PennSilverTaco's "Perfect 5-Lug Regular Cab" Build, Aspergers, and General BS MegaThread!
Discussion in '2nd Gen. Builds (2005-2015)' started by PennSilverTaco, Jul 15, 2014.
  1. Sep 7, 2022 at 4:10 PM
    PennSilverTaco
    PennSilverTaco [OP] Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    I got the flag set up for this weekend!
    57E01B9C-A118-4C5C-B8EA-53235F7BF8C2.jpg 3E196D05-E340-47EE-9B4A-586FBE036202.jpg
    98tacoma27, Taco critter and wilcam47 like this.
  2. Sep 7, 2022 at 4:17 PM
    clenkeit
    clenkeit Well-Known Member
    Colin
    Lakewood, CA
    2010 White DCLB TRD Sport
    Don't even worry about it in the slightest. Mileage doesn't matter so long as the truck is well maintained and functioning as it should. I've got 200k miles on mine and have regularly been in 100+ weather out here in the CA/AZ deserts. Always with the AC blasting too. No problem with high speeds (it's actually lower speeds you probably have to worry about due to reduced airflow.)
    Only time I ever had an overheating problem was while lugging very slowly up a steep incline over 6-10" boulders trying to keep a smooth and steady ride for our gear and passengers. It was only warm, maybe 80 deg and high altitude (thin air). I was going to upgrade the radiator after that but when I went to do the install I found a 12" diameter blockage between my radiator and condenser - it was dog hair. Cleared the blockage and haven't had a problem since.
    PennSilverTaco[OP] likes this.
  3. Sep 7, 2022 at 4:18 PM
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    Here is Sacramento, 116 yesterday.
    This was a 10-15 min drive to the lake to get the dogs out.
    Usally the engine temp would be 185…rarely go over that.
    transmission would be at max like 130 on the drive to the lake. Yesterday was a little warm for the truck.
    Takes a while for the ac to cool down the truck as well.
  4. Sep 7, 2022 at 4:18 PM
    PennSilverTaco
    Charlie
    I've talked to a couple older people who described having to crank the heat when driving through Death Valley to keep the radiator from boiling over. Obviously, vehicles have come a long way in the last 50-60 years!
  5. Sep 7, 2022 at 4:20 PM
    eon_blue
    Azusa, CA
    They have signs all over the state for cars to shut off their AC when going up steep highway grades, I've never had any issue though. Its more of a precaution for people in vehicles that might be poorly maintained or already suffering from a cooling issue.
  6. Sep 7, 2022 at 4:22 PM
    Ricardo13x
    Ricardo13x YT: @UrbanOpsOffRoad IG: @urban.ops.offroad
    Upland, CA.
    05 OR DCSB ProRunner(4x4 conv.), Chevy 63”s, NWF EcoCrawler, 35”s
    Random stuff. Oh! and converted to non ADD 4x4.
    I’m from Imperial Valley/Mexicali desert. Tacomas run just fine with the AC on when there are no maintenance issues with your truck(such as leaks, coolant pump issues, damaged radiator, etc.)
  7. Sep 7, 2022 at 4:24 PM
    PennSilverTaco
    Charlie
    On another note, I had the water pump in my truck replaced when the dealer replaced my frame last November with about 140K miles on the clock, as preventative maintenance...
  8. Sep 7, 2022 at 4:53 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Nice!:oldglory:
  9. Sep 7, 2022 at 5:17 PM
    PennSilverTaco
    Charlie
    This was just a dry run; I'm not driving around with them on the truck until Friday...
    wilcam47[QUOTED] likes this.
  10. Sep 7, 2022 at 5:27 PM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    I drive mine almost daily. Rush hour on the way home stop and go for an hour in 110. All systems go! AC blowing cold no overheating.
    10thMTNgrunt likes this.
  11. Sep 7, 2022 at 5:31 PM
    10thMTNgrunt
    10thMTNgrunt This is the way, step inside.
    2013 TRD Sport
    Which scan gauge is that?
  12. Sep 7, 2022 at 5:35 PM
    kairo
    kairo >_>
    Nor Nev
    '20 OR DCLB Quicksand
    You won't have any issues with any modern vehicle even in death valley even sitting at idle with the A/C on.
    I didn't even have issues with my '79 F150 in 100+ temps crawling in the desert (Aside from myself being incredibly uncomfortable in the cab lol)
    Modern cars are built to work basically anywhere that anybody might like to own one. A lot of people live in very hot and very cold places.
  13. Sep 7, 2022 at 5:36 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I removed the rubber weatherstrip at the base of the windshield to let hot air out and cooler air in. My first truck mod, actually
  14. Sep 7, 2022 at 5:37 PM
    Boco10
    Boco10 Well-Known Member
    ADK
    Last week I had to turn around in Utah on my way to Vegas. I had a dog with me, so I had to run AC. My NY truck did not like the heat or the elevation. Getting back home through Colorada was a 6-hour adventure. Hell of a time for the water pump to go.
  15. Sep 7, 2022 at 5:40 PM
    PennSilverTaco
    Charlie
    I'm guessing the 1979 F150 doesn't have A/C?
  16. Sep 7, 2022 at 5:41 PM
    kairo
    kairo >_>
    Nor Nev
    It did not lol. But it had a .060 bored 351m and a 7.1 first gear with a 4:1 transfer case. It did a lot of low speed, high RPM work and it held up fine.
  17. Sep 7, 2022 at 5:43 PM
    dblwall
    dblwall Active Member
    Az
    2012 TRD Sport
    In Arizona last year we had 40 straight days of at least 110*, never missed a beat. I know it's hot when I go to start my truck, turn the key to the on position and I can see the temp gauge move.
    MGMDesertTaco and kairo like this.
  18. Sep 7, 2022 at 5:46 PM
    kairo
    kairo >_>
    Nor Nev
    "Oh, so it's one of THOSE days"
    Yah, we get those here too lol
    Alexely999 likes this.
  19. Sep 7, 2022 at 5:49 PM
    kairo
    kairo >_>
    Nor Nev
    A joke? On an internet forum? Well I've never
  20. Sep 7, 2022 at 5:53 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    My 1984 Monte Carlo was one I had to run the heat in the summer occasionally when it ran hot, and that's in MA which isn't exactly scorching. Flow and fans were okay, just how it was back then.
    Ultragauge but I can't tell which version
