PennSilverTaco's "Perfect 5-Lug Regular Cab" Build, Aspergers, and General BS MegaThread!
Discussion in '2nd Gen. Builds (2005-2015)' started by PennSilverTaco, Jul 15, 2014.
  1. Dec 1, 2020 at 8:50 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Is the air compressor always on? If it goes to start they usually draw full amp rating.
  2. Dec 1, 2020 at 8:51 AM
    PennSilverTaco
    PennSilverTaco [OP] Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    No it isn't; Don't even think my dad keeps it plugged in when not in use...
    wilcam47[QUOTED] likes this.
  3. Dec 1, 2020 at 8:51 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    If one GFI trips does in only trip that one or does it take out any other outlets?
  4. Dec 1, 2020 at 8:51 AM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
  5. Dec 1, 2020 at 8:51 AM
    PennSilverTaco
    Charlie
    All other outlets...
  6. Dec 1, 2020 at 8:52 AM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    So your bathroom and garage and basement and outside receptacles are all one this poor 15amp breaker. That there is the issue dude.
    Gunshot-6A likes this.
  7. Dec 1, 2020 at 8:52 AM
    wilcam47
    Will
    Bourbon state
    So the treadmill is inside house? Or garage?
    PennSilverTaco[OP] likes this.
  8. Dec 1, 2020 at 8:52 AM
    TheCochese
    TheCochese The Bronze T4R OG
    Attempting to flee the south
    Cavalry Blue soccer machine
    Fine corinthian leather
    These christmas lights that are outside...are they plugged into an outdoor (attached to side of house) outlet?
  9. Dec 1, 2020 at 8:52 AM
    PennSilverTaco
    Charlie
    :rofl:
    I don't have more than three interconnectible sets plugged into each other at once...
    wilcam47 likes this.
  10. Dec 1, 2020 at 8:53 AM
    PennSilverTaco
    Charlie
    Downstairs in the unfinished basement.
  11. Dec 1, 2020 at 8:54 AM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    And your still clueless as to why your tripping a breaker/gfci :facepalm:
    Martyinco and TheCochese like this.
  12. Dec 1, 2020 at 8:54 AM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    Regardless of where the treadmill is or if it's even on this breaker. That's still too many rooms and things on the one 15amp. The bathroom should be on a separate breaker all it's own. Same with the garage, and then again with the basement.
  13. Dec 1, 2020 at 8:55 AM
    PennSilverTaco
    Charlie
    Yes, but indirectly; I've got a six-plug outdoor power strip/dusk-to-dawn timer plugged into the side outlet and two strands on the left side of the house plugged into that. I've got another dusk-to-dawn power strip plugged into the first one, and the operates the lights on right side of the house.
  14. Dec 1, 2020 at 8:56 AM
    shakerhood
    Southern Ohio
    Right that way sucks. When l use them l set them up to work independent of each other, that way if one trips it doesn't impact anything else on that circuit. Where I was going before was a 15 Amp circuit x 120 Volts = 1800 Watts, then subtract about a 20 percent safety factor leaves you 1440 Watts. If you add the wattage together of everything on that circuit it can't exceed that.
  15. Dec 1, 2020 at 8:57 AM
    PennSilverTaco
    Charlie
    Dehumidifier not in use at the moment, and nothing in the garage is in use unless someone is out there; The treadmill and the LEd nightlights are the only things really in use, and I don't think the nightlights are the problem...
  16. Dec 1, 2020 at 8:58 AM
    TheCochese
    Less is more, man.
    Your outdoor outlet should not be on the same circuit as a bathroom or kitchen outlet.
    Is the outdoor outlet GFCI? Is there another outlet on this circuit that is also GFCI?
  17. Dec 1, 2020 at 8:58 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    OP......you are missing the key item to solving this problem. The Current load (Amperage) of each item is needs to be totaled to understand the load on the circuit.
    Look at each item in your list. There should be a label or tag that indicates the Current Rating (amp or A) of that device. Add up all the current ratings for each device on the power strip or outlet. If it is greater than 15A, then you have found the problem. Another method to determine what device is on a circuit is to shut off the breakers, then make a note what items quit working and the non-working outlets.
    In your list, the 2 biggest current consumers will the treadmill and the air compressor. Each could suck up 15+A on its own. Hairdryer can also suck up a large current load.
    Gunshot-6A, wilcam47 and Lawfarin like this.
  18. Dec 1, 2020 at 8:58 AM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    Things with a high amp draw (microwave, fridge, garbage disposal, AC units, treadmills, air compressors, welders....) should be on breakers all their own, or only share it with plugs in that room. Lights should be by themselves on a breaker. This ensures lights dont dim when a big draw appliance kicks on. Bathrooms should be on breakers all their own for safety. (Water and electricity dont mix).
  19. Dec 1, 2020 at 8:58 AM
    PennSilverTaco
    Charlie
    Check out the other thread...
    CLICK HERE
  20. Dec 1, 2020 at 8:59 AM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Treadmill is up to 20 amps. Dehumidifier probably at least 5.
    Bathroom should definitely be own it’s own circuit (code) and the garage should be on its own maybe run front outdoor gfci’s. Would be smarter to just have a small sub panel in the garage but builders won’t ever do that.
    Gunshot-6A, TheCochese and wilcam47 like this.
