PennSilverTaco's "Perfect 5-Lug Regular Cab" Build, Aspergers, and General BS MegaThread!
Discussion in '2nd Gen. Builds (2005-2015)' started by PennSilverTaco, Jul 15, 2014.
  1. Jan 23, 2020 at 6:19 AM
    PennSilverTaco
    PennSilverTaco [OP] Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    I was going to tell John if his house has oil heat, that he should get heat pumps to cut back on fuel costs...
    What brand of heat pump does your new house have? Also, why does your new house have gas heat but an electric stove? I've lived in three houses that had natural gas heat but an electric stove; I've never lived in a house with propane heat.
    Taco critter likes this.
  2. Jan 23, 2020 at 6:19 AM
    PennSilverTaco
    Charlie
    You should get heat pumps if you go with the ductless mini-splits; They can really save you money over oil when it's above 35 degrees or so.
  3. Jan 23, 2020 at 6:24 AM
    PennSilverTaco
    Charlie
    Your house was built in like 1910?
    You know how I used to work at bar called Puck? Well, I'm still technically employed there, just furloughed...
    Anyway, the owners of Puck have this beautiful house right in the borough that was built in 1824! It has been thoroughly modernized inside while retaining the original 1820s feel on the outside; It even has gas-powered lamps at the front door! The house has been retrofitted with three-zone central air, and recently a fourth unit was added!
    shakerhood and Taco critter like this.
  4. Jan 23, 2020 at 6:26 AM
    PennSilverTaco
    Charlie
    The 4th unit is a builder-grade Bryant, only a 1.5-ton (18,000 BTU), installed for an addition they made a couple years ago. The house also a 1996 Rheem, and two big old 1980s York Stellar series units...
  5. Jan 23, 2020 at 6:37 AM
    PennSilverTaco
    Charlie
    @Taco critter
    Puck opened in 2005 or 2006, and I’m pretty sure the owners bought the building sometime before that; Employees come and go, and by 2014-2015 it got to the point where I was the only one who knew where the outdoor A/C unit was located!
    Once, on my day off, the heat pump for the basement venue had to be serviced; I got a text from the owner of the building (this really nice woman in her 60s) asking me where the outdoor unit was because the tech couldn’t find it! I immediately told her where the unit was and the tech was able to service...
  6. Jan 23, 2020 at 6:38 AM
    El Duderino
    El Duderino Obviously, you're not a golfer.
    Jeremy
    HI->PNW
    19 nautical blue SR5 premium 4x4
    Stuff, things, this, an ADS
    No clue your guess is good as mine. Also I don’t even know how to turn on a furnace let alone remember what brand it is. I have a lot to learn about living in seasons lol
  7. Jan 23, 2020 at 6:40 AM
    PennSilverTaco
    Charlie
    All you have to do is set the thermostat to heat and the furnace will turn on. In more mild temperatures, the heat pump will turn on; below freezing (maybe more like 35-38 degrees) or when the heat pump is defrosting, the furnace will kick in...
  8. Jan 23, 2020 at 6:42 AM
    PennSilverTaco
    Charlie
    I’m guessing that in Oregon, the A/C will be used more to filter allergens and pollen because it rarely gets that hot there...
  9. Jan 23, 2020 at 7:16 AM
    PennSilverTaco
    Charlie
    According to the Lennox website, the efficiency-based regional install thing doesn't seem to apply to heat pump versions of the same models; This is more than likely because all heat pumps are a tad less efficient than the straight-cool A/C version of the same unit and are thus exempted for this reason. The least efficient brand new heat pumps I've ever seen since about 2013 were rated at 13 SEER and 7.7 HSPF; The most efficient Lennox heat pump available today, right here and right now, is rated at "up to 23.5 SEER" and "up to 10.2 HSPF". My friend Doug's parents' Bryant Evolution Series (which I picked out) was installed in June 2010 and was rated at 16 SEER and just shy of 9 or 10 HSPF when it was new.
    shakerhood likes this.
  10. Jan 23, 2020 at 7:20 AM
    PennSilverTaco
    Charlie
    Any heat pump manufactured prior to 1992, unless it is a super high-end model, is going to be less than 10 SEER and about 5 or 6 HSPF; Even a top-of-the-line heat pump from almost three decades ago will likely be less efficient than the cheapest and most inefficient heat pump available today due to the following factors...
    • Age
    • Wear and tear
    • Neglect
    • Advances in technology
    Any air-conditioner or heat pump from 1992 or later is going to be at least a 10 SEER, and any unit from January 2006 or newer is going to be at least a 13 SEER. When replacing a unit that is 13 SEER or less, the only way to see a noticeable reduction in your utility bill is to replace that unit with one of at least 16 SEER.
