PennSilverTaco's "Perfect 5-Lug Regular Cab" Build, Aspergers, and General BS MegaThread!
Discussion in '2nd Gen. Builds (2005-2015)' started by PennSilverTaco, Jul 15, 2014.
  1. Nov 21, 2021 at 9:09 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I am cheap too lol, but do the majority of stuff by myself so had to get those.
    6 gearT444E[QUOTED] likes this.
  2. Nov 21, 2021 at 9:15 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    what i figured out worked well for my offroad model with hydraulic brake booster was to jam a board between the brake pedal and seat, push the power seat all the way forward. Turn ignition to “on” and the hydraulic pump does all the work; just open and close the bleeder valve, check level in between each wheel cylinder bleeding. But for most other cars I’m on my own, but too cheap to buy something of that nature so i draw the vacuum by hand.
    shakerhood[QUOTED] likes this.
  3. Nov 21, 2021 at 9:18 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Yes, I did leave out a very important part.
    DO NOT let the reservoir go dry.
    I usually let my buddy keep an eye on that too.
    Since I’m lazy, and don’t want to have to keep getting up off the ground.
    And……he’s closer. :rofl:
  4. Nov 21, 2021 at 9:19 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    reservoir goes dry= start over from step 1. :oops:
    shakerhood likes this.
  5. Nov 21, 2021 at 9:21 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
  6. Nov 21, 2021 at 9:25 PM
    TnShooter
    Deogee
    STOCK
    No.
    If that happens, old step 1, becomes new step 2.
    New step 1. Throw things, cuss, throw a good soul cleansing fit.
    The more incoherent and irrational your fit of rage is, the better.
  7. Nov 21, 2021 at 9:28 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    New step 0, go buy more beer and brake fluid :D
    shakerhood and TnShooter[QUOTED] like this.
  8. Nov 22, 2021 at 3:16 AM
    6 gearT444E
    Deep South
    Herculiner Hootus
    you may, but have to go out of your way to ask. Even the bare bones packages sometimes contain power windows/locks these days. The work truck trims usually have vinyl floors and manual everything. Now that kids can’t figure out transmissions I think they only come with automatics in base unfortunately.
  9. Nov 22, 2021 at 7:38 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Allow me to add a couple subtle points.
    When your buddy has the pedal on the floor....they need to HOLD the pedal on the floor UNTIL you have the bleeder closed.
    You can build a communication rhythm.
    Buddy when pedal is "hard" says, "Open"
    You open bleeder.
    Buddy says "Floor"
    You close bleeder say, "Closed"
    Repeat,....
    Begin with the longest brake line. I think this is the Driver's side rear wheel. Then Passenger Rear, Driver Front, Passenger Front.
  10. Nov 22, 2021 at 10:17 AM
    Taco 422
    Taco 422 Well-Known Member
    USA
    Gen 2 AC v6 TRD SR5 Prerunner
    Grease the nipple if you're using a vacuum - it'll cut the air bubbles from the threads out of the mix.
    I just got the tip on youtube last night, I'm going to try it in a little bit this morning.
    eherlihy and steelcity2 like this.
  11. Nov 22, 2021 at 12:14 PM
    PennSilverTaco
    PennSilverTaco [OP] Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    I pick her up within the hour!
  12. Nov 22, 2021 at 1:26 PM
    burrito782
    burrito782 Shit Throwing Ape
    08 TRD Off Road
    Allow me to add a subtle change to the communication rhythm. Instead of saying "Open" when the pedal is hard, Buddy says, "HOOCHIE MAMA!!!" @6 gearT444E you concur/approve?
  13. Nov 22, 2021 at 1:27 PM
    Taco 422
    USA
    I spent the last half hour using a vacuum bleeder pissed off at the world, anything that would make me laugh like that is a welcome change the bleeding the brakes.
  14. Nov 22, 2021 at 3:48 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    perfect!
  15. Nov 22, 2021 at 5:33 PM
    Red Alert
    Red Alert Well-Known Member
    CT
    2020 Tacoma SX 3.5 4x4 BRM AC
  16. Nov 22, 2021 at 6:09 PM
    PennSilverTaco
    Charlie
    Everything on the truck works fine, though apparently they replaced my leaf springs as part of the frame recalls and I didn't know this was going to be the case...
    Taco critter likes this.
  17. Nov 22, 2021 at 6:15 PM
    PennSilverTaco
    Charlie
    What? It's all done, though my friend seems to think that it's higher off the ground than it was before the frame got replaced; Maybe the new Bilsteins make it look higher?
  18. Nov 22, 2021 at 6:17 PM
    PennSilverTaco
    Charlie
    The truck is back; It may need a front end alignment, but other than all is good!
  19. Nov 22, 2021 at 6:28 PM
    TnShooter
    Deogee
    STOCK
    What did you/they decided on the springs?
    Personally, I never knew they were side specific.
    I had my springs replaced under the TSB.
    Still haven’t crawled under to see if they are correct. (That should tell you how I feel about it)
  20. Nov 22, 2021 at 6:28 PM
    burrito782
    08 TRD Off Road
    Yup, for the frame replacement the 2WDs get new leafs while the 4WD/Prerunners don't.
