PennSilverTaco's "Perfect 5-Lug Regular Cab" Build, Aspergers, and General BS MegaThread!
Discussion in '2nd Gen. Builds (2005-2015)' started by PennSilverTaco, Jul 15, 2014.
  1. Oct 10, 2022 at 8:55 AM
    PennSilverTaco
    PennSilverTaco [OP] Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    Neither did I. The truck runs great!
    Taco critter likes this.
  2. Oct 10, 2022 at 9:24 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  3. Oct 10, 2022 at 9:48 AM
    Just_A_Guy
    Just_A_Guy Rain is a good thing
    On the hunt
    A truck
  4. Oct 10, 2022 at 10:26 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
  5. Oct 10, 2022 at 1:27 PM
    PennSilverTaco
    Charlie
    The engine is in great shape, and the head gasket has failed in such a way that more oil is being released into the coolant rather than the other way around; I am not getting a new engine. However, I did not budget for this big of a job and my dad is going to have to help me pay for it.
  6. Oct 10, 2022 at 1:38 PM
    PennSilverTaco
    Charlie
    Don't remind me...
    Keep the original engine though? It would be fun to do a 4.0L swap, but that would require replacing the transmission and computer as well...
    shakerhood and Taco critter like this.
  7. Oct 10, 2022 at 1:41 PM
    shakerhood
    Southern Ohio
    Yeah in a case like that it's less expensive to just get a different truck
  8. Oct 10, 2022 at 1:42 PM
    shakerhood
    Southern Ohio
    Hopefully not too pricey.
  9. Oct 10, 2022 at 3:03 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Oof. That's why I mentioned it yesterday. You're showing signs of a small head gasket leak or head crack. If that's what it is, it will only get worse....to the point where engine failure would be imminent. I suspect it was comprised when it initially overheated and continued to worsen over the last couple of weeks.
    When you shut the truck off at your friend's house there was immediate heat soak. That's why your gauge pegged when you started it.
    Keep the driving to an absolute minimum. Eventually it will get bad enough to allow compression from the cylinders to pulse through the cooling system. Only bad things happen after that. Also, enough coolant in the oil can lead to all sorts of nasy things....spun crank bearings, scored cylinder walls, etc.
  10. Oct 10, 2022 at 3:54 PM
    steelcity2
    steelcity2 Well-Known Member
    Pittsburgh Pa
    2013 MGM DCSB TRD sport
    Bilsteins 5100's all 4 corners 1 inch rear spacer
    Dang bro , sorry to hear. Well that will put an end to the mystery. She'll be ole reliable again. :thumbsup:
    RustyGreen and Taco critter like this.
  11. Oct 10, 2022 at 3:56 PM
    PennSilverTaco
    Charlie
    We are probably going to fix it, sell it, and buy a 3rd Gen...
  12. Oct 10, 2022 at 4:03 PM
    Just_A_Guy
    On the hunt
    A truck
    The dark side awaits. I’ll send cookies as a 3rd gen initiation ritual.
  13. Oct 10, 2022 at 4:05 PM
    steelcity2
    Pittsburgh Pa
    :eek: wow didn't expect that. 4wd?
  14. Oct 10, 2022 at 4:08 PM
    PennSilverTaco
    Charlie
    My dad thinks it's more worthwhile to buy a newer vehicle; I can't afford a newer vehicle right now. I don't want anything but a truck. I refuse to replace my truck with a Shitsubishi Mirage.
  15. Oct 10, 2022 at 4:24 PM
    PennSilverTaco
    Charlie
    What the fuck else is gonna break? It's gonna be a money pit. My uncle said I should just sell it and not mention the head gasket...
  16. Oct 10, 2022 at 5:03 PM
    PennSilverTaco
    Charlie
    I am still confounded as to why a well-maintained 2TR-FE needs a major overhaul before 160K miles; I've always been OCD about maintenance.
    TnShooter likes this.
  17. Oct 10, 2022 at 5:17 PM
    Plain Jane Taco
    USA
    That would be really shitty
  18. Oct 10, 2022 at 5:18 PM
    Plain Jane Taco
    USA
    :notsure:
    shakerhood likes this.
  19. Oct 10, 2022 at 5:51 PM
    shakerhood
    Southern Ohio
    It would only be right if you made the buyer aware of the issue if it's not been repaired.
  20. Oct 10, 2022 at 5:55 PM
    PennSilverTaco
    Charlie
    I actually got pretty pissed at my uncle for saying that. My mechanic Petr did he'd pay like five grand for the truck as is, put a used low mileage engine in it, and resell it.
    My plan is to pay to fix the truck, drive it for six months to a year, then sell it privately and buy a 3rd Gen with what I've saved up. My truck is worth enough that it will be a suitable down payment.
