PennSilverTaco's "Perfect 5-Lug Regular Cab" Build, Aspergers, and General BS MegaThread!
Discussion in '2nd Gen. Builds (2005-2015)' started by PennSilverTaco, Jul 15, 2014.
  1. Nov 16, 2017 at 10:31 AM
    #5421
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
  2. Nov 16, 2017 at 10:42 AM
    #5422
    PennSilverTaco
    PennSilverTaco [OP] Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
  3. Nov 16, 2017 at 10:44 AM
    #5423
    PROseur
    Pussy
    Who buys used books in 2017?
  4. Nov 16, 2017 at 10:50 AM
    #5424
    PennSilverTaco
    Charlie
    There's supposed to be a little sliver of gray rod that goes into the motor. That was not present when I tried to put the motor on, so I ripped the entire front end apart and am going to rebuild it after work. You are probably correct about the way LEGO printed it. Similar stuff has happened to me before. If it is still the same way when I rebuild it, I will remember to take photos this time before I tear it apart and send them to you.
    When I built the Extreme Adventure 4x4, which was my first LEGO kit in about a decade, I built the front differential backwards; This meant that the tracks rolled in opposite directions from each other when turned and the truck couldn't roll on the ground. I had to tear the entire front diff and transfer case apart and rebuilt it. Cost me over an hour!
  5. Nov 16, 2017 at 10:56 AM
    #5425
    PennSilverTaco
    Charlie
    That place has been there for years. I bought a hardcover copy of Under the Dome there for next to nothing, back in like 2012 or 2013. With all your huge chain bookstores going under thanks to Amazon, the generic used book store is probably going to be doing even better...
    Gr8fl likes this.
  6. Nov 16, 2017 at 11:05 AM
    #5426
    Sear87
    Sear87 YJ apologist
    KCMO
    2011 AC TRD-OR 6MT
    Damnit, now you've got me curious. I was wrong, it's not a 5L axle, but a 4L tan axle with center stop. I don't see any grey piece that goes into the motor, but the 24-tooth gear below the motor output gear is on a dark grey axle. Is that what you're referring to?
  7. Nov 16, 2017 at 11:10 AM
    #5427
    uurx
    uurx Well-Known Member
    long island, new york
    '12 t|x pro
    cory02taco likes this.
  8. Nov 16, 2017 at 11:12 AM
    #5428
    PennSilverTaco
    Charlie
    This is one thing I've noticed a lot lately, and I'm not talking about even the newest Crown Vics...
    I'm talking about 2007-2014 Tahoes, 2007-2017 Expeditions, 2011-present Explorers, etc...
    The same goes for Tahoes and Expeditions used by fire departments and EMS...
    None of them have the backup camera in the usual spot above the rear license plate.
    I would think that a backup camera would be of great benefit to a LEO, especially when he or she has to abruptly floor it in reverse. Even more especially if he or she is in a very tight space.
    On my way to work today, I did see one of those new aluminum-bodied F150s. It belonged to the Warrington Township Police and was marked. It had a backup camera in the tailgate handle assembly. I also believe I've seen some 2015-present police Tahoes with backup cameras.
    That brings up my second question. Do police cars have rear-facing dashcams (not for the suspect in the backseat, but which are pointed out the rear window or mounted to the roof and pointed backwards?
    Also, the oldest police car I saw that was in still in operation was in Guthrie, Oklahoma; This was back in March 2014. It was a 1996-1998ish Crown Vic...
  9. Nov 16, 2017 at 11:13 AM
    #5429
    PennSilverTaco
    Charlie
    Yes
  10. Nov 16, 2017 at 11:18 AM
    #5430
    PennSilverTaco
    Charlie
    Are those real, or made from scratch?
  11. Nov 16, 2017 at 11:20 AM
    #5431
    98tacoma27
    Ben
    Not Beech Creek
    :wave:
    Mostly woodworking books as they have plans in them.
  12. Nov 16, 2017 at 11:22 AM
    #5432
    uurx
    '12 t|x pro
    not sure honestly, I google imaged "toyota lego" and those seemed like real ones out of the many pictured
  13. Nov 16, 2017 at 11:23 AM
    #5433
    Sear87
    Sear87 YJ apologist
    KCMO
    2011 AC TRD-OR 6MT
    Okay, that grey axle does not go into the motor.
    Those are someone's own builds
    uurx likes this.
  14. Nov 16, 2017 at 11:27 AM
    #5434
    PennSilverTaco
    Charlie
    Then why was I having so much trouble getting everything to fit? Every time I pushed the motor back part of the axle assembly would come off. Also, in the instructions, the gray rod protrudes slightly from the gear...
  15. Nov 16, 2017 at 11:27 AM
    #5435
    uurx
    '12 t|x pro
    Sear87 and PennSilverTaco[OP] like this.
  16. Nov 16, 2017 at 11:38 AM
    #5436
    Sear87
    Sear87 YJ apologist
    KCMO
    2011 AC TRD-OR 6MT
    Okay, now I see what you're talking about. Part of that axle does stick past the gear, as seen below in step 153. However, that is then covered by the motor bracket in step 163. If this isn't lining up or the axle protrudes too far, I'd double check the module it's built into (starts at step 94). If you've already figured this out, I'll shut up now.
  17. Nov 16, 2017 at 11:47 AM
    #5437
    PennSilverTaco
    Charlie
    Problem I had was that the axle didn't protrude far enough.
  18. Nov 16, 2017 at 11:54 AM
    #5438
    Sear87
    Sear87 YJ apologist
    KCMO
    2011 AC TRD-OR 6MT
    Ah, gotcha. In that case, this assembly might be one hole too far forward.
    Edit: yeah, as best as I can tell the front of the steering assembly on yours appears to be two holes from the end of that long dark grey beam instead of three:
    PennSilverTaco[OP] likes this.
  19. Nov 16, 2017 at 12:28 PM
    #5439
    PennSilverTaco
    Charlie
    Thanks!
  20. Nov 16, 2017 at 1:22 PM
    #5440
    Sear87
    Sear87 YJ apologist
    KCMO
    2011 AC TRD-OR 6MT
    You're welcome! Hopefully that solves it.
