PennSilverTaco's "Perfect 5-Lug Regular Cab" Build, Aspergers, and General BS MegaThread!
Discussion in '2nd Gen. Builds (2005-2015)' started by PennSilverTaco, Jul 15, 2014.
  1. Sep 7, 2022 at 11:44 PM
    carmellocafe
    carmellocafe Begin With The End In Mind.
    KEVIN
    N. California
    2014 TRD OR Access cab longbed
    117F yesterday in Tehama county. Drove around town w/ac blasting. Only thing i noticed was the suspension/tires felt a little “spongy.” Water temp. Reached 196. Truck ran fine, but i probably wouldn’t tow anything on days like this. 2014 OR well maintained. It’s hotter than the hinges on the gates into hell in northern ca. right now. Always looking for the east side of buildings to park.
    PennSilverTaco[OP] likes this.
  2. Sep 8, 2022 at 12:43 AM
    hoffengineering
    hoffengineering Well-Known Member
    Taylor
    Orange County, California
    2015 DCLB 4X4
    I typically notice the trans temps getting higher than I'd like before the engine coolant does. That being said, I've driven my Tacoma through steep grades in 105+ deg weather in the Nevada desert with 1000+ lbs in the truck and the AC blasting the whole time and it was never an issue. Trans temps got a little high, but nowhere near anything I would consider risky or worrisome. Although I have flushed the trans and added an aftermarket cooler since then to keep temps down.
    Also drove my POS '98 Audi through the Arizona desert where it reached over 110 deg not too long ago. AC blasting, tunes up, and no issues.
    As long as your cooling system is in good working order you should be fine, just keep an eye on your temps. If you don't have a way to monitor trans temp, just make sure the torque converter stays locked while you're driving.
  3. Sep 8, 2022 at 7:27 AM
    PennSilverTaco
    PennSilverTaco [OP] Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    I don't recall it ever being this hot when we lived on base in the late 1990s!
    72AAC09E-BEDE-45D2-B3AE-15B6A7371300.jpg 411DE5F9-A204-455C-8B5B-4C203918849B.jpg
  4. Sep 8, 2022 at 7:29 AM
    PennSilverTaco
    Charlie
  5. Sep 8, 2022 at 7:47 AM
    PennSilverTaco
    Charlie
    shakerhood and wilcam47 like this.
  6. Sep 8, 2022 at 8:05 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
  7. Sep 8, 2022 at 8:17 AM
    PennSilverTaco
    Charlie
    It's partially buried, so it would be very easy to keep cool. Also, note the location of the furnace; I can't imagine it being particularly easy to run ductwork for a central HVAC system with all the sloped ceilings, so I'd do a gas or oil boiler, and Mitsubishi Mr. Slim ductless mini-split heat pumps for A/C and backup heat.
    shakerhood likes this.
  8. Sep 8, 2022 at 8:51 AM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    My view of houses is more pragmatic than style driven.
    If I was building my forever home it would have the simplest and steepest roof line possible.
    The #1 problem with home ownership is water intrusion, look at all the transitions and areas where the roof meets a wall in that plan, 15 years down the road those start becoming expensive to repair problems.
    EDIT: And the garage isn't nearly big enough. :laugh:
  9. Sep 8, 2022 at 10:24 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
  10. Sep 8, 2022 at 10:29 AM
    98tacoma27
    Ben
    Not Beech Creek
    That's a no for me. I don't like how the bedroom opens right into the family room.
    RustyGreen and Taco critter like this.
  11. Sep 8, 2022 at 10:33 AM
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    Running HVAC wouldn't be an issue at all. I've been on plenty of roofs that are steep and way more cut up, 70+ facets. With that one being 6 facets and not steep it wouldn't be a problem.
  12. Sep 8, 2022 at 10:34 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Yes. The A/C light started blinking and the coolant temp quickly climbed to 217°and I felt it would keep going, then overheat. That's when I turned the A/C off, rolled down the windows, and dealt with the heat. The temp stabilized at 212°.
    I think it was in the mid to high 120's that year in Death Valley.
  13. Sep 8, 2022 at 10:35 AM
    PennSilverTaco
    Charlie
    @Torspd
    I think you quoted your own post...
    Torspd[QUOTED] likes this.
  14. Sep 8, 2022 at 10:45 AM
    PennSilverTaco
    Charlie
    They didn't have Maul...
  15. Sep 8, 2022 at 10:46 AM
    PennSilverTaco
    Charlie
    Did anyone else hear the news? Queen Elizabeth just passed away; I think it's a bad omen....
  16. Sep 8, 2022 at 10:53 AM
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    I think we’re good. :)
    72FA7739-2DD9-4FB3-A414-CBC394999EC8.jpg F5617D6E-6162-4095-BE54-BC74DD6D2A27.jpg
  17. Sep 8, 2022 at 10:58 AM
    PennSilverTaco
    Charlie
    I've read that story and can't believe the insurance company totaled the truck; I would have wanted it repaired and returned to me. I ran the license plate through Carfax and the truck now has a salvage title, but from what I can tell it was repaired and someone is actually driving it now...
  18. Sep 8, 2022 at 10:58 AM
    PennSilverTaco
    Charlie
    I have mad respect for Queen Elizabeth!
    wilcam47 and Taco critter like this.
  19. Sep 8, 2022 at 11:18 AM
    shakerhood
    Southern Ohio
    I heard that on the radio about 30 minutes ago, guess that Prince Charles character takes over her spot.
  20. Sep 8, 2022 at 11:19 AM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Same, function first. My bathroom had a skylight and I just knew the day would arrive it would leak, I said first time it leaks it's gone. Definitely relate to steep roof..mine in the back is shallow and ice dams were an issue until I went metal
    A shame
