PennSilverTaco's "Perfect 5-Lug Regular Cab" Build, Aspergers, and General BS MegaThread!
Discussion in '2nd Gen. Builds (2005-2015)' started by PennSilverTaco, Jul 15, 2014.
  1. Jul 20, 2020 at 1:56 PM
    grubburg
    grubburg Well-Known Member
    2019 TRD OR MT
    K & N Intake, Gibson Catback (chopped), Weathertech floormats, 285/70/17 Ridge Grapplers, Black Rhino Glamis wheels, Kicker Key, Kicker Hideaway, Infiniti Speakers, OV Tune, 888's, 5100s X 4, HS 3-leaf, LR SPC UCAs, Diff Drop, Carrier Bearing Drop, OEM Bed Mat, Morimoto HID low beams, Morimoto LED 2 Stroke High Beams, KC 336 LED bar, KC C3 LED pods for rear, KC LED 6'' SlimLites ditch lights, N-Fab Steps, Auxbeam Interior Blue Lights, 7r41lbr34k3r Shift Knob, Wet Okole Seat Covers, Diode Dynamics SAE Pro Fogs, Cali Raised ditch light brackets, hidden light bar brackets, tailgate light brackets.
    You guys like Pepsi or Coke?
  2. Jul 20, 2020 at 2:02 PM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Lol, cant tell if that last part is sarcastic or not, but yes a manufactuers "dyno" numbers will always be accurate.
    Have you ever looked at the stock Tacoma air intake? It sucks air in from the wheel well right above the tire, outside the engine compartment. Adding a "cold air intake" either sealed or not, inside the engine bay would be a step backwards if you were looking for performance.
    I think comparing the horsepower gains on a 700+hp or 500ci crate race motor and then juxtaposing them onto a toyota tacoma are kind of crazy. Two totally differnt applications and so many other different factors affecting that negliable power gain.
  3. Jul 20, 2020 at 2:14 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    OP, (if you're still here):
    K&N/oiled filters are fine investments if you're going to own it long enough to offset the cost in paper filters. They flow more when clean but are out-performed soon after that. I've used them for that reason - and once you get the recharge kit and multiple filters for all your vehicles, its nice to be able to rejuvenate them all at once... for like <$5 of liquid.
    The MAF will read whatever air is ingested and inject the appropriate fuel; it is not a zero-sum game as somebody else stated. More restriction will decrease Volumetric Efficiency (VE) thus affecting power and BSFC (read: "fuel economy"), but not to a noticeable degree.
    As somebody else stated, the way the air enters the intake is much more important (such as via velocity stack - an exponential taper) so you'd be better off finding a filter with one integrated. I forget which company does this, but they have flow figures to back it up.
    Some toilet reading for you: https://dieseliq.com/aftermarket-air-filters
    The sock's only purpose is providing a hydrophobic barrier. That's why it makes sense for yours, since its in the corner where water will seep through the hood cracks.
    US Marine[QUOTED] likes this.
  4. Jul 20, 2020 at 2:48 PM
    ssd2k2
    ssd2k2 Well-Known Member
    Keith
    Minnesota
    2019 Tacoma TRD Sport M/T
    It picks up from a small hole in the quarter panel not directly from the wheel well vs the whole front of the car which is open to whatever is floating around.
    I've had two other cars with the air intake in pretty much the same location that I put aftermarket "cold air" intakes on. After 150,000 miles between the two, one with open air filter vs with a sealed box, I noticed the filter without an air box had to be cleaned after less than 10k miles vs with an air box I could get closer to 15k before cleaning.
    It's not about HP gains, it's about vroom vroom noises.
  5. Jul 20, 2020 at 2:57 PM
    markmizzou
    markmizzou Well-Known Member
    Mark
    Missouri
    17 SR5 V6 4x4 AC AT tow pkg. Blue as they come
    A back step for when I get older, Carhartt seatcovers, 4Runner wheels, Topper, and "tats all folks"! --for now!!
    The element is NOT the problem --it is the "fusion process" by the heat that has ruined the oven cavity itself. I also thought I could take on replacing the whole oven cavity -problem was - the cavity was not available as a part that a "consumer" could order. said the MFR.
    "we can't sell that part" to you as it would not be "possible" for a consumer (regardless of their technical abilities) to take on this task.
