yeah he definitely quoted her under five, I told her not to get either of the 2 you listed.
  18. Jan 3, 2020 at 9:53 AM
    PennSilverTaco
    Charlie
    This would be me after seeing your ex's electric bill during the winter...
  19. Jan 3, 2020 at 9:57 AM
    shakerhood
    Southern Ohio
    She is convinced that it's going to save her thousands, I told her to just keep her expectations in check.
  20. Jan 3, 2020 at 9:58 AM
    PennSilverTaco
    Charlie
    By getting a heat pump she will definitely save thousands. That meme is in reference to her current heating system!
