PennSilverTaco's "Perfect 5-Lug Regular Cab" Build, Aspergers, and General BS MegaThread!
Discussion in '2nd Gen. Builds (2005-2015)' started by PennSilverTaco, Jul 15, 2014.
  1. Apr 4, 2022 at 4:55 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I'm sure that would be less expensive but your truck still looks good. Would you beilieve l had the Mustang 24 years as of yesterday.
    RustyGreen likes this.
  2. Apr 6, 2022 at 5:02 PM
    shakerhood
    Southern Ohio
    I found a Sears receipt from 1961 buried in insulation in the attic today, thought it was kinda neat.
  3. Apr 6, 2022 at 5:29 PM
    PennSilverTaco
    PennSilverTaco [OP] Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    What year was your house built?
    shakerhood[QUOTED] likes this.
  4. Apr 6, 2022 at 6:00 PM
    shakerhood
    Southern Ohio
    I "think" l recall seeing something on a document the day of my closing that said 1950s.
  5. Apr 6, 2022 at 6:07 PM
    PennSilverTaco
    Charlie
    In 1961, I don't even think the Berlin Wall had been built yet!
    shakerhood[QUOTED] and wilcam47 like this.
  6. Apr 6, 2022 at 6:30 PM
    shakerhood
    Southern Ohio
    That paper is in such good shape considering it's been in the attic for 60 years.
  7. Apr 6, 2022 at 9:06 PM
    PennSilverTaco
    Charlie
    Actually, I looked it up; The Berlin Wall was constructed starting in 1961...
  8. Apr 6, 2022 at 9:13 PM
    shakerhood
    Southern Ohio
    That is very interesting, thinking how long that paper was up there my Dad would have been in his early 20's and my Mom a Teenager.
  9. Apr 6, 2022 at 10:24 PM
    bebo_junker
    bebo_junker Well-Known Member
    Western Mass
    '05 X-Runner - '06 SR5 RC - '07 TRD Sport AC
    Black Ice Little Trees
    :rasta::rasta::rasta::rofl:
  10. Apr 7, 2022 at 5:35 AM
    PennSilverTaco
    Charlie
    My dad would have been a baby!
  11. Apr 7, 2022 at 6:38 AM
    PennSilverTaco
    Charlie
    Last Friday, the CEL came on; A scan revealed it was an ignition coil. I wanted all four replaced, but my mechanic could only get two on such short notice. He replaced them and got the CEL to go out. The CEL was out for about a day before it came on. I got the other two this past Monday; The CEL went out on its this time.
    No CEL at the moment, but the engine misfired when I started it this morning. It quickly went away. I am sitting in the truck with the engine running as I type this, and it feels like the truck is vibrating a bit more than normal.
    My truck has the 2.7L 2TR-FE, and current odometer reading is 147,554 miles; I have owned the truck since new and obsessively maintained it the whole time.
    Likely gonna have to leave it with my mechanic overnight at some point, as he says there's literally a million that could be causing this, but I wanted to get an opinion here too; Also, I'm going to a few car shows this weekend and can't be sans truck!
  12. Apr 7, 2022 at 6:48 AM
    PennSilverTaco
    Charlie
    UPDATE: Dropping it off at the shop of Pete (my mechanic) on Sunday night so he can look at it on Monday; I do not have work on Monday and there are no car shows.
  13. Apr 7, 2022 at 6:52 AM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    Look at plugs. How old. What kind?
    Stick with Denso for plugs. And just because a coil is new. Does not mean it works. Test out
    Kolter45 and PennSilverTaco[OP] like this.
  14. Apr 7, 2022 at 6:57 AM
    PennSilverTaco
    Charlie
    Spark plugs were replaced in October 2021 and have like 7,000-8,000 miles on them, and they are Denso; I actually bought them at the dealership and my friend helped me put them in! How do you test a coil? Would it still be throwing codes if the CEL isn't on?
  15. Apr 7, 2022 at 9:03 AM
    Geeves77
    Mark
    Northeast
    2011 Tacoma DCSB
    Are usually do it you start the truck, and then you go to each coil and unplug it to see if you hear a difference in the engine because you lost a cylinder, if you pull the plug in the engine doesn’t change then you have a bad coil in that cylinder
    PennSilverTaco[OP] likes this.
  16. Apr 7, 2022 at 9:07 AM
    PennSilverTaco
    Charlie
    So you're thinking that one more of these coils is a dud?
  17. Apr 7, 2022 at 9:56 AM
    shakerhood
    Southern Ohio
    Me either!
  18. Apr 7, 2022 at 10:03 AM
    Geeves77
    Mark
    Northeast
    2011 Tacoma DCSB
    1. Could be. Easy to check
    2. But I’ll let the pros in on this one also
  19. Apr 7, 2022 at 10:04 AM
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    OEM coils?
  20. Apr 7, 2022 at 10:08 AM
    Kmart6
    Kmart6 An Average Joe
    MD
    08 2.7 5spd
    Does it only misfire on a warm startup. 2tr-fe here and had a leaky injector and my truck would misfire only on warm starts. Swapped coils and spark plugs but only went away after replacing injector
