PennSilverTaco's "Perfect 5-Lug Regular Cab" Build, Aspergers, and General BS MegaThread!
Discussion in '2nd Gen. Builds (2005-2015)' started by PennSilverTaco, Jul 15, 2014.
  1. Mar 6, 2022 at 9:41 PM
    PennSilverTaco
    PennSilverTaco [OP] Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    And this is the "inside" of the garage with the aforementioned "Jiffy Lube oil change pit"...
  2. Mar 6, 2022 at 9:44 PM
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    Well as a historical archaeologist I can tell you two ways to help find the answer to your question.
    1) go to the documentary evidence. Look at old property maps, and follow the chain of title
    2) dig for residential refuse. This would require a permit. Your surface survey yielded only materials related to the tire shop. Its more than likely it was only a mechanic shop. A closer examination of the surface level artifacts might uncover some materials more associated residential sites.
    PennSilverTaco[OP] likes this.
  3. Mar 6, 2022 at 9:47 PM
    PennSilverTaco
    Charlie
    Bringing broken and/or obsolete TVs into the woods surrounding Centralia and then totally destroying them seems to be a tradition of sorts based on what I've read online, and I've lost count of how many TV carcasses I've found combined on both trips; This old Zenith appears to be over 40 years old. As such, I do not know if it was left behind 25 to 30 years ago by the last owner of the property, or if bored kids brought it up here in the last one or two decades and destroyed it. The amount of rust on the metal parts would indicate that it has been here for well over a decade...
  4. Mar 6, 2022 at 9:48 PM
    PennSilverTaco
    Charlie
    When you say title, do you mean the deed to the property?
  5. Mar 6, 2022 at 9:49 PM
    PennSilverTaco
    Charlie
  6. Mar 6, 2022 at 9:51 PM
    PennSilverTaco
    Charlie
    Inside the pit; I've seen plenty of houses with professional-style hydraulic lifts in the garage, but I've never seen a professional style oil changing pit like this one in a residential building, which further points towards a commercial property like a garage or gas station...
  7. Mar 6, 2022 at 9:53 PM
    boston23
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    Yeah exactly. These property titles are publicly available. You can go to the county courthouse (or other administrative type of building-not always the courthouse) and ask to look through the archives. Unless you have a reliably old street address you’ll need to start by looking at historic property maps, find the spot, then search for the deed. Each dead references the previous deed and previous owners. You then search that document and so on. This is called a chain of title search. You can find out some really interesting stuff this way.
  8. Mar 6, 2022 at 9:54 PM
    boston23
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    Red Alert and PennSilverTaco[OP] like this.
  9. Mar 6, 2022 at 9:57 PM
    PennSilverTaco
    Charlie
    It is also entirely possible that this building had been collapsing prior to 1993, and that it was part of a residential property; The stretch of State Route 61 that was shut down and bypassed in the 1990s due to the underground mine fire is not far behind this property. One likely scenario is that the main house was demolished, but the government didn't bother to fully demolish this building since nature did most of the job for them...
  10. Mar 6, 2022 at 10:01 PM
    PennSilverTaco
    Charlie
    So all of this is public record, and that info is at the Columbia County Courthouse? What sucks is that there is no address visible on the property, so I'd have to point it out to some county employee on a map...
  11. Mar 6, 2022 at 10:01 PM
    PennSilverTaco
    Charlie
  12. Mar 6, 2022 at 10:01 PM
    boston23
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    Often, when government funding is involved in demolition, the gov’t won’t touch environmental hazard sites. It opens up a whole can of worms with environmental compliance and EPA regs. So a place full of motor oil etc, could have been left to rot because it was cheaper than dealing with it. Happens all too often
  13. Mar 6, 2022 at 10:04 PM
    PennSilverTaco
    Charlie
    There are some ghost towns where vehicles were left in garages and they still sit there decades later, in obvious need of mechanical repairs if they are to be made roadworthy again, but in one piece and remarkably well preserved; Picher, Oklahoma is one such place...
    Unfortunately, Centralia does not have any derelict vehicles in areas open to the public, because automotive archeology is something I truly enjoy!
  14. Mar 6, 2022 at 10:06 PM
    PennSilverTaco
    Charlie
    This garage is rather rudimentary in design and looks like it could have been built in the 1940s, though the old Zenith TV is obviously a bit newer than that...
  15. Mar 6, 2022 at 10:07 PM
    PennSilverTaco
    Charlie
    This place honestly looks like it fell into disrepair years before the entire Borough of Centralia was declared eminent domain (which was in 1993)...
  16. Mar 6, 2022 at 10:08 PM
    PennSilverTaco
    Charlie
    Yet another obvious clue that this was a garage... :D
  17. Mar 6, 2022 at 10:09 PM
    Red Alert
    Red Alert Well-Known Member
    CT
    2020 Tacoma SX 3.5 4x4 BRM AC
    That's why suggestions by local folks to perhaps turn it into a National Historic Site fell on deaf ears. All those visitors & the area could sorely use tourist $$$. The powers that be won't touch it & have been passing the buck for decades. An open air graffiti-ridden garbage pit. An utter disgrace.
  18. Mar 6, 2022 at 10:10 PM
    PennSilverTaco
    Charlie
  19. Mar 6, 2022 at 10:11 PM
    PennSilverTaco
    Charlie
  20. Mar 6, 2022 at 10:12 PM
    PennSilverTaco
    Charlie
    You know a TV is old when it only has one speaker!
