PennSilverTaco's "Perfect 5-Lug Regular Cab" Build, Aspergers, and General BS MegaThread!
Discussion in '2nd Gen. Builds (2005-2015)' started by PennSilverTaco, Jul 15, 2014.
  1. Apr 3, 2020 at 11:18 AM
    PennSilverTaco
    PennSilverTaco [OP] Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    Over the last couple of weeks, my head unit has been having problems...
    It is a Pioneer AVH-1330 NEX, installed in March 2018; It has been known to randomly reboot itself at times, but nothing like this!
    The speakers are powered by an external amplifier, so if the amp cuts out there is no sound. It has been doing this a lot lately, but some days it won’t do it at all. The radio will still be on, and the subwoofer will still be thumping, but the sound will cut in and out or there will be no sound at all.
    It seems to do this not when the iPod is playing, but it also does this when the radio is on.
    The Bluetooth will not work at all; The radio recognizes my phone, but I can’t hear the person on the other and they can’t hear me.
    My neighbor hooked up his voltmeter to the battery, the amp, and the back of the radio, as well as the alternator, and found no problems.
    My radio was also having a weird problem where a little purple square with a volume symbol and a minus sign would appear in the upper left corner of the screen; The volume would inexplicably lower and controls like the EQ would be locked out, preventing me from using them.
    My head unit (again, the Pioneer AVH-1330NEX) is no longer made, but I found a refurbished one on Amazon for $240. My dad told me that if my radio is failing, I shouldn’t buy the exact same model. A new Pioneer would be nice, but they cost a lot; I do not want to get a different brand because that would require changing out the wiring harness which is something I’m not that good at...
  2. Apr 3, 2020 at 12:25 PM
    PennSilverTaco
    Charlie
    Radio is shot; Bluetooth does not work and as I stated before, something within the head unit is causing the amp to overload. Getting a Pioneer AVH-1550NEX, so it’ll be a drop-in replacement.
    shakerhood[QUOTED] likes this.
  3. Apr 3, 2020 at 12:25 PM
    El Duderino
    El Duderino Obviously, you're not a golfer.
    Jeremy
    HI->PNW
    19 nautical blue SR5 premium 4x4
    Stuff, things, this, an ADS
    That’s not good news
  4. Apr 3, 2020 at 12:27 PM
    PennSilverTaco
    Charlie
    Not the worst; $345 MSRP and I’m getting it for $280!
  5. Apr 3, 2020 at 12:36 PM
    El Duderino
    Jeremy
    HI->PNW
    Nice. How many days wait? How’s your dog doing?
  6. Apr 3, 2020 at 12:41 PM
    PennSilverTaco
    Charlie
    Next Wednesday; Porter’s doing great!
  7. Apr 3, 2020 at 12:52 PM
    dolbytone
    dolbytone Well-Known Member
    South Carolina
    09 TRD Off Road
    Runnin' home to mamma...
    Verify the ground on your amplifier.
  8. Apr 3, 2020 at 1:01 PM
    PennSilverTaco
    Charlie
    The amplifier has been tested...
  9. Apr 3, 2020 at 1:17 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Sucks that you are gonna need a replacement
  10. Apr 3, 2020 at 1:30 PM
    dolbytone
    South Carolina
    09 TRD Off Road
    I notice how you did not say something like:
    "Yeah, I redid the ground and it's all clean and I sanded the grounding point and I'm like super positive it's totally killer."
    Kinda hard to move on this being the case.
  11. Apr 3, 2020 at 3:28 PM
    PennSilverTaco
    Charlie
    Which ground? The one on the amp the or where the system is tied into the battery...? I am 99.9% sure the head unit is the problem because I whacked the dash bezel a couple times when the radio cut out and it started working again...
  12. Apr 3, 2020 at 3:35 PM
    PennSilverTaco
    Charlie
    I've disconnected and reconnected all connections...
    Dialectric grease? Also, this still doesn't explain why the Bluetooth has inexplicably failed!
  13. Apr 3, 2020 at 3:41 PM
    PennSilverTaco
    Charlie
    My phone was last updated several weeks ago; The head unit will recognize my phone but there's no sound, and this has only been in the last couple of weeks.
  14. Apr 3, 2020 at 3:52 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    You’ve pulled the head unit from the dash? Did you connect a regular speaker straight to the HU? Did you connect a different head unit to the amp? Have you tried playing a CD?
    Sounds like you haven’t done much troubleshooting.
  15. Apr 3, 2020 at 3:54 PM
    PennSilverTaco
    Charlie
    How do I do that? I didn't know a radio needed an update unless it has GPS/navigation...
  16. Apr 3, 2020 at 3:55 PM
    Sharpish
    Brian
    Read the owners manual to see why the purple square shows up?
    PennSilverTaco[OP] likes this.
  17. Apr 3, 2020 at 3:56 PM
    PennSilverTaco
    Charlie
    If it does this with radio and iPod, I am 99% it'll do it with a CD. I was thinking of temporarily bypassing the amp and plugging directly to the speakers; The only head units I have lying around are my truck's factory radio (pretty sure it no longer works), a cassette deck from a 1990s Taco (don't know if it works, and an ancient Pioneer CD player from the early 2000s (new in the box and never used, but lacks many of the hookups my unit has), all of which would require extensive wiring to work with the amp.
  18. Apr 3, 2020 at 3:57 PM
    PennSilverTaco
    Charlie
    I haven't seen the owner's manual in two years; Possible it's still in the glovebox, but gonna chat with Crutchfield tech support tomorrow.
    El Duderino likes this.
  19. Apr 3, 2020 at 4:01 PM
    Sharpish
    Brian
    None of it needs extensive wiring. You grab a few cables and start bench testing stuff. Get the cheapest crappiest speaker you can find of any type, get 3 feet of speaker wire and connect it to the speaker outs on the HU. See if you get sound. Plug anything with an RCA connection into the amp and see if you get sound. Even a DVD player with an extension cord. You have to narrow it down.
  20. Apr 3, 2020 at 4:06 PM
    PennSilverTaco
    Charlie
    Can I wire the Pioneer HU to the speakers from my Panasonic shelf system, or one of the Bose speakers from the family room?
