PennSilverTaco's "Perfect 5-Lug Regular Cab" Build, Aspergers, and General BS MegaThread!
Discussion in '2nd Gen. Builds (2005-2015)' started by PennSilverTaco, Jul 15, 2014.
  1. Dec 11, 2021 at 1:37 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Could be a short or a bad ground somewhere
    TRDSport10 and shakerhood like this.
  2. Dec 11, 2021 at 1:38 PM
    PennSilverTaco
    PennSilverTaco [OP] Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    At 142K miles, I don't see how it could be anything but the alternator; A bad ground is not going to cause that many systems to fail...
    Kolter45 likes this.
  3. Dec 11, 2021 at 1:46 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Until you gather data you can’t definitively say. Plus it’s a lot faster.
  4. Dec 11, 2021 at 1:48 PM
    PennSilverTaco
    Charlie
    I also do not have a multimeter; Gonna ask for one for Christmas though!
    shakerhood likes this.
  5. Dec 11, 2021 at 1:56 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    A possible bad ground or loose wire crosses my mind too, especially since you had the frame swap. Hoping it is something simple like the alternator or battery though. Definitely ask for a meter for Christmas, got one for the ex gf's son cause l am tired of him always borrowing mine for extended periods of time.
  6. Dec 11, 2021 at 1:57 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    I thought you took it to AutoZone to get the alt tested? Call them, they may loan out a tester.
    At that mileage, if replacing the alt, minus well replace the serpentine belt and check the idler pulleys very carefully, or just replace them while you are at it. 4 cyl? Looks like your alt has a decoupler pulley. Those tend to seize and burn out the alt. That happened to our Lexus ES350 at about the same mileage. The decouple should be replaced at 100K. They are about $40-$90, plus you need the tool adapter.
  7. Dec 11, 2021 at 1:58 PM
    PennSilverTaco
    Charlie
    Did you read the above posts? 99.9% sure that it is the alternator; I have a "new" remanufactured" one ready to go!
    shakerhood[QUOTED] likes this.
  8. Dec 11, 2021 at 1:59 PM
    PennSilverTaco
    Charlie
    The belt was replaced in like October, right before the frame was replaced; Will have to check on the pulleys...
  9. Dec 11, 2021 at 2:03 PM
    shakerhood
    Southern Ohio
    I did, but once you test everything out you can be sure.
  10. Dec 11, 2021 at 3:15 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    You just had a frame replacement so who knows. I have a friend who had his frame replaced a couple of years ago. He says it seems like his rig as never been the same. Just nickle and dime shit ever since. A loose something here, a creaking thing there, CELs every few months. He said he always finding a wire pitched somewhere or a bolt not tight or even missing
    tacotoe, shakerhood and burrito782 like this.
  11. Dec 11, 2021 at 3:47 PM
    burrito782
    burrito782 Shit Throwing Ape
    08 TRD Off Road
    I was thinking the same thing about OP having the frame replaced recently.
  12. Dec 11, 2021 at 5:19 PM
    PennSilverTaco
    Charlie
    And the dealer wanted over $500 just for an alternator; I don't even want to think about what they'd charge to install one! I got one for $280 at AutoZone and I'm gonna get $60 back for returning the old one in the box; I know dealers always overcharge and we seeing record inflation, but this time I legitimately they're :rasta:
    tacotoe likes this.
  13. Dec 11, 2021 at 5:21 PM
    PennSilverTaco
    Charlie
    You're not thinking it's time for a new truck, are you? I can't afford a new truck. My truck has actually been really good since the frame replacement, and at 142K I'm thinking it was just time for the alternator to go...
  14. Dec 11, 2021 at 5:27 PM
    Red Alert
    Red Alert Well-Known Member
    CT
    2020 Tacoma SX 3.5 4x4 BRM AC
    You better get that Subaru back & fix it up
    JK
    :D
    Don't panic. Wait for the diagnosis.
    PennSilverTaco[OP] likes this.
  15. Dec 11, 2021 at 5:31 PM
    PennSilverTaco
    Charlie
    @ColoradoTJ
    @shakerhood
    @Taco critter
    After I bought the new alternator, I was in a rush to get the truck home because systems were starting to shut down; The HVAC wasn't working, the radio wasn't working (which means the Bluetooth wasn't working either), the ABS and traction control lights were, and on the way to buy the alternator it actually felt like the truck lost power under acceleration at one point.
    I noticed that my friend had texted me wanting to hang out, and I realized that his more-mechanically-inclined-than me dad could possibly help me put the alternator in; I called him as I was leaving the parking lot, and a woman in a blue SUV happened to be turning into the parking of the adjacent restaurant as I was leaving...
    She is what is known in North America as a "Karen"!
    wilcam47, shakerhood and ColoradoTJ like this.
  16. Dec 11, 2021 at 5:32 PM
    PennSilverTaco
    Charlie
    The building circled in red is the AutoZone I bought the alternator at...
  17. Dec 11, 2021 at 5:34 PM
    PennSilverTaco
    Charlie
    The property where the AutoZone is located shares it's rear exit onto Kansas Road with the Chickie's and Pete's restaurant next door (seen in the upper part of the screenshot); The red line shows the path I took when leaving the AutoZone to ultimately head home...
  18. Dec 11, 2021 at 5:39 PM
    PennSilverTaco
    Charlie
    Again, the red line shows the path I was taking to leave the AutoZone and go home; The first blue line represents the lady coming into the restaurant parking lot, the blue X represents where stopped to bitch at me for being on my phone while driving (For the record, it is not illegal to be talking on a cell phone while driving in Pennsylvania, and my Bluetooth wasn't working since the radio had shut down due to the alternator giving out), and the second blue line shows the path she took after our less-than-friendly exchange of words...
  19. Dec 11, 2021 at 5:50 PM
    PennSilverTaco
    Charlie
    I do not know which way the woman was coming from on Kansas Road, but I think it was the path illustrated by the blue line below. An accident did not almost occur, and I probably should've stopped for a bit longer, but I was in a rush to get my truck home before it died altogether and a reasonable person would have fully understood if they'd let explain myself; I say again that, (A) my truck was having electrical problems that could cause it to totally die and I needed to get it home, (B) my Bluetooth was not functioning because the radio had shut off due to the the aforementioned electric problems, and (C) I was making a call to my friend's dad could potentially help me address those electrical problems...
    But no, this Karen had to shout "Get off your phone!" out of her her open window, and I was already understandably not in good mood, so her unwanted commentary set me off in a way that it normally would not have in the presence of a woman especially under those circumstances...
    I screamed "Fuck you!" and she responded with "Fuck you harder!" before driving off; This was a middle aged woman, mind you...
    After hearing the story, my mom said that people really need to stop using the F-word so casually...
    Anyway, it is not against the law to talk on the phone while driving in PA, no accident occurred (nor did it almost occur), and the woman knew absolutely nothing about me or my situation...
    wilcam47 and shakerhood like this.
  20. Dec 11, 2021 at 5:54 PM
    PennSilverTaco
    Charlie
    Let's see here; I'm a guy with autism who needs to get his truck home because it is literally dying, is a bit preoccupied as a result, and is trying to contact someone who can possibly fix said truck. I say again that using a cell phone without a handsfree device is not illegal in Pennsylvania, and my Bluetooth was not functioning due to the aforementioned electrical problems...
    Kindly stick your opinion up your ass and mind your own business, PLEASE!
    ABA180, wilcam47 and shakerhood like this.
