PennSilverTaco's "Perfect 5-Lug Regular Cab" Build, Aspergers, and General BS MegaThread!
Discussion in '2nd Gen. Builds (2005-2015)' started by PennSilverTaco, Jul 15, 2014.
  1. Dec 1, 2020 at 10:17 AM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
  2. Dec 1, 2020 at 10:18 AM
    Fargo Taco
    Fargo Taco Well-Known Member
    Not Drew but still Drew
    Fargo
    2019 TRD Pro
    Lomax tonneau cover, N-Fab Podium steps, bed mat
    Do you have a picture of this power tower?
    And bushes aren't going to protect anything from water.
    wilcam47 and PennSilverTaco[OP] like this.
  3. Dec 1, 2020 at 10:19 AM
    PennSilverTaco
    PennSilverTaco [OP] Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    Will take pics when I get home from work...
    shakerhood and wilcam47 like this.
  4. Dec 1, 2020 at 10:21 AM
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    Grind it off with a 120 grit flap disk.
  5. Dec 1, 2020 at 10:23 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Ok....we seem to be narrowing the problem.
    First steps to take outside is to protect those power towers from water. Consider them to be in the wide open driveway with no protection.
    I'd suggest for you to fashion some type of housing to protect the power towers. Anything can work. Milk jug, coffee can, ice chest, ziploc with duct tape. Get the towers encased in a water resistant housing. Think about how to protect from a direct stream of water from a garden hose nozzle.
    <edit> A 5 gallon bucket from HomeDepot, Lowes, Menards with a lid would make a good housing. Just drill a couple holes to pass cords, snap the lid on.......<endedit>
    When you get home, record the current ratings of all the devices in the list. Then add up all the numbers. Over 15 A? If yes, then begin unplugging the big current load devices. Place them on a different circuit, not just a different outlet.
    These steps will likely solve your trouble.
    As a follow up. I would urge your Father to hire a certified, licensed, bonded electrician to rewire that basement and these circuits. Whoever did the work was a hack. As a side note: sometimes a family friend is not a good choice. That treadmill needs its own dedicated circuit. Lights should be on separate circuits. The outside outlets should be on their own circuit or as GFCI outlets without dependent outlets downstream.
    As it is set up. The main electric panel feeds a GFCI, then the GFCI feeds a number of outlets downstream, including the outside outlets. So, if water enters an electric connection outside causing the GFCI to trip, then the basement dies. Or if you'd rather......Dad is running at full tilt on the treadmill, GFCI trips, Dad tumbles off treadmill, gets injured, call ambulance.........
  6. Dec 1, 2020 at 11:08 AM
    PennSilverTaco
    Charlie
    Right now, the only issue with my truck is the left license plate lamp; I initially thought it was burned out, but on a whim decided to kick it and it came back on. Sometimes it stays on, but most of the time I have to kick it just so to make it turn on; I unscrewed the assembly from the back bumper the other day and took a look, but found nothing amiss (and the light stayed on), so I screwed it back into place and have been giving it percussive maintenance on an as-needed basis. I'm wondering if it's somehow related to having the trailer hitch installed back in October...?
    shakerhood likes this.
  7. Dec 1, 2020 at 11:16 AM
    PennSilverTaco
    Charlie
    @El Duderino
    Porsche 911 GT3! :drool::drool::drool:
    Met this couple in the Kohl’s parking lot while cruising around with the truck lit up on Black Friday (don’t worry, I got his permission to take a picture of the car); I know you love Porsches, and the couple kinda reminded me of you and your wife...
    Taco critter and shakerhood like this.
  8. Dec 1, 2020 at 11:33 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Wow, that is Sexy! One day l was at Lowe's and a guy was throwing bags of cement into the front trunk of a 911.
  9. Dec 1, 2020 at 11:35 AM
    PennSilverTaco
    Charlie
    o_O :rofl:
    Though to be fair, I know a guy who puts all sorts of home improvement materials in the trunk of his Rolls-Royce...
  10. Dec 1, 2020 at 11:36 AM
    shakerhood
    Southern Ohio
    You would think if you were wealthy enough to own an exotic car you would also have something else for picking up building supplies.
  11. Dec 1, 2020 at 11:37 AM
    PennSilverTaco
    Charlie
    Didn't hurt the car, but I feel like a 1980 Rolls-Royce Camargue would be a bit more up to the task than a Porsche 911...
    Taco critter likes this.
  12. Dec 1, 2020 at 11:38 AM
    PennSilverTaco
    Charlie
    Well maybe he normally probably pays people with pickup trucks and vans to do that shit for him, but this was maybe a spur-of-the-moment type of thing?
    shakerhood[QUOTED] likes this.
  13. Dec 1, 2020 at 11:40 AM
    shakerhood
    Southern Ohio
    I didn't stop to talk to the guy, was almost in disbelief as l walked past as there is no way l would have done that.
  14. Dec 1, 2020 at 11:41 AM
    PennSilverTaco
    Charlie
    Have you ever been forced to haul stuff like that in your Mustang?
  15. Dec 1, 2020 at 11:41 AM
    El Duderino
    El Duderino Obviously, you're not a golfer.
    Jeremy
    HI->PNW
    19 nautical blue SR5 premium 4x4
    Stuff, things, this, an ADS
    Wife loves them. I’m a ferrari man
  16. Dec 1, 2020 at 11:42 AM
    El Duderino
    Jeremy
    HI->PNW
    But I do love the 911 GTR3. Would love one in white or silver
  17. Dec 1, 2020 at 11:42 AM
    PennSilverTaco
    Charlie
    Didn't you have a situation in Italy that resulted in a $20,000 brake job for a relative's Ferrari?
    El Duderino[QUOTED] likes this.
  18. Dec 1, 2020 at 11:42 AM
    PennSilverTaco
    Charlie
    I've got a LEGO replica of a GT3 RS in orange...
  19. Dec 1, 2020 at 11:43 AM
    shakerhood
    Southern Ohio
    Maybe that 911 was a rental car, lol. Well that Mustang is a Hatchback and you can fit quite a bit of stuff back there. When l was moving from my apartment to my house l did everything in my old Geo Tracker and the Mustang.
  20. Dec 1, 2020 at 11:44 AM
    PennSilverTaco
    Charlie
    So glad I have a pickup!
