PennSilverTaco's "Perfect 5-Lug Regular Cab" Build, Aspergers, and General BS MegaThread!
Discussion in '2nd Gen. Builds (2005-2015)' started by PennSilverTaco, Jul 15, 2014.
  1. Nov 15, 2017 at 4:27 PM
    #5401
    PennSilverTaco
    PennSilverTaco [OP] Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    Found the Claas tractor on sale at Toys "R" Us, for almost $60 below MSRP!
    So, by the time I'm done with this, the Ferrari F40 should be here!
    Toyko Joe and Sear87[QUOTED] like this.
  2. Nov 15, 2017 at 4:47 PM
    #5402
    Sear87
    Sear87 YJ apologist
    KCMO
    2011 AC TRD-OR 6MT
    Nice find! The way they designed the steering mechanism is neat. Think of it as a gearbox with no gears.
  3. Nov 15, 2017 at 6:21 PM
    #5403
    PennSilverTaco
    Charlie
    It begins!
  4. Nov 15, 2017 at 6:49 PM
    #5404
    PennSilverTaco
    Charlie
    Is this part supposed to be pointed down?
  5. Nov 15, 2017 at 7:09 PM
    #5405
    Sear87
    Sear87 YJ apologist
    KCMO
    2011 AC TRD-OR 6MT
    If I'm looking at it right, that will be the actuator for the rear accessory (logging arm). You have it oriented correctly in your pic. Or were you referring to a specific part rather than the assembly?
    Edit: what you have appears correct per the instructions
  6. Nov 15, 2017 at 9:40 PM
    #5406
    PennSilverTaco
    Charlie
    It was bent downward, but I fixed it.
    This is where I am right now...
    Sear87[QUOTED] likes this.
  7. Nov 16, 2017 at 8:13 AM
    #5407
    Gr8fl
    Gr8fl Some rise, some fall, some climb.
    JK
    Central Bucks, PA
    17 Cement Pro, 20 MGM Land Cruiser
    My bad if that’s the case, saw it from a distance and thought he said it was a Pro. As my wife likes to say about me, “often wrong and never in doubt...”
  8. Nov 16, 2017 at 8:15 AM
    #5408
    Gr8fl
    JK
    Central Bucks, PA
    In fact some one was, my 15 year old was teaching my 12 year old and one of his buddies. Trust me, fairly atypical. More often than not they just punch each other.
  9. Nov 16, 2017 at 9:39 AM
    #5409
    PennSilverTaco
    Charlie
    @Sear87
    I was having a lot of trouble getting the battery-operated motor to fit. I tore the entire front half of the chassis down and plan on rebuilding when I get home work tonight.
    Did you encounter any problems? The gray rod didn't poke all the way through the gray gear, and the motor didn't fit.
  10. Nov 16, 2017 at 10:08 AM
    #5410
    Sear87
    Sear87 YJ apologist
    KCMO
    2011 AC TRD-OR 6MT
    I don't recall having any issues with this kit, but it's been a while since I built it and haven't torn it down yet.
    Are you referring to this area?
  11. Nov 16, 2017 at 10:08 AM
    #5411
    PennSilverTaco
    Charlie
    Yeah
  12. Nov 16, 2017 at 10:10 AM
    #5412
    PennSilverTaco
    Charlie
    Police DOT checkpoints are such an epidemic in Bucks County that a dedicated Facebook page was made!
  13. Nov 16, 2017 at 10:11 AM
    #5413
    Sear87
    Sear87 YJ apologist
    KCMO
    2011 AC TRD-OR 6MT
    Did everything turn out similar to that pic? It's a 5L axle running from the motor, through the gear and two supports, into a dark grey coupling. Kind of a tight area, might want to double check that all of the supports are in their proper location.
  14. Nov 16, 2017 at 10:17 AM
    #5414
    PennSilverTaco
    Charlie
    I took it all apart. The gear was where that little sliver of gray rod was...
  15. Nov 16, 2017 at 10:25 AM
    #5415
    Sear87
    Sear87 YJ apologist
    KCMO
    2011 AC TRD-OR 6MT
    Forgive me, but I guess I don't quite follow without a picture or something for more context. I can probably tear into mine a bit more after work if that'd help. Best I can say for now is pay close attention to specific part locations in the instructions. The way Lego prints them can sometimes mess you up if you don't give it more than a glance. More than once I've ended up back-tracking a ways because I had something only a hole or two off.
    PennSilverTaco[OP] likes this.
  16. Nov 16, 2017 at 10:27 AM
    #5416
    PennSilverTaco
    Charlie
    3rd Gen SR5 DCLB used as rolling billboard for a realtor.
    @HomerTaco @PROseur
    You guys know anything about those rims?
  17. Nov 16, 2017 at 10:28 AM
    #5417
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    wow no realtor here would be caught dead in a truck.
    Cayenne, Range Rover, S550 only around here....
  18. Nov 16, 2017 at 10:29 AM
    #5418
    PROseur
    Pussy
    Those are SR5 wheels
  19. Nov 16, 2017 at 10:30 AM
    #5419
    PennSilverTaco
    Charlie
    The matte black finish threw me off a bit. I thought the SR5 came with regular alloys.
  20. Nov 16, 2017 at 10:30 AM
    #5420
    PennSilverTaco
    Charlie
    Well, this realtor has a truck and wants everybody to know it!
    Only reason he didn't get an access cab is probably because he needs to drive clients around to look at houses.
