PennSilverTaco's "Perfect 5-Lug Regular Cab" Build, Aspergers, and General BS MegaThread!
Discussion in '2nd Gen. Builds (2005-2015)' started by PennSilverTaco, Jul 15, 2014.
  1. Feb 25, 2021 at 1:32 PM
    PennSilverTaco
    PennSilverTaco [OP] Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    I'm probably not getting new tires until August or September, but I'll definitely have Pete realign the truck after he installed the lift.
    :hattip: :wave::fistbump: :cheers:
  2. Feb 25, 2021 at 1:33 PM
    PennSilverTaco
    Charlie
    I've allowed my truck to get low enough that the warning light came on just one time; I rarely ever let it get below a quarter of a tank anymore, and I track the distance I've travelled using the trip odometer. The farthest I've ever gone before filling up that I can remember was about 240 miles...? On this occasion, the fuel gauge was just below a quarter of a tank, but I have a feeling my calculations are not entirely accurate because I burn some gas while sitting in traffic or just idling with the A/C on...
  3. Feb 25, 2021 at 1:33 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Good deal buddy!
  4. Feb 25, 2021 at 1:34 PM
    PennSilverTaco
    Charlie
    Have you heard of a hydrogen bubbler?
    shakerhood[QUOTED] likes this.
  5. Feb 25, 2021 at 1:35 PM
    shakerhood
    Southern Ohio
    No, not that l can recall, what does it do?
  6. Feb 25, 2021 at 1:36 PM
    PennSilverTaco
    Charlie
    Supposedly connects to the gas tank and improves mileage substantially...
  7. Feb 25, 2021 at 1:36 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Working for the Hindenburg effect.
    What are you using to crack the H2 from?
    What are you using to initiate the cracking method? Electricity? Chemical.
    What are you doing with waste?
    What is the supply?
    What additional equipment is required?
    What controls are needed on the process?
    How will you meter it into the engine?
    How to adjust the engine tune?
    How to create the fuel/air ratio mapping?
    Frankly, I think you were being fed a load.
    Good luck.
  8. Feb 25, 2021 at 1:37 PM
    shakerhood
    Southern Ohio
    I doubt anything like that would make any increases.
  9. Feb 25, 2021 at 1:38 PM
    PennSilverTaco
    Charlie
    Like I said, it was just traffic light chitchat...
    My mechanic is helping me install a lift kit in less a than a week (since he has a hydraulic lift and I don’t), and I’ll have him check the MAF to see if that’s dirty or clogged in anyway because I think it has something to do with my lousy mileage.
  10. Feb 25, 2021 at 1:39 PM
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
    I remember this snake oil bull from a decade ago.
    If the car companies could make more efficient motors they would.
  11. Feb 25, 2021 at 1:43 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Yeah back then they were calling it 'browns gas' or 'HHO'.
    Essentially you're using electrical power to do 2H2O -> 2H2 + O2 , then feed the resulting mix into the engine. They claim that this saves fuel, enough to negate the extra you've burnt to run the alternator to run the reaction. I've never tested it.
  12. Feb 25, 2021 at 1:47 PM
    Knute
    Consider.
    Typically, H2 is cracked from Natural Gas. I don't know the process, but I assume its chemical or molecular sieve. H2 can also be cracked from water.
    The Nat Gas process would require an onboard storage for the Nat Gas, plus the equipment to crack the H2. I'm not 100% what gas remains, but I suspect it is flammable. In this situation, it would be simpler to feed the Nat Gas into the engine and avoid the cracking process.
    The water process requires electricity. To create enough H2 to feed an engine would require a significant amount of current. The waste will be a mix of O2 and water. O2 is highly flammable and is capable of oxidizing very quickly.
    Either process is loaded with explosive problems and issues.
  13. Feb 25, 2021 at 1:47 PM
    PennSilverTaco
    Charlie
    Sounds like the “Turbonator”...
  14. Feb 25, 2021 at 1:48 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Hydrogen bubble chamber. At least 100mpg. 6BF4DCA5-10B7-40C1-8F50-4564432EB28C.jpg
    sbb, tacotoe, Naveronski and 4 others like this.
  15. Feb 25, 2021 at 1:55 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    They don’t work, they can’t work, they won’t save you any money and they won’t save you fuel . They are BS!
    They and every other device advertised to save fuel and improve mpg are bull shit. Think about it, if these things really worked new car manufacturers would be all over it. Every new car would have such a devise. It would certainly help new cars meet EPA fuel standards.
  16. Feb 25, 2021 at 2:00 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Hahaha, hey OP, ask the guy if he’s got any real estate for sale too. He might be able to cut you a smoking deal!
    6 gearT444E and Sprig like this.
  17. Feb 25, 2021 at 2:14 PM
    PennSilverTaco
    Charlie
    Yeah... No.
  18. Feb 25, 2021 at 2:16 PM
    PennSilverTaco
    Charlie
    One thing I love about Big Muddy Patches is that they include complimentary Smarties with every order!
    Taco critter and MarX like this.
  19. Feb 25, 2021 at 2:17 PM
    PennSilverTaco
    Charlie
    Taco critter, MarX and shakerhood like this.
  20. Feb 25, 2021 at 3:32 PM
    wmgeorge
    wmgeorge Well-Known Member
    The Browns gas thing has been around for a long time. Uses electricity to separate a water molecule into into Oxygen and Hydrogen. Yes it works,,,, BUT the energy used to make the Browns gas exceeds the output of energy Produced!!