  11. Jan 23, 2020 at 8:32 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Funny you posted that as I noticed a unit just like that at Lowe's the other day, it looked like it had the guts in it too.
  12. Jan 23, 2020 at 11:25 AM
    PennSilverTaco
    Charlie
    Your unit is proof that Lennox builds good products; I believe we established that yours is from 1993...?
    The oldest working Lennox central air-conditioner I have ever seen was a 1969 model installed at my ex-girlfriend's parents' house; It died in a 2014 or 2015 I believe and was replaced with a base model Lennox unit under their homeowner's insurance policy. I guarantee you that new Lennox will not last anywhere near five decades like the one it replaced!
    shakerhood[QUOTED] likes this.
  13. Jan 23, 2020 at 2:01 PM
    PennSilverTaco
    Charlie
    At the gym...
    Not warm at all, but tolerable enough that I can be outside in a T-shirt and gym shorts!
  14. Jan 23, 2020 at 2:18 PM
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals Diode Dynamics HP5 Third brake light LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Tonneau Cover (Truxedo Roll Up) KB voodoo bed bars Pelican Vault (for gear) LED interior lighting Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear) (18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap AC drip line mod Anti Tweeker tailgate lock
    Less girls, more trucks
  15. Jan 23, 2020 at 2:19 PM
    PennSilverTaco
    Charlie
    I’ve posted plenty of truck pictures on this forum!
  16. Jan 23, 2020 at 4:45 PM
    PennSilverTaco
    Charlie
    @Kidwidataco
    This started out as a build thread and has a lot stuff about the work done to my truck; It was originally started in 2016 or 2017, but it has been backdated to my join date of 2014 because the mods merged my "new member intro" into it...
  17. Jan 23, 2020 at 5:40 PM
    PennSilverTaco
    Charlie
    I figured I'd continue this discussion about the greatest drama series ever (and greatest show about the mafia ever), here; This way I don't clog up the other thread with off-topic BS...
    Christopher Moltisanti (one of my favorite characters on the series and also quoted in my signature) drove a beautiful 1997 Lexus LS400 for the first season and a half or so of the series...
    The pilot episode was filmed in 1997, but the other twelve episodes were filmed in 1998 or 1999; The Lexus is implied to be brand new in the pilot episode, which despite being filmed in 1997 can be assumed to take place in 1999. When talking to his psychiatrist, Tony says "and this is a kid who just bought himself a $60,000 Lexus" but does not say whether it was new or not...
    The screenshot above was taken from Season 1/Episode 8, "The Legend of Tennessee Moltisanti"
  18. Jan 23, 2020 at 5:44 PM
    PennSilverTaco
    Charlie
    IMCDb lists Christopher's Lexus as a 1997 model, so it is possible he bought it used in 1999, but I don't think a used '97 LS400 with even ridiculously low miles would cost sixty grand in 1999 (Isn't that what they cost new?). The screenshot below is of Christopher's Lexus in the pilot episode, which as stated above was filmed in 1997. You will notice that the car does not have larger chrome wheels seen in later season 1 episodes, and is also wearing a different license plate; The damage seen on the front left corner of the car is the result of Tony using the car to run down a guy who owned him and Christopher money from gambling debt...
    I think it looks better with the chrome wheels...
  19. Jan 23, 2020 at 5:51 PM
    PennSilverTaco
    Charlie
    By 2000, Chris had gotten rid of the Lexus and bought himself a 1999 Mercedes CLK430; This screenshot is from the season 3 episode where he got made...
  20. Jan 23, 2020 at 5:59 PM
    PennSilverTaco
    Charlie
    He owned the Mercedes from 2000 until 2001, and bought himself a new Ranger Rover in after getting made in this same episode; IMCDb lists the Range Rover as a 2000, but the episode takes place in 2001 and the SUV is shown with a Monroney sticker, so it's probably intended to be a new '01 model...
    Chris was implied to have paid cash for the Ranger Rover, but it was a lot for him and he ended up owing fellow mobster Paulie Walnuts significant money from a sports book, which he could not immediately pay back because he'd blown his money on the Ranger Rover. Chris was shown to have significant drug and alcohol habit for most of the series, and this Range Rover was carjacked by drug dealers maybe a year and a half at most after Chris bought it (Season 4, in 2002); The Range Rover was never to be seen again, and I'm guessing that Chris's insurance more than likely paid out...
