PennSilverTaco's "Perfect 5-Lug Regular Cab" Build, Aspergers, and General BS MegaThread!
Discussion in '2nd Gen. Builds (2005-2015)' started by PennSilverTaco, Jul 15, 2014.
  1. Jun 17, 2020 at 9:01 AM
    PennSilverTaco
    PennSilverTaco [OP] Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    Probably wasn’t terribly delicate when new, but keep in mind that the Soviet Union still existed when the furnace wa a manufactured!
  2. Jun 17, 2020 at 9:04 AM
    wrightme43
    wrightme43 Well-Known Member
    Scottsville Kentucky
    17 Double Cab M/T TRD Offroad Blazing Blue Pearl
    Redline custom leather shift and e-brake boot. VFTUNE Super Full Otto cycle, octane learning, premium fuel.
    Ok before you decide you need a engine or mechanical repair. 2 data points do not show much.
    Change brands of oil. Some oils vaporize more than others. Mobil one synthetic doesn't vaporise much.
    Take photo of oil level.
    Drive 1000 miles, park in same spot, take photo of oil level.
    Repeat every 1000.
    Then you will actually know.
    1 quart every 5000 is not crazy oil consumption. 1 quart every 1000 is.
    One needs nothing really, the other needs attention.
    I hope this helps and makes sense.
  3. Jun 17, 2020 at 9:06 AM
    PennSilverTaco
    Charlie
    It actually does! :)
    My truck seems to going through a quarter every 3,000-3,500 miles...
    maxtherat and wrightme43[QUOTED] like this.
  4. Jun 17, 2020 at 9:13 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I found some kind of old GM emblems or stickers down in my garage, I will see if I can find where I put them and I will take a pic.
    Taco critter likes this.
  5. Jun 17, 2020 at 9:22 AM
    wrightme43
    That may be the brand of oil. We got some bulk oil in once, it caused a rash of people complaining about oil consumption. The same time we had hired a Flippin moonbat as the new oil change guy. Were they actually full? Who knows. Was it the oil? Who knows. Changed brands of bulk, and the moonbat quit. Problem just disappeared after testing like above.
    PennSilverTaco[OP] likes this.
  6. Jun 17, 2020 at 10:09 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Charlie....you're really over thinking this. Just try a different oil. I suggested M1 High Mileage 5/30 because it has an excellent additive/detergent package and is on the heavier side of the 5/30 spectrum.
    Anyway....we've had this discussion before. I'm out
  7. Jun 17, 2020 at 10:12 AM
    PennSilverTaco
    Charlie
    And the other mystery is why my gas mileage is so bad...
  8. Jun 17, 2020 at 10:23 AM
    shakerhood
    Southern Ohio
    I had also found gasket sets for Edsel in the garage.
  9. Jun 17, 2020 at 11:00 AM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    Sometimes I think you start these threads to get attention and you don’t actually want to address the “problem.”
    If you’re paying someone to do your brakes you’re probably not mechanically inclined and could strip a plug or something doing a compression check yourself. Replacing the piston rings would cost more than the truck is worth.
    Just drive it and keep an eye on it, there are better things to worry about.
  10. Jun 17, 2020 at 11:49 AM
    PennSilverTaco
    Charlie
    So you’re telling me it would cost about $9,000 to replace the piston rings?
    I most certainly am not doing this just to get attention. This is a fairly recent occurrence with regards to using oil and the last time it happened, I thought it was the result of my mechanic not putting the full 5.5 quarts in last
    time; Turns out that is not the case.
    I know how to change oil, change a tire, etc; I’ve swapped out headlights and taillights and done work on the stereo myself. I also replaced a blend door actuator myself. I just do not feel comfortable working on brakes myself because I’ve never done it before.
    My biggest grievance with my dad’s mechanic is that he charges more than even the dealer on certain things; A perfect example would be PA inspection. Thompson Toyota charges $60 for both emissions and safety, and offers a free loaner car; My dad’s mechanic charges like $70 or $80, obviously does not offer a free loaner, and even has to farm out the emissions part of the test because he’s a small operation and doesn’t have the resources to purchase the $12,000 state-mandated emissions testing machine.
