PennSilverTaco's "Perfect 5-Lug Regular Cab" Build, Aspergers, and General BS MegaThread!
Discussion in '2nd Gen. Builds (2005-2015)' started by PennSilverTaco, Jul 15, 2014.
  1. Dec 1, 2020 at 9:13 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    OH good God.
    Getting good information for this issue is like trying to get milk from an Oak tree.
    If the device isn't plugged into the circuit, then it doesn't count.
    No wonder everyone is spinning trying to help solve your problem.
    wilcam47 and TheCochese like this.
  2. Dec 1, 2020 at 9:14 AM
    Fargo Taco
    Fargo Taco Well-Known Member
    Not Drew but still Drew
    Fargo
    2019 TRD Pro
    Lomax tonneau cover, N-Fab Podium steps, bed mat
    There should only be one GFCI per circuit.
    Edit: Beat by pretty much everyone. :laugh:
  3. Dec 1, 2020 at 9:17 AM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    GFIC breakers or GFIC outlets?
    TheCochese likes this.
  4. Dec 1, 2020 at 9:17 AM
    PennSilverTaco
    PennSilverTaco [OP] Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    Just talked to my dad; The house has three GFCI circuits...
    One does the basement and outdoor outlets, one does the garage, and one does all three bathrooms; The internet, cable, treadmill, and Christmas lights are the only items sharing the same circuit. My dad says the basement is very poorly wired (not unsafe or dangerous in anyway, just your typical tract home fustercluck). The air compressor and iPod charging station/speaker in the garage have no affect on the breaker popping. What I would like to figure out is why the internet, cable, and Christmas lights went out las night without the treadmill being in use...
  5. Dec 1, 2020 at 9:19 AM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    You can run more than 1 gfci on a circuit. However it’s important how it’s wired.
    shakerhood and wilcam47 like this.
  6. Dec 1, 2020 at 9:20 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    :goingcrazy:
    wilcam47 likes this.
  7. Dec 1, 2020 at 9:20 AM
    Knute
    Ok......lets everyone stop for a few minutes. Lets see if the OP can clear up a few questions to help form a base.
    OP.
    How do you identify a circuit? One outlet? One power cord? One GFCI?
    How do you determine what device is operating on an outlet or circuit?
    Could you find the Electric Panel in the house?
    Could you identify a circuit in the Panel?
    Can you reset a circuit breaker in the Panel?
  8. Dec 1, 2020 at 9:21 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    X2
    Sig45[QUOTED] likes this.
  9. Dec 1, 2020 at 9:21 AM
    TheCochese
    TheCochese The Bronze T4R OG
    Attempting to flee the south
    Cavalry Blue soccer machine
    Fine corinthian leather
    OK, now we are getting somewhere. If this information is 100% accurate (and you should own some basic electrical testing equipment, every homeowner should. Outlet tester, live wire tester, Kill-A-Watt are among those. Stop by HD, Lowes, or wherever and pick up at least the live wire tester at the bare minimum before you touch anything else.)
    Now, eliminate talking about anything going forward that isn't on the one circuit you are having problems with going forward.
    Go home, verify this information is accurate. That's the next step.
  10. Dec 1, 2020 at 9:28 AM
    PennSilverTaco
    Charlie
    In this case, one GFCI.
    If it is plugged into one of the GFCI sockets, then it is operating on a circuit and not an individual outlet; Every room has two to four outlets and those all operate on the circuit for that specific room.
    Yes. There two, both in the basement. The main one is located in the far corner of the basement, and the smaller one is located on the other side near the sump pump. There is also a separate deal for the internet cable, which itself has a breaker switch but is tied into the basement/outside GFCI.
    o_O Yes, of course I can; I've known how to reset breakers since before I was old enough to drive.
  11. Dec 1, 2020 at 9:31 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Exactly, they will operate independent of each other and not take out the entire circuit.
    PennSilverTaco[OP] likes this.
  12. Dec 1, 2020 at 9:32 AM
    PennSilverTaco
    Charlie
    It sounds like my house was not as badly wired as I thought it was, but the basement is definitely a shitshow...
    shakerhood[QUOTED] and wilcam47 like this.
  13. Dec 1, 2020 at 9:34 AM
    scotkw
    scotkw Well-Known Member
    A free State
    '17 DCSB V6 2wd Sr5
    Some nomenclature to clear up.
    There are breakers in the panel, There are GFCI breakers in the panel, then there are GFCI outlets on the walls. Be clear on which one is tripping.
  14. Dec 1, 2020 at 9:34 AM
    TheCochese
  15. Dec 1, 2020 at 9:34 AM
    PennSilverTaco
    Charlie
    GFCI
  16. Dec 1, 2020 at 9:35 AM
    Knute
    Ok. Thanks. Your answers clear a few things. Please focus only on the problem area.
    OP> The GFCI with the Xmas lights is it located in the Panel or is it an outlet?
    Stick with me guys.....I think I can lead us out of this with a few questions.
    wilcam47 and PennSilverTaco[OP] like this.
  17. Dec 1, 2020 at 9:35 AM
    PennSilverTaco
    Charlie
    What'd I do wrong?
  18. Dec 1, 2020 at 9:37 AM
    scotkw
    A free State
    '17 DCSB V6 2wd Sr5
    is it GFCI outlet on wall or GFCI breaker in the panel that is tripping? Those are 2 different things.
  19. Dec 1, 2020 at 9:38 AM
    PennSilverTaco
    Charlie
    Outlet; Not the outlet that the Christmas lights are plugged into. The main outlet for this circuit controls all of the GFI outlets in the basement and the two located outside, and the internet and cable are plugged into the "main" outlet; Only the "main" outlet has a reset button, and this is what we have to press to get everything working again.
  20. Dec 1, 2020 at 9:38 AM
    PennSilverTaco
    Charlie
    On the wall next to the breaker, but separate from breaker.
