PennSilverTaco's "Perfect 5-Lug Regular Cab" Build, Aspergers, and General BS MegaThread!
Discussion in '2nd Gen. Builds (2005-2015)' started by PennSilverTaco, Jul 15, 2014.
  1. Feb 9, 2020 at 8:14 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Oh wow, that sucks! The one I have in there now does MP3's and USB drive so am pretty pleased with it.
  2. Feb 9, 2020 at 8:15 PM
    shakerhood
    Southern Ohio
    Right, im not drilling any holes though, it would have to be a way that doesn't require that.
  3. Feb 9, 2020 at 8:16 PM
    PennSilverTaco
    PennSilverTaco [OP] Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    I've learned to live with it; Doesn't happen that often, and tends to happen more when it's cold out; That stereo has more memory than my parents' first computer and is probably a lot more complex!
    shakerhood[QUOTED] likes this.
  4. Feb 9, 2020 at 8:17 PM
    PennSilverTaco
    Charlie
    My truck required absolutely no drilling to install the backup camera; Pull off the rear license plate and see what's back there...
    Have you ever seen a fox body with a backup camera?
  5. Feb 9, 2020 at 8:18 PM
    shakerhood
    Southern Ohio
    My car has a strange little Coaxial Box at the very top of the rear glass. The Original Owner was a fire fighter and had some kind of equipment mounted back there, I removed all the cable but the box has to stay.
  6. Feb 9, 2020 at 8:19 PM
    PennSilverTaco
    Charlie
    I honestly believe that there's a loose connection and not anything actually wrong with the radio, but I haven't had the time to tear the dash apart to get back there!
  7. Feb 9, 2020 at 8:19 PM
    PennSilverTaco
    Charlie
    Why?
  8. Feb 9, 2020 at 8:19 PM
    shakerhood
    Southern Ohio
    I take the license plate off every year to clean and wax under there, there is really no area above it either.
  9. Feb 9, 2020 at 8:20 PM
    PennSilverTaco
    Charlie
    If you put a rubber grommet in place, it would keep water out if you had to drill; They also make wireless backup cameras.
  10. Feb 9, 2020 at 8:21 PM
    shakerhood
    Southern Ohio
    It is permanently mounted back there, I will have to take a picture some time.
  11. Feb 9, 2020 at 8:22 PM
    shakerhood
    Southern Ohio
    There is no area above the plate though.
  12. Feb 9, 2020 at 8:22 PM
    PennSilverTaco
    Charlie
    Does your current radio have Bluetooth? Sounds like all you really need are speakers? You can actually make it sound good without a sub; An external amp is more important!
  13. Feb 9, 2020 at 8:23 PM
    PennSilverTaco
    Charlie
    They make wireless ones that show up on your phone or in a special rearview mirror...
  14. Feb 9, 2020 at 8:23 PM
    shakerhood
    Southern Ohio
    I cant remember if it has bluetooth, honestly I rarely use it in my truck as cell service is sketchy around here.
  15. Feb 9, 2020 at 8:25 PM
    shakerhood
    Southern Ohio
    Right if I ever decide to do something like that I would stick with something wireless but still have no place to put a camera in the rear.
  16. Feb 9, 2020 at 8:26 PM
    shakerhood
    Southern Ohio
    The factory amp was quite small but since there is no empty interior spaces they had it mounted in behind the stereo.
  17. Feb 9, 2020 at 8:26 PM
    PennSilverTaco
    Charlie
    You don't need space; With wireless it's integrated into your your license plate frame!
  18. Feb 9, 2020 at 8:27 PM
    PennSilverTaco
    Charlie
    There's got to be some way to put a full system in a Mustang hatchback with a factory sunroof!
  19. Feb 9, 2020 at 8:28 PM
    shakerhood
    Southern Ohio
    Im not sure a license plate frame would even fit, there is literally zero space above the license plate, maybe the thickness of a quarter.
  20. Feb 9, 2020 at 8:32 PM
    shakerhood
    Southern Ohio
    You would have to hang something off the ceiling if you want the sunroof space.