    I am calling MY MECHANIC (Pete) right now to schedule a compression test because he’s considerably cheaper than my dad’s guy; The only reason I went to my dad’s guy is because my guy was booked.
  11. Jun 17, 2020 at 11:54 AM
    PennSilverTaco
    Charlie
    Also, I would prefer to change my own oil, but I live with my parents; Why? I was going to rent a place, but my best friend’s rent has gone up by over $200 per month since he moved there and after seven years he has decided to move back in with his parents so he can (A) save up for a condo or townhouse, and (B) pay off his new SUV early. I have decided to skip renting entirely and save up for my own place.
    Anyway, my dad hasn’t changed his own oil since like 1992 (at 3 years old I was helping him do it); He is afraid I’ll spill oil in his garage.
    I buy six quarts of Mobil 1 for like $40 and then my mechanic Pete charges like $12 or $14 for the filter and labor...
  12. Jun 17, 2020 at 11:58 AM
    PennSilverTaco
    Charlie
    They don’t make ‘em like they used to!
    61DDC486-1A02-4D70-832B-BD70F8BC578D.jpg 690948C6-1802-44BB-A1A9-4EDD8CE5ABBC.jpg 8072C1D0-D3F0-454C-9C96-A3187F842F1E.jpg 95E9D2BC-A989-4A3A-B947-F781ABB20808.jpg 701DED37-4254-49F2-B597-BA6B7DCCB2F9.jpg A6D6F5A8-C9BD-4C7C-BD3F-9E73C01D6E41.jpg AD800958-577D-4375-BBCE-83BD3E3F6CDB.jpg B3CAE977-D6AF-4E66-A4B7-86A52975A1CF.jpg FFFE1058-8BB7-4ABA-895B-A2D06AE94ADF.jpg
    shakerhood likes this.
  13. Jun 17, 2020 at 11:59 AM
    PennSilverTaco
    Charlie
    Do you get to keep and sell for a profit?
    shakerhood[QUOTED] likes this.
  14. Jun 17, 2020 at 12:05 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    no if that's the manufacturers recommended weight oil use it. I think 5w20 can also be used in that engine if 0w20 might not be available
  15. Jun 17, 2020 at 12:08 PM
    PennSilverTaco
    Charlie
    Ive heard that 5W30 will work; That’s what Bill’s older RC used...
  16. Jun 17, 2020 at 12:08 PM
    BillsSR5
    bill
    2014 SR5
    save your truck if you own it, bank loans are almost at 0% APR you can maybe buy a small efficiency apartment instead of renting probably would come at the same as a months renting and eventually youll own it.
  17. Jun 17, 2020 at 12:09 PM
    BillsSR5
    bill
    2014 SR5
    it will work but try to stick with the OEM recommendations
  18. Jun 17, 2020 at 12:16 PM
    PennSilverTaco
    Charlie
    My truck was a gift from my parents when I got my learner’s permit almost 11 years ago! It’s been paid off since 2012 or 2013 and I’ve got a title in my name!
  19. Jun 17, 2020 at 12:20 PM
    BillsSR5
    bill
    2014 SR5
    your 2 steps ahead of most, #1 no truck payments #2 you have probably the most reliable cost effective pick up available
  20. Jun 17, 2020 at 12:28 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    lots of assumptions & guessing
    if it was a head gasket U would definitely have a LOSS of power
    cold or hot
    empty or under load ( grade )
    a consistent compression check between cylinders negates head gasket
    a ' leak down ' test would indicate ring or valve issues
    rare that valve issues cause oil consumption
    switching weight of oil seldom causes loss.................. changing brands or types will
    going from a parafin to an ester
    going from a Dino to a synth will cause issues
    most oil consumption occurs related to rings
    the engine/rings / valves etc are designed & engineered to run
    slow speeds to fast
    idle to red line
    hot to cold
    all present different heat ranges
    ' blow by ' is largely a contribution of rings losing their tensile strength
    particularly in different operating ranges
    a regular bump/grind commuter run will result in more oil consumption than
    a consistent hi way cruise
    1 quart in approx 3000 miles is no biggie
