PennSilverTaco's "Perfect 5-Lug Regular Cab" Build, Aspergers, and General BS MegaThread!
Discussion in '2nd Gen. Builds (2005-2015)' started by PennSilverTaco, Jul 15, 2014.
  1. Dec 5, 2022 at 5:35 PM
    Just_A_Guy
    Just_A_Guy Rain is a good thing
    On the hunt
    A truck
    First thought was warped rotors, but that’s ruled out by the occurrence when you are not braking.
    So something driveline related makes sense. Others pointed out U-joint, I’ll defer to them. I’m still learning about the intricacies of these trucks.
  2. Dec 5, 2022 at 5:54 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    See them up the road from us here too
  3. Dec 5, 2022 at 6:02 PM
    PennSilverTaco
    PennSilverTaco [OP] Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    The driveshaft also squeaks when going slow in reverse; I brought this noise to the attention of my mechanic, who found the source, and unfortunately can't do much about it as there's nothing mechanically wrong with the truck.
    wilcam47 likes this.
  4. Dec 5, 2022 at 6:05 PM
    wilcam47
    Will
    Bourbon state
    What was the source?
    TnShooter likes this.
  5. Dec 5, 2022 at 6:10 PM
    PennSilverTaco
    Charlie
    The driveshaft...
    wilcam47[QUOTED] likes this.
  6. Dec 5, 2022 at 6:13 PM
    wilcam47
    Will
    Bourbon state
    I mean why cant he do anything about it? If its squeaking the ujoints are bad
  7. Dec 5, 2022 at 6:17 PM
    PennSilverTaco
    Charlie
    He didn't seem to think they were bad? I've heard that it's not hard to remove the driveshaft, but how much involved would it be to replace the U-joints? Could this be causing the weird symptoms when the truck is decelerating?
    shakerhood and wilcam47[QUOTED] like this.
  8. Dec 5, 2022 at 6:20 PM
    wilcam47
    Will
    Bourbon state
    Its not a difficult job. It definitely could be.
  9. Dec 5, 2022 at 6:40 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I agree with @Just_A_Guy and @wilcam47
    Sounds like a possible U-joint issue.
    Your truck is a single cab. So it shouldn’t be all that hard to replace them.
  10. Dec 5, 2022 at 6:56 PM
    PennSilverTaco
    Charlie
    My mechanic is the type of guy who will put my truck on the lift to pinpoint the exact issue without charging me a cent. Is a bad or worn U-joint easy to find in this manner?
  11. Dec 5, 2022 at 6:58 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    There should be Zerk Fittings on the Driveshaft.
  12. Dec 5, 2022 at 6:59 PM
    PennSilverTaco
    Charlie
    Zerk?
    shakerhood[QUOTED] likes this.
  13. Dec 5, 2022 at 7:02 PM
    shakerhood
    Southern Ohio
    It's a fitting you use to grease.
  14. Dec 5, 2022 at 7:02 PM
    PennSilverTaco
    Charlie
    I got Scout the mini horse addicted to string cheese during my time working at the detail shop...
    :anonymous:
    shakerhood and wilcam47 like this.
  15. Dec 5, 2022 at 7:03 PM
    PennSilverTaco
    Charlie
    So grease rather than replace? Will I fuck something up if I wait too long to address this?
  16. Dec 5, 2022 at 7:05 PM
    shakerhood
    Southern Ohio
    You really should grease it every oil change or every other change, but once per year should be sufficient.
  17. Dec 5, 2022 at 7:11 PM
    TnShooter
    Deogee
    STOCK
    I don’t think the 5 lug 2WD trucks got zerks.
    They even phased them out on the later 2WD PreRunner trucks.
    I could be wrong, but I’m fairly certain the 5lug trucks are non-greasable
  18. Dec 5, 2022 at 7:16 PM
    shakerhood
    Southern Ohio
    Wow, had no idea the 2 wheel drives where different. l know they phased them out of the rear driveshaft of 4x4's in 2017.
  19. Dec 5, 2022 at 7:17 PM
    PennSilverTaco
    Charlie
    So just replace the U-joints? There's two?
  20. Dec 5, 2022 at 7:17 PM
    TnShooter
    Deogee
    STOCK
    Typically in my experience with u-joints.
    You’ll see some play at the joint.
    Sometimes you can hear them chirp when driving.
    Pete sounds like a good guy. I’d ask him what he thinks.
    I’d probably change mine if they were making noise, but I can grease mine, and can do mine myself.
    So I’m in a different situation.
