PennSilverTaco's "Perfect 5-Lug Regular Cab" Build, Aspergers, and General BS MegaThread!
Discussion in '2nd Gen. Builds (2005-2015)' started by PennSilverTaco, Jul 15, 2014.
  1. Apr 3, 2020 at 4:08 PM
    Toy4me
    Toy4me Well-Known Member
    Tom
    NNJ
    '10 DCLB TRD Sport MGM
    Why not shoot an email to Pioneer? Rather than being 99% sure of this and that, and whacking the head unit, which is generally not how electronics are repaired, try the manufacturer. Maybe go to their website and and find the owners' manual, sometimes you're only given a basic one in the box and a much more comprehensive one is available online. Look at the troubleshooting section. GL.
    dolbytone and PennSilverTaco[OP] like this.
  2. Apr 3, 2020 at 4:09 PM
    PennSilverTaco
    PennSilverTaco [OP] Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    Currently waiting for a callback from Crutchfield...
  3. Apr 3, 2020 at 4:09 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    How did they wire it into the truck? Did they use crimp connectors?
    PennSilverTaco[OP] likes this.
  4. Apr 3, 2020 at 4:11 PM
    PennSilverTaco
    Charlie
    Butt connectors? My neighbor popped them into place and then shrunk them using a heat gun; Installation detailed in my build thread...
  5. Apr 3, 2020 at 4:14 PM
    0xDEADBEEF
    Yeah, those. It sorta sounds like you may have more than one problem on your hands here - some related to phone/radio software, and possibly others related to wiring. Not that butt connectors are guaranteed to be the issue, but they can certainly give you intermittent faults like this.
  6. Apr 3, 2020 at 4:37 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    Crutchfield won’t be able to solve your problem over the phone, unless it’s something dumb like you’ve pressed the mute button.
    you’re going to have to man up and start deductively troubleshooting to narrow it down. Or take it to someone and pay them to figure it out if you’re not up to it.
    Gus87 and PennSilverTaco[OP] like this.
  7. Apr 3, 2020 at 4:41 PM
    PennSilverTaco
    Charlie
    Actually, the guy at Crutchfield gave me a lot of the same pointers you guys did, including hooking another speaker into the head unit. I'm gonna use one of the speakers from my old Panasonic shelf system. If the radio plays uninterrupted through the Panasonic speaker, then I'll know the problem lies with the amp or one of the speakers.
    0xDEADBEEF likes this.
  8. Apr 3, 2020 at 4:42 PM
    PennSilverTaco
    Charlie
    Butt connectors have never let me down!
  9. Apr 3, 2020 at 4:42 PM
    PennSilverTaco
    Charlie
    As for the Bluetooth, I will replace the head unit if I can't get the Bluetooth to work!
  10. Apr 3, 2020 at 5:03 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    I’ve worked in the car audio/mobile electronics field for nearly 15 years. This issue could be multiple things and could be very complicated. Without looking at it all I could do is offer a few pointers. Do you have a multimeter? This is greatly help figure some things out
    First: the issue with the Bluetooth. Sounds like a software or internal hardware problem. As already stated update your BT device (phone) and see if pioneer has any software updates. If not and the phone is updated, then likely it’s something internal.
    As for the music cutting out while play. You said the radio is staying on and the amp? Does it cut out when the volume is turned up? If so it could be a poor ground (amp) or perhaps the amplifier is going into protect. If it’s going into protection it still could be a grounding issue or you have an impedance problem with your speakers. Check where the amp is grounded. Make sure it’s secure, you can’t move the cable from the mounting point. Also it’s better if the contact area is bare metal. Where exactly is the ground and what is it mounted too. Proper grounding is one of the most important and overlooked issues.
    what kind of amp is it? You said it’s powering the door speakers and a sub? Assuming it’s a multi channel amp 3,4,5 channel? Ohm out all the speakers and check their impedance. Most Coaxles (assuming thats what you have) are 4 ohms. They should all be metering close to that. Next you should meter the sub. You need to find out what the impedance of the voice coil(s) are. Then you need to make sure your amp can handle the final impedance per channel.
    if all that checks out, put the DMM on the power lead at the amp and start the truck. Turn the radio on and put it at where you normally listen to it. Check the voltage and see what it’s all. If the amp is dipping below ~11 volts it will probably temp go into protect, cutting out the sound, but still be “on”. Most new amps have a protection light so if it’s in protection you can easily tell. If the voltage is low check your wiring and fuse. If using a AGU fuse (glass style) a lot of times the solder in the corners heats up and loses contact. The fuse isn’t “blown” but it’s not allowing the current the amp needs. To verify this simply meter the voltage before and after the fuse or just replace with a new one and see if that fixes the issue. I’d honestly recommend just replacing the entire fuse holder to a ANL style. Much better design
    As for the radio randomly rebooting, that could be a few different issues as well. First thing to check or try would be a new or better ground. Also check the voltage on the yellow (constant) and the red (ignition). Should be 12-14v. It more than likely could just be the radio itself. Or something is causing a conflict and it’s just rebooting.
    dolbytone likes this.
  11. Apr 3, 2020 at 5:57 PM
    PennSilverTaco
    Charlie
    Rockford Fosgate amp powering the speakers, and the Kicker sub is “powered” so it has its own amp...
  12. Apr 3, 2020 at 5:59 PM
    PennSilverTaco
    Charlie
    The amp is going into protection when it cuts out; I’ve confirmed this by looking at the amp and the blue light turns to red. The subwoofer switches between blue and red when the amp is “protection”.
  13. Apr 3, 2020 at 5:59 PM
    PennSilverTaco
    Charlie
    Maybe not...
    shakerhood[QUOTED] likes this.
  14. Apr 3, 2020 at 6:00 PM
    PennSilverTaco
    Charlie
    Long-dormant central A/C at a house in Colorado in The Last of Us; This one seems to still be hooked up unlike the ones in Pittsburgh...
    shakerhood likes this.
  15. Apr 3, 2020 at 6:01 PM
    PennSilverTaco
    Charlie
    1971-1972 Chevy C10 at the same house, probably easily restorable...
    shakerhood, Wulf and Taco critter like this.
  16. Apr 3, 2020 at 6:02 PM
    PennSilverTaco
    Charlie
    This mail truck, also in Colorado, is about twenty years late making its deliveries...
  17. Apr 3, 2020 at 6:08 PM
    PennSilverTaco
    Charlie
    Taco critter likes this.
  18. Apr 3, 2020 at 6:12 PM
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
    Hell, I don’t even have a cable subscription, let alone a gaming console.
  19. Apr 3, 2020 at 6:17 PM
    PennSilverTaco
    Charlie
    How does your kid stay entertained? At least you have internet!
  20. Apr 3, 2020 at 6:22 PM
    ColoradoTJ
    Colorado
    Ride bikes, shoot guns, take care of their chickens/cats/dog, hiking, family time, board games...etc.