    Also to the other poster about using tape --you have no idea how well this tin foil will fuse to the oven coating after it has been melted on with the temps of a oven on the broil setting.
    PennSilverTaco[OP] likes this.
  6. Jul 20, 2020 at 4:11 PM
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    Yeah, I do. My wife, (who doesnt need a user manual) melted foil on our oven bottom shortly after we bought it. Granted, the tape just got the big chunks off; the rest, I think we soaked in simple green and scoured it with a nylon pad, then ran a self clean. The oven is perma-scarred though. Nothing gets that shit off totally.
  7. Jul 20, 2020 at 4:19 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    You clean the MAF every oil change and risk damaging it when you don’t actually need to clean it unless there’s an issue. Lol
    .....and the K&N actually causing the oil buildup on the MAF. So you’re creating your own problems and think it’s fine. Lol
  8. Jul 20, 2020 at 5:41 PM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    Not to mention that a 3hp "gain" on a 700+hp engine is way inside the dyno margin of error. Several runs, back to back, with the same conditions, will likely result in more than a 3hp delta in the results.
    US Marine likes this.
  9. Jul 20, 2020 at 5:52 PM
    GrundleJuice
    Michigan
    2016 TRD Bro
    I wasn't talking about replacing the element, I was talking about replacing the surface that the foil melted on. Many (most?) ovens with an element under the lower surface have a bottom panel that is removable. My previous electric oven did and my current gas one does, too. Going to the MFR for parts is the first mistake you made. You have to go through a dealer or an appliance repair place that has the ability to order from the MFR. Just like with a auto, you can't go directly to Toyota for parts, you go through a dealer or parts supplier. Also, cheap appliances are made cheaply and without the provisions for repair or maintenance. Heck, even some expensive appliances are made cheaply and without repairs in mind.
    The oven coating is used specifically because it is not porous and able to withstand very high temps. The bond of the aluminum should be mechanical, not chemical.
  10. Jul 20, 2020 at 6:11 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    Like I mentioned previously ....
    If you watch Motor trend's Engine Masters episode #27 " Air filter challenge " with Dave Freiburger , Steve Dulcich and Steve Brul'e
    You'll be surprised what a K&N filter can support
  11. Jul 20, 2020 at 6:48 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    No,waste of money.
  12. Jul 20, 2020 at 6:49 PM
    Boyk1182
    Boyk1182 Well-Known Member
    Northern Colorado
    Cherry Coke.
    Greenedmc and PennSilverTaco[OP] like this.
  13. Jul 20, 2020 at 6:52 PM
    Greenedmc
    Greenedmc Well-Known Member
    Daniel
    Elizabethton TN
    2014 Silver Tacoma Trd Off Road Access cab
    Vanilla Coke
  14. Jul 20, 2020 at 6:52 PM
    PennSilverTaco
    PennSilverTaco [OP] Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    @Greenedmc
    I used to have a Coke problem, but then I switched to Pepsi; It just goes through the straw so much easier...
  15. Jul 20, 2020 at 6:53 PM
    Boyk1182
    Northern Colorado
    I just wanted to sub to this. I have an AFE Pro dry, I cleaned it yesterday and it’s drying now. I just hope it’s filtering as well as the paper filters do, I’ve been using it a while.
  16. Jul 20, 2020 at 6:53 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    Jolt Cola or Surge
  17. Jul 20, 2020 at 6:55 PM
    PennSilverTaco
    Charlie
    grubburg and Greenedmc like this.
  18. Jul 20, 2020 at 6:57 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    When I used to drive trucks and stay awake I had a large Monster Energy drink followed by Mtn Dew Code red
  19. Jul 20, 2020 at 7:08 PM
    Assumer
    Assumer Well-Known Member
    Maumelle Arkansas
    2020 TRD White
    GoRhino D1
    When you get to go you will love it. Gotta go to the cliffs of Mohr Dingle Kilkey. Just driving you see remnants of castles. People are wonderful.
  20. Jul 20, 2020 at 7:19 PM
    PennSilverTaco
    Charlie
    I used Monster to get through the 9-hour Saturday shifts when I was detailing cars at a dealership; I DO NOT MISS THAT SHITTY JOB!
