PennSilverTaco's "Perfect 5-Lug Regular Cab" Build, Aspergers, and General BS MegaThread!
Discussion in '2nd Gen. Builds (2005-2015)' started by PennSilverTaco, Jul 15, 2014.
  1. Jan 12, 2024 at 2:44 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    If those wheel cylinders froze up then the shoes wouldn't expand or contract.
    steelcity2 likes this.
  2. Jan 12, 2024 at 2:52 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    The ABS module didn’t cause the problem with the rear brakes.
    The only thing that expands in the rear brakes is the parking brake lever and the wheel cylinder.
    The parking brake lever doesn’t require the brakes to be bled. So that pretty much tells me the cylinders are bad. They normally leak and not seize up. But then again, I live in the south. We don’t have the rust issues you all have.
    Personally, I’d let Toyota do the module (not really) then have Pete do the rears. You’ll save a lot of money.
    The cylinders are just two 10mm bolts and a brake line disconnect/reconnect. Maybe 20 mins extra later per side. Be sure to try and get the Advics cylinders if you can. They are OEM supplier and good stuff.
  3. Jan 12, 2024 at 2:54 PM
    TnShooter
    Deogee
    STOCK
    They’d likely expand and not contract, wear the drums and shoes faster.
    But it rare to see them frozen up down here where I live.
    shakerhood[QUOTED] likes this.
  4. Jan 12, 2024 at 2:57 PM
    shakerhood
    Southern Ohio
    Usually l either see them leaking from the boots or with broken bleeder screws.
    TnShooter[QUOTED] likes this.
  5. Jan 12, 2024 at 2:59 PM
    TnShooter
    Deogee
    STOCK
    Me too.
    I never seen one seized that wasn’t driven daily.
    I seen them seized on vehicles that sat for years, like 5+ years.
    But never on one driven regularly.
  6. Jan 12, 2024 at 3:02 PM
    shakerhood
    Southern Ohio
    Same here, it seems odd that any daily driver would seize up.
    PennSilverTaco[OP] likes this.
  7. Jan 12, 2024 at 3:19 PM
    shakerhood
    Southern Ohio
    @PennSilverTaco Charlie you called your rear shoes "linings" it made me chuckle as l haven't heard that term in about 40 years. You used to actually take your old brake shoes to a specialist and they would replace the "lining", the process was called re-lining.
  8. Jan 12, 2024 at 5:26 PM
    PennSilverTaco
    PennSilverTaco [OP] Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    From what I was told, the rear brake shoes are fine (though they are getting replaced very soon), but what ever allows the brakes to actually operate is seized.
  9. Jan 12, 2024 at 5:50 PM
    TnShooter
    Deogee
    STOCK
    You could do the same with your clutch disc too.
    We've done it on a tractor. Much cheaper that way.
    But that was 20 years ago. China probably make a piece of shit disc much cheaper now.
    But I still wouldn't buy it.
  10. Jan 12, 2024 at 6:22 PM
    shakerhood
    Southern Ohio
    The wheel cylinder pushes the shoes apart and into the drum, it's sounding like they froze up somehow.
    TnShooter likes this.
  11. Jan 12, 2024 at 7:34 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    What tails do you want?
  12. Jan 12, 2024 at 10:24 PM
    PennSilverTaco
    Charlie
    :notsure:
  13. Jan 12, 2024 at 10:49 PM
    ABA180
    East Bridgewater MA
    What are you running now? And which one is busted?
  14. Jan 13, 2024 at 4:59 AM
    PennSilverTaco
    Charlie
    Don't remember what brand, and it's hardly busted (just cracked), but it's the right one; I have no idea how it happened.
    shakerhood likes this.
  15. Jan 13, 2024 at 2:37 PM
    ABA180
    East Bridgewater MA
    Was gonna say I have at least right OEM tail..might have a pair IDK
  16. Jan 14, 2024 at 6:07 PM
    PennSilverTaco
    Charlie
    Nikon pics of Philadelphia's City Hall from yesterday morning...
  17. Jan 14, 2024 at 6:08 PM
    PennSilverTaco
    Charlie
  18. Jan 14, 2024 at 6:08 PM
    PennSilverTaco
    Charlie
  19. Jan 14, 2024 at 6:09 PM
    PennSilverTaco
    Charlie
  20. Jan 14, 2024 at 6:09 PM
    PennSilverTaco
    Charlie
