PennSilverTaco's "Perfect 5-Lug Regular Cab" Build, Aspergers, and General BS MegaThread!
Discussion in '2nd Gen. Builds (2005-2015)' started by PennSilverTaco, Jul 15, 2014.
  1. Apr 26, 2023 at 8:44 AM
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
    2"x6" is required for building code in my area.
  2. Apr 26, 2023 at 8:44 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    2x6 should make sturdier house.
    It also gives you a bit more of an insulation barrier. However, a well built 2x4 house will out perform a poorly built 2x6 house.
  3. Apr 26, 2023 at 8:48 AM
    PennSilverTaco
    PennSilverTaco [OP] Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    Because of weather conditions?
    shakerhood likes this.
  4. Apr 26, 2023 at 8:50 AM
    ColoradoTJ
    Colorado
    Yes
  5. Apr 26, 2023 at 8:55 AM
    PennSilverTaco
    Charlie
    I wouldn't be surprised if 2x6 is mandatory in places like Kansas and Oklahoma where tornados are prevalent. In Florida, central air-conditioners have to be bolted to the ground because of hurricanes, and it's probably the same for houses in Tornado Alley...
  6. Apr 26, 2023 at 9:02 AM
    ColoradoTJ
    Colorado
    My house wouldn't stand up to a tornado, but we do get very high winds at times (over 70 mph) and then there's the colder weather and what that brings.
    When building our rear patio, we had to overbuild it to withstand the weather.
  7. Apr 26, 2023 at 9:09 AM
    PennSilverTaco
    Charlie
    If your central A/C shits the bed before you sell the house, you should get a 4-ton 2-stage or variable-speed unit instead of another 3.5-ton unit. My grandma's old house had a 3.5-ton heat pump, and at my urging she decided to get a 2-stage heat pump with a variable-speed air handler. Since air-conditioners and heat pumps don't come in "half-ton" sizes (1.5, 2.5, 3.5), the contractor determined that upsizing to a 4-ton unit was the best way to go. There was a significant improvement in heating and cooling performance. Also, for some reason there is no such thing as a 4.5-ton unit; I have no idea why...
  8. Apr 26, 2023 at 9:15 AM
    ColoradoTJ
    Colorado
    We don't get the heat like some of the lower elevations. 85* is uncommon here. If it does take a dump, an upgrade will be had if this one is undersized.
  9. Apr 26, 2023 at 9:18 AM
    PennSilverTaco
    Charlie
    It's not that it's undersized, but a 2-stage would operate at half-capacity most of the time (2 nominal tons or 24,000 BTUs) and save you money. On those really hot days, it would operate at full capacity (4 nominal tons or 48,000 BTUs)...
  10. Apr 26, 2023 at 9:47 AM
    PennSilverTaco
    Charlie
    Is your house 2x6?
    Taco critter likes this.
  11. Apr 26, 2023 at 10:27 AM
    PennSilverTaco
    Charlie
  12. Apr 26, 2023 at 10:29 AM
    PennSilverTaco
    Charlie
    HisDad likes this.
  13. Apr 26, 2023 at 10:32 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    We had a F0 or F1 Tornado come thru here, when people say it sounds like a freight train they are not lying. It ended up knocking over the fire department and picking up the covered bridge!
  14. Apr 26, 2023 at 10:35 AM
    HisDad
    HisDad Well-Known Member
    Texas at last
    2019 Cement Tacoma SR5 Double Cab
    We had one come up through our neighborhood about 10 years ago. I wasn't home when it happened, but my wife was. She also said it sounded like a train. She went to the front door to see what was going on and almost did a Dorothy in the Wizard of Oz! Technically, she is a tornado survivor.
  15. Apr 26, 2023 at 10:36 AM
    HisDad
    Texas at last
    I like that style of ranch. If I were going to build, it would be that exact style.
  16. Apr 26, 2023 at 10:37 AM
    shakerhood
    Southern Ohio
    Glad she was ok, definitely a scary situation.
    PennSilverTaco[OP] likes this.
  17. Apr 26, 2023 at 10:38 AM
    PennSilverTaco
    Charlie
    @Just_A_Guy
    @RustyGreen
    @TnShooter
    I would turn the smaller bedroom into a larger master bathroom and a walk-in closet, and the kitchen is rather cramped, so I would probably replace the cooktop and wall oven with a range/oven that has the microwave above it. This plan is clearly from the 1960s or 1970s (possibly the 1980s), and the kitchen layout as originally planned porbbaly calls for a 30" range/oven with a 24" wall oven. If you look closely, you will see that instead of "cooktop" or "surface unit", it says "range"; I really do not like countertop microwaves if they can be avoided, and at a minimum I would prefer to have a cubby above the oven for a countertop microwave. My biggest complaint about this plan is that it would appear the washer and dryer are located in the basement...
    TnShooter and shakerhood like this.
  18. Apr 26, 2023 at 10:38 AM
    PennSilverTaco
    Charlie
    :amen::fistbump:
  19. Apr 26, 2023 at 10:43 AM
    Just_A_Guy
    Just_A_Guy Rain is a good thing
    On the hunt
    A truck
    Purchasing a townhome with an HOA sounds miserable.
    I think your Tacoma needs a west coast road trip. Let @ColoradoTJ do some off roading with it. See how far the little 5 lug can go.
  20. Apr 26, 2023 at 10:45 AM
    Just_A_Guy
    On the hunt
    A truck
    I think I technically live in one now. But as a renter, doesn’t really affect me. It is nice having someone do the landscaping.
