PennSilverTaco's "Perfect 5-Lug Regular Cab" Build, Aspergers, and General BS MegaThread!
Discussion in '2nd Gen. Builds (2005-2015)' started by PennSilverTaco, Jul 15, 2014.
  1. Dec 27, 2017 at 1:32 PM
    #6721
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    RSCA = Rollover Side Curtain Airbags
    If you are doing some crazy driving off road, and don't want the air bags to pop out ($$$) if you slowly or almost roll over. Press and hold in the button until light comes on. Owners Manual item, just fyi.
    gunn_runner, jpereira2 and REDdawn6 like this.
  2. Dec 27, 2017 at 1:49 PM
    #6722
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    There’s many videos on YouTube.
  3. Dec 27, 2017 at 1:52 PM
    #6723
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    It’s like the easy button, when you press it, it makes life easier. Don’t press it too much though, if life gets too easy, well, its no bueno.
    PennSilverTaco[OP] likes this.
  4. Dec 27, 2017 at 2:05 PM
    #6724
    PennSilverTaco
    PennSilverTaco [OP] Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    Turns out my 5-lug Taco actually does have this feature! I've had the truck for 8 years (since new), and I never knew I could shut off the side curtain airbags!
  5. Dec 27, 2017 at 2:07 PM
    #6725
    TexasWhiteIce
    Texas
    That’s the cool thing about our trucks, even after years of ownership, we find features about them, I’ve had mine for 8 years now too and always find out random things about it. Like the other day I just finally noticed the TPMS reset button.
    Tacoguy015 likes this.
  6. Dec 27, 2017 at 2:14 PM
    #6726
    PennSilverTaco
    Charlie
    Can't tell you how many 2nd gen owners I've met who didn't know about the telescoping steering column...
  7. Dec 27, 2017 at 2:17 PM
    #6727
    Pigpen
    Dan
    Northwest Montana
    I was excited to find out about this one, after several years of ownership.
  8. Dec 27, 2017 at 2:21 PM
    #6728
    PennSilverTaco
    Charlie
    While at Raceway Park for the Spring 2015 swap meet, I met a vendor who owned a 2005 RC 5-lug (just like mine in terms of sock appearance but older) with only 55K miles on it! He had owned it since new, as in an entire decade, and didn't know about that feature until I showed him!
  9. Dec 27, 2017 at 2:37 PM
    #6729
    PennSilverTaco
    Charlie
    If there's anything all base model Tacoma owners (1st, 2nd, and 3rd Gen) can relate to, it's the fact that their trucks don't have a feature that we take for granted.
    I drive a 2010 RC 5-lug, which was a gift from my dad when it was brand new. I did not realize it lacked intermittent wipers until two days after we bought it!
    As most of us know, installing the intermittent control is quite easy.
    My dad bought me a brand new Toyota OEM switch from the dealer, as an early Christmas present, in December 2016.
    My truck was going into the body shop for some minor work, so my body guy installed the control for an extra $10. All I can say is that I wish I'd done it earlier!
    I've also heard of owners swapping in controls from Corollas and other Toyota vehicles. The swap is quite easy.
    What confounds me is that the last Tacomas with crank windows rolled off the assembly line in 2014 and backup cameras have been standard on all models since 2015, but even in 2018, brand new Tacomas lack the this feature!
    I've seen base 2nd gen V6 DCSB 4x4s that have steering wheel audio controls and cruise control from the factory, but only 2-speed wipers!
    My dad says Toyota knows they've got a great product and not adding intermittent wipers to the cheapest models is a way for them to save a lot of money.
  10. Dec 27, 2017 at 2:43 PM
    #6730
    kyledamon
    kyledamon Well-Known Member
    Colchester, VT
    2016 AC TRD OR
    I think your Dad is correct
  11. Dec 27, 2017 at 2:45 PM
    #6731
    Depoxy
    Depoxy Well-Known Member
    SoCal
    2010 Regular Cab 5-speed 4x4
    URD S/S, Eibach pro-truck @ 0.8" lift, hanook 265/75r16 AT
    I just popped out the plastic trim and popped the oem lights in. For power I bought a wiring harness from the place recommend in the ultimate headlight mod thread and wired it to a OTRATTW switch inside the cab
  12. Dec 27, 2017 at 2:52 PM
    #6732
    David K
    That's our Toyotas, they just keep giving and giving!
  13. Dec 27, 2017 at 3:02 PM
    #6733
    Mitch76
    Mitch76 Well-Known Member
    Mitch
    San Angelo, TX
    2021 F150 STX 4x4 5.0
    275/65-20 Cooper Discoverer XLT. Borla XR1.
    Wait...what? How do you operate it?
    Pigpen likes this.
  14. Dec 27, 2017 at 3:04 PM
    #6734
    Mitch76
    Mitch
    San Angelo, TX
    Right there in the middle on the bottom row.
  15. Dec 27, 2017 at 3:21 PM
    #6735
    PennSilverTaco
    Charlie
    Are you joking or do you seriously not know how to operate it? It's the same switch that operates the tilt function. Just push the wheel in and out, instead of up and down.
    Mitch76[QUOTED] likes this.
  16. Dec 27, 2017 at 3:24 PM
    #6736
    Mitch76
    Mitch
    San Angelo, TX
    Dead serious. I just went out in the freezing cold (35 here) and tried it. Shit Charlie, you taught me something! Thanks buddy!
  17. Dec 27, 2017 at 3:24 PM
    #6737
    PennSilverTaco
    Charlie
    My dad is very rarely ever wrong!
    Toyko Joe and kyledamon[QUOTED] like this.
  18. Dec 27, 2017 at 3:25 PM
    #6738
    PennSilverTaco
    Charlie
    :thumbsup:
  19. Dec 27, 2017 at 3:38 PM
    #6739
    PennSilverTaco
    Charlie
    What was that about 35 degrees being cold?
    This is the current temperature in the lovely little town where I work!
  20. Dec 27, 2017 at 3:59 PM
    #6740
    Depoxy
    SoCal
    The three blanks above fit Carling switches (OTRATTW) perfectly. Just requires minor filing so its not really reversible, but it looks almost stock
