PennSilverTaco's "Perfect 5-Lug Regular Cab" Build, Aspergers, and General BS MegaThread!
Discussion in '2nd Gen. Builds (2005-2015)' started by PennSilverTaco, Jul 15, 2014.
  1. Oct 11, 2021 at 6:54 PM
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    When I last changed my sparks this happened to me because I forget to reseat one of the ignition coils.
  2. Oct 11, 2021 at 7:02 PM
    PennSilverTaco
    PennSilverTaco [OP] Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    That was my mechanic's; Maybe I'll ask for one for Christmas...?
    shakerhood likes this.
  3. Oct 11, 2021 at 7:02 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Good habit to form is to disconnect the Negative side of the battery BEFORE FN around with the wires........
    But some must learn the hard way. My oldest daughter was like this. We could tell her "Don't touch that its hot." She'd touch it. Then First Aid.
    shakerhood and 6 gearT444E like this.
  4. Oct 11, 2021 at 7:09 PM
    PennSilverTaco
    Charlie
    It'll be page 2,200 and something when I merge it with the MegaThread...
    TnShooter and shakerhood like this.
  5. Oct 11, 2021 at 7:16 PM
    PennSilverTaco
    Charlie
    And I was not expecting the mods to get to it until tomorrow, but here we go...
  6. Oct 11, 2021 at 7:16 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    where is the merge button?
    TnShooter likes this.
  7. Oct 11, 2021 at 7:19 PM
    PennSilverTaco
    Charlie
    The mods gotta do that; Once I'm done with a thread, I get it merged with the MegaThread; Been doing that for years. It allows me to have an online record of everything I've done to my truck :):D:cool:
  8. Oct 11, 2021 at 7:20 PM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    How does this relate to the dash lights you get starting up a motor with an ignition coil disconnected? Doesn’t matter what was done with the battery before hand, that one cylinder won’t be firing.
  9. Oct 11, 2021 at 7:21 PM
    PennSilverTaco
    Charlie
    I've got the backup camera and every stereo modification in here, my uncle making my custom wheel skins, and when the frame gets replaced the service manager is gonna me go back into the garage at the dealer and take pictures of my 2010 Toyota jigsaw puzzle while it's pieces!
  10. Oct 11, 2021 at 7:22 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    When the reframe happens Toyota will replace the fluid as well.
    Or an Ultragauge, mang..one function it has is a code reader/resetterer
  11. Oct 11, 2021 at 7:24 PM
    PennSilverTaco
    Charlie
    I made the check engine light in my truck come on back in 2015 when I pulled the fuse for the horn...
  12. Oct 11, 2021 at 7:26 PM
    Knute
    It doesn't. That comment was posted in the other thread on the subject of the truck consuming a 1/2 quart of oil. Specifically, as a tip to prevent fouling up the electrical system while dinking with the wiring.
    Looks like the OP has merged the 2 topics.......
    Can't fathom anyone plowing through 2200+ pages of drivel and c-rap.
    6 gearT444E likes this.
  13. Oct 11, 2021 at 7:26 PM
    Markcal
    Markcal Well-Known Member
    Charlie, my 2006 has the same 2.7l engine you have and have been putting off replacing the valve cover gasket. Could some of your oil loss be from oil seeping out and burning off before noticing anything significant, as I have noticed my engine around the gasket looking wetter as time goes by?
    PennSilverTaco[OP] likes this.
  14. Oct 11, 2021 at 7:31 PM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    Well you did quote my coil post. But anyway. Go easy on the guy. Anyone who doesn’t like the content can just avoid it…
    ABA180 likes this.
  15. Oct 11, 2021 at 7:31 PM
    PennSilverTaco
    Charlie
    That is definitely possible; How much do you think it would cost to replace the valve cover gasket? Now that my frame is getting replaced I am DEFINITELY keeping my truck for the long haul, even if I buy something new and the truck is relegated to second vehicle status; My mechanic is very skilled at doing engine swaps on otherwise good vehicles that just need a new engine. He told me could probably put an engine from a totaled truck in my truck for like $3,500; If my truck needs a major repair at like 250K or so, it might be more economically feasible to drop a new one in there, and I would actually pay to do that instead of buying a newer vehicle and possibly having monthly payments...
  16. Oct 11, 2021 at 7:50 PM
    Markcal
    There are some good threads on DIY valve cover gasket replacement, so I was going to go that route, and haven't priced it. Here are some good threads if you decide to DIY it:
    https://www.tacomaworld.com/threads/oil-leak-rear-valve-cover-area-2008-2-7l.695331/
    https://www.toyotanation.com/threads/2-7-l-valve-cover-gasket-replacement.944082/
    P.S. The Red Sox just beat the Tampa Bay Devil Rays!! :bananadance::kona::rockband::taco::muscleflexing::broccoli:
  17. Oct 11, 2021 at 7:53 PM
    Knute
    @Hook78 sorry about that.......I thought the post was one of his.
  18. Oct 11, 2021 at 7:54 PM
    PennSilverTaco
    Charlie
    Just so we are clear, this is a lot less involved than replacing the head gasket, correct?
  19. Oct 11, 2021 at 7:59 PM
    Markcal
    Yes, the valve cover gasket doesn't keep the coolant separated from the oil, it sits on top of the engine, and when you see too much oil seeping it's time to do the replacement, mine has gotten that bad yet.
  20. Oct 11, 2021 at 8:00 PM
    PennSilverTaco
    Charlie
    I don't see oil seeping, but in order to nip this in the bud before 150K, I'd have my mechanic put a new valve cover gasket in!
