PennSilverTaco's "Perfect 5-Lug Regular Cab" Build, Aspergers, and General BS MegaThread!
Discussion in '2nd Gen. Builds (2005-2015)' started by PennSilverTaco, Jul 15, 2014.
  1. Dec 1, 2020 at 8:59 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    If you step up to 20 Amps:
    20 x 120 = 2400
    2400 - 480 = 1920 Watts
  2. Dec 1, 2020 at 9:00 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    the basement should be its own circuit.
  3. Dec 1, 2020 at 9:01 AM
    PennSilverTaco
    PennSilverTaco [OP] Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    Dehumidifier not in use...
  4. Dec 1, 2020 at 9:01 AM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Also everything outside should be sealed. Having a power tower and open connectors sitting outside exposed to the elements isn’t a good idea and can fault the GFCI
    Gunshot-6A, TheCochese and wilcam47 like this.
  5. Dec 1, 2020 at 9:02 AM
    PennSilverTaco
    Charlie
    Whenever someone uses the treadmill, the recessed lights in the kitchen pulsate, as does the light in the powder room...
    wilcam47 likes this.
  6. Dec 1, 2020 at 9:03 AM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Also food for thought. Every time a breaker trips, it gets weaker
  7. Dec 1, 2020 at 9:03 AM
    PennSilverTaco
    Charlie
    The bathrooms are on their own breaker I believe, now that I think about, but the bathrooms all share the same circuit...
  8. Dec 1, 2020 at 9:03 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    false , ask me how I know
    Martyinco, medic2230, FFBlack and 4 others like this.
  9. Dec 1, 2020 at 9:03 AM
    wilcam47
    Will
    Bourbon state
    Also those dusk to dawn controllers burn out quick and can kick breakers. Had that issue also
  10. Dec 1, 2020 at 9:04 AM
    PennSilverTaco
    Charlie
    Also, it's not a switch within the circuit breaker; This GFCI is separate from the main breaker I think...
    The internet, cable, and Christmas lights will all go out but everything else in the house still works!
  11. Dec 1, 2020 at 9:04 AM
    PennSilverTaco
    Charlie
    I'm gonna guess you own one?
  12. Dec 1, 2020 at 9:05 AM
    OZ-T
    Peter North
    British Columbia
    I build them
    shakerhood likes this.
  13. Dec 1, 2020 at 9:05 AM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Is it a breaker in the panel tripping not the main obviously) or just the GFCI?
  14. Dec 1, 2020 at 9:06 AM
    TheCochese
    TheCochese The Bronze T4R OG
    Attempting to flee the south
    Cavalry Blue soccer machine
    Fine corinthian leather
    Still waiting to hear if there are two GFCI outlets on the same circuit.
  15. Dec 1, 2020 at 9:06 AM
    PennSilverTaco
    Charlie
    We did not start having the breaker pop issue until I swapped the controllers; I'm thinking I might put the newer one back in the main location. The older one is far more intuitive to use, and I haven't figured out how to operate the timer on the new one (I just unplug it every night before bed).
    wilcam47[QUOTED] likes this.
  16. Dec 1, 2020 at 9:07 AM
    PennSilverTaco
    Charlie
    Yes; With the exception of the bathrooms every GFCI is on the same circuit. The bathrooms all share a circuit, and something happened with the breaker a couple weeks ago where none of the lights in our three bathrooms worked (simple as flipping a switch to get it working again though).
  17. Dec 1, 2020 at 9:08 AM
    PennSilverTaco
    Charlie
    The compressor has only been used twice in the last couple of weeks and is not plugged in when not in use.
  18. Dec 1, 2020 at 9:10 AM
    TheCochese
    How many damn GFCI outlets are on this one circuit? There really should only be one per circuit.
    Also, stop talking about other circuits not related to this one. You're muddying the waters with too much information that may not be relevant. Stick to what you know is on this one circuit. If you don't know, find out.
  19. Dec 1, 2020 at 9:10 AM
    wilcam47
    Will
    Bourbon state
    Sounds like some bad electrical work. Need to be careful and open the circuit panel and check connections. The upstairs lights shouldnt flicker. When running treadmil.
  20. Dec 1, 2020 at 9:11 AM
    OZ-T
    Peter North
    British Columbia
    I'm no electrician but pretty certain there should only be 1 GFCI plug on the circuit protecting everything else downstream
