PennSilverTaco's "Perfect 5-Lug Regular Cab" Build, Aspergers, and General BS MegaThread!
Discussion in '2nd Gen. Builds (2005-2015)' started by PennSilverTaco, Jul 15, 2014.
  1. Dec 8, 2020 at 2:15 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Yes! If you want factory cruise. They may make after market cruise set ups.
    PennSilverTaco[OP] likes this.
  2. Dec 8, 2020 at 2:16 PM
    PennSilverTaco
    PennSilverTaco [OP] Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    What does this truck need to get factory cruise control if it isn’t prewired?
  3. Dec 8, 2020 at 2:19 PM
    gotoman1969
    You would need the factory dash harness at minimum that has the cruise wires and connections, maybe even an ecu if yours is not set up to have cruise. If it’s not prewired there is nothing for you to plug the parts into and carry any signal to the ecu to control the cruise control. You’re going down a rabbit hole it’s not worth imo. Maybe some people of the electrical gurus will chime in.
  4. Dec 8, 2020 at 2:25 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Take lots of pictures, I'm curious
  5. Dec 8, 2020 at 2:34 PM
    PennSilverTaco
    Charlie
    Why would it have that little light on the instrument cluster if it wasn’t prewired?
  6. Dec 8, 2020 at 2:36 PM
    Tacospike
    Two Trucks
    To save money and make the same dash for all models. Just some that have the feature wire them and others don't. Lots of manufacturers do this.
    gotoman1969 likes this.
  7. Dec 8, 2020 at 2:37 PM
    gotoman1969
    Did the light come on or your can seat where it say cruise? Many of the cluster faces have all the little wording. In many cases it’s easier to make a universal face vs one for each set up.
  8. Dec 8, 2020 at 2:39 PM
    PennSilverTaco
    Charlie
    Yes, no light but it says “CRUISE”; Picture above...
  9. Dec 8, 2020 at 2:40 PM
    gotoman1969
    Means nothing. The faces are universal for mass production and savings cost.
  10. Dec 8, 2020 at 2:41 PM
    PennSilverTaco
    Charlie
    What’s the likelihood of my truck having it?
  11. Dec 8, 2020 at 2:42 PM
    gotoman1969
    More on the less side. Let’s put it this way. If it’s not prewired it will cost you more than the trucks worth to make it like it would have come from the factory.
  12. Dec 8, 2020 at 2:43 PM
    PennSilverTaco
    Charlie
    Truck’s worth about $8,500...
    I highly doubt it would cost over eight grand to install cruise control if it isn’t prewired.
  13. Dec 8, 2020 at 2:47 PM
    gotoman1969
    If you need a dash harness .oem is about 3k, if need the ecu oem another 2k, may need a throttle body too, may need the engine harness 2-3k of course these are new parts. I’d never buy a harness that’s been sitting in a junkyard or ecu. You said you only do oem. Now if you want an after market set up probably could do it for a grand.
  14. Dec 8, 2020 at 2:49 PM
    PennSilverTaco
    Charlie
    Would an aftermarket setup look like shit?
  15. Dec 8, 2020 at 2:49 PM
    gotoman1969
    Oh wait you’d still have to remove the entire dash to install the harness , and if need the engine harness there’s another 1k labor if you can’t do it your self. Seeing the rabbit hole yet
  16. Dec 8, 2020 at 2:50 PM
    gotoman1969
    I’ve seen a few they don’t look bad if the person installing takes their time to make it look good. Definitely much cheaper.
  17. Dec 8, 2020 at 2:51 PM
    PennSilverTaco
    Charlie
    Is there a light that comes on indicating it’s on?
  18. Dec 8, 2020 at 2:54 PM
    PennSilverTaco
    Charlie
    Just picked up MOST of the necessary parts; Screws and steering wheel side plate arrive Thursday...
  19. Dec 8, 2020 at 2:59 PM
    gotoman1969
    I can’t recall.
  20. Dec 8, 2020 at 3:01 PM
    Levalexi
    Levalexi Well-Known Member
    Southern Maine
    07 Tacoma access cab 4x4 2.7l
    its the same cluster. do the paperclip in the bottom two holes of the plug like i said above to see if its prewired. or have your mechanic friend do it. itll take 5 minutes at most to do it.
    and this following post is what you do. since you have everything else, i would contact the seller and see if you can purchase just the wiring from him. in the event you arent prewired, all you need to do is run a ground wire, and run one from the steering wheel to the ecu
