PennSilverTaco's "Perfect 5-Lug Regular Cab" Build, Aspergers, and General BS MegaThread!
Discussion in '2nd Gen. Builds (2005-2015)' started by PennSilverTaco, Jul 15, 2014.
  1. Jun 15, 2021 at 1:18 PM
    jburner
    jburner Well-Known Member
    2013 Tacoma TRD DCSB Black
    Head gasket would be more likely especially since you are losing oil every 3500 assuming there aren’t any visible leaks.
    Can you get a leak down test done on the coolant system?
    PennSilverTaco[OP] likes this.
  2. Jun 15, 2021 at 1:19 PM
    PennSilverTaco
    PennSilverTaco [OP] Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    No visible leaks; How common is it for head gaskets to fail?
  3. Jun 15, 2021 at 1:23 PM
    jburner
    On the 2.7, not sure I’ve heard of all that many. 4.0 not many either. Unfortunately, I was one of the rare ones that did have one at 85k on my 4.0, but thankfully it was covered by the warranty of the dealer I purchased it from
  4. Jun 15, 2021 at 1:31 PM
    PennSilverTaco
    Charlie
    Yeah, I’ve owned the truck since new and I’m way out of warranty…
  5. Jun 15, 2021 at 2:10 PM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    A qt. every 3500 miles would make me think, it’s time to part ways and move on.
  6. Jun 15, 2021 at 4:16 PM
    PennSilverTaco
    Charlie
    :mad:
    Can’t afford a new truck, and I’m 99% sure it’s the head gasket…
    whatstcp likes this.
  7. Jun 15, 2021 at 7:23 PM
    crtx
    crtx Well-Known Member
    Confirm 100% that is a failed Head Gasket. If is its a head gasket... the good news is, it does not sound like your engine has been damaged yet. I would swap in a new OEM head gasket and call it good. labor for a head gasket job should be reasonable with it being a 2.7 engine. After new engine is in, be sure to flush out the old coolant/oil mix. That oil/coolant mix will make your coolant hoses swell up and leak.
  8. Jun 15, 2021 at 7:25 PM
    JEEPNIK
    JEEPNIK Well-Known Member
    2020 Voodoo Blue TRD Sport
    Head gasket.
  9. Jun 15, 2021 at 7:27 PM
    uurx
    uurx Well-Known Member
    long island, new york
    '12 t|x pro
    i wanna know more about who and or how, you where suggested transmission fluid...
    because thats fascinating honestly
  10. Jun 15, 2021 at 7:28 PM
    JEEPNIK
    Tranny fluid from cooler leak on vehicles with a cooler in the radiator tank.
  11. Jun 15, 2021 at 7:29 PM
    PennSilverTaco
    Charlie
    That was my mechanic when I was talking to him on the phone, before he actually saw the coolant reservoir; He said something about the transmission cooler leaking into the coolant, but upon seeing the truck later on he determined that was not the case.
    uurx[QUOTED] likes this.
  12. Jun 15, 2021 at 7:41 PM
    GetterDun
    GetterDun Well-Known Member
    Northern BC, Canada
    2009 Tacoma
    Armor - TG Rock Defense Bumpers, OKX engine and transmission skid plate Suspension - Bilstein 8112 Remote Coilovers (650lb) and 8100 Adjustable Remote Reservoirs, TC UCA's, OME 500lb leaf springs Electrical - 27F Odyssey extreme AGM battery, "big 7" wiring upgrade, 200A alt and MK4 booster, Warn Zeon 10s winch with remote solenoid and upgraded wiring Engine - URD headers
    Best option would be to change the head gasket. No water in your oil hey?
  13. Jun 15, 2021 at 7:49 PM
    PennSilverTaco
    Charlie
    None; It's the exact opposite. The oil is mixing with the coolant, which is why my engine isn't totally screwed...
  14. Jun 15, 2021 at 7:55 PM
    PennSilverTaco
    Charlie
    This is the setup my truck has...
  15. Jun 15, 2021 at 8:01 PM
    GetterDun
    Northern BC, Canada
    2009 Tacoma
    Yeah thats good haha. So it'll be leaking in where the oil pressure is greater than the coolant pressure. Haven't had any issues like this for myself but I've had it happen to friends and the head gasket was the issue. Like JEEPNIK noted that could be another spot where it could happen, not sure where else in these engine the coolant and lube oil come in close proximity.
    Are you going to be changing the gasket yourself?
  16. Jun 15, 2021 at 8:06 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Yeah looks like the head gasket. I have had two fail on me but thats because i ran my 2.7 boosted without ARP head studs. That has been remedied now though, and i did the repair myself. I would say change it out and keep on trucking. That is low miles for a 2TR-FE. Also when mine went i didnt have coolant in the oil, but rather the cooling system was being pressurized and forcing the coolant out of the rad and into the overflow
    TnShooter and PennSilverTaco[OP] like this.
  17. Jun 15, 2021 at 8:07 PM
    PennSilverTaco
    Charlie
    I love my truck, but the head gasket shit the bed at 134K miles and it's not going to be a cheap fix; If I did decide to go through with this, I would still get my truck fixed before selling it. The biggest thing here is that I'd love to have a truck with 4WD...
    The truck in question belongs to a good friend of mine and I've been offered a very good price (not gonna say here); It is a red 2004 Access Cab TRD Off-Road 3.4L/5-speed 4x4, fully loaded, with almost 150K miles. The truck runs and drives great, and the A/C blows ICE COLD, and the frame was replaced. The title is clean and there is nothing wrong with the truck beyond normal wear.
    I can drive a stick shift, but one of my worries is that I will get tired of working a clutch pedal in suburban traffic; My biggest worry is about the truck's history prior to my friend acquiring it roughly a year and a half ago (I think she's put about 10K on it in that time). If I bought this truck, my plan would be to sell my current truck first so I can pay cash and have money left over. My only plans for modifications for the time being would be to upgrade the stereo system and add a backup camera (the truck currently has an aftermarket JVC HU with CD and USB, and what I believe to be the stock speakers).
    Taco critter likes this.
  18. Jun 15, 2021 at 8:10 PM
    PennSilverTaco
    Charlie
    :rofl:
    I can install a stereo, I can install lights, I can change the oil, and I can do rudimentary maintenance, but some things are better left to an experienced mechanic...
  19. Jun 15, 2021 at 8:48 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    It is a 2TR-FE a simple head gasket replacement. Get it done by a professional and call it a day. Nowhere near as screwed up as a 1GR-FE.
  20. Jun 15, 2021 at 8:54 PM
    PennSilverTaco
    Charlie
    Funny you should mention that because on Sunday I was talking to a guy at a car show who used to own a 2006 with the 1GR-FE; He said he sold the truck because it started severely burning oil at 130K, with puffs of blue smoke out the tailpipe and everything!
