PennSilverTaco's "Perfect 5-Lug Regular Cab" Build, Aspergers, and General BS MegaThread!
Discussion in '2nd Gen. Builds (2005-2015)' started by PennSilverTaco, Jul 15, 2014.
  1. Jan 1, 2018 at 3:41 PM
    #7001
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    And cold doesn't kill batteries...heat does.
    Jcyr likes this.
  2. Jan 1, 2018 at 3:42 PM
    #7002
    RogueTRD
    RogueTRD Learn to swim...
    Cade
    So. Oregon
    Supercharged '14 Pyrite Mica DCSB 4x4 TRD OR
    Stacked spacer lift, 22x12 wheels with stretched 33's, tow mirrors, bull nuts.
    Auto LSD, but same "diff". ;) :rofl:
  3. Jan 1, 2018 at 3:42 PM
    #7003
    PennSilverTaco
    PennSilverTaco [OP] Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    So, my truck still technically has an open rear?
    It actually does surprisingly good in the snow...
  4. Jan 1, 2018 at 3:45 PM
    #7004
    RogueTRD
    Cade
    So. Oregon
    Yeah, the auto LSD is still much better than an open diff, just works differently than a mechanical
  5. Jan 1, 2018 at 3:46 PM
    #7005
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    Akin to dragging the parking brake kinda?
    PennSilverTaco[OP] likes this.
  6. Jan 1, 2018 at 3:47 PM
    #7006
    RogueTRD
    Cade
    So. Oregon
    Kinda, lemme see if I can find the info on how it works.
  7. Jan 1, 2018 at 3:48 PM
    #7007
    RogueTRD
    Cade
    So. Oregon
    When the driver presses the Auto LSD switch, this system achieves the LSD effect by regulating the hydraulic pressure that acts on the drive wheels and controlling the engine output in accordance with the amount of pedal effort applied on the accelerator.
  8. Jan 1, 2018 at 3:49 PM
    #7008
    PennSilverTaco
    Charlie
    I'm probably better off leaving it stock then...
    JoefromPTC likes this.
  9. Jan 1, 2018 at 3:50 PM
    #7009
    hunter357mag
    hunter357mag Well-Known Member
    Bruce
    Minnesota
    2011 Black RC 4WD
    3" vertical ascension.....wheels.....tires......stuff
    People tell me I'd miss the change in seasons if I moved somewhere warmer. I'd be up for at least trying to string some Christmas lights on a palm tree!
    Back to the truck....I've used synthetic oil on my vehicles that could/should have it, including my taco. The manual recommends changing it every 5K and I do. I figure it's cheap insurance towards prolonging the motor.
    The battery I have I got from a local dealership-I got a coupon in the mail for an 84 month Toyota battery with decent cold weather stats for $119 installed. The last one I bought and put in myself(like that's rocket surgery)cost me over $100, so I thought I'd try the Toyota battery.
  10. Jan 1, 2018 at 3:50 PM
    #7010
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    True, but cold will decrease the amount of amps the battery can put through the starter. Also, batteries damaged by time and heat can freeze which is death for a battery. That's what happened to my OEM 5 years in.
    Also, AGM batteries have much higher outputs in terms of amperage available to the starter when you get into the bitter cold below the cold cranking amp test temperature.
    I found a JCI AGM battery for 169.99 CAD, which is only about $130 USD.
  11. Jan 1, 2018 at 3:52 PM
    #7011
    PennSilverTaco
    Charlie
    My original Toyota battery lasted from when we bought the truck in September 2009 until early 2015. My mechanic installed an Interstate Mega-Tron battery in early 2015. That's the battery I still have...
    hunter357mag[QUOTED] likes this.
  12. Jan 1, 2018 at 3:52 PM
    #7012
    RogueTRD
    Cade
    So. Oregon
    Probably, but then again... I don't agree with leaving vehicles stock. :D But yeah, you wouldn't get a huge change from just swapping in a mechanical LSD.
  13. Jan 1, 2018 at 3:53 PM
    #7013
    Sig45
    Mark
    Maine
    Don't disagree. That's why I get a new battery every 4 years. The cold will expose a weakened battery.
  14. Jan 1, 2018 at 3:53 PM
    #7014
    PennSilverTaco
    Charlie
    I meant leaving the rear diff stock. My truck is not exactly stock anymore, and I am slowly but surely building myself the ultimate daily driver 5-lug RC!
    Would putting a locker in make a difference?
  15. Jan 1, 2018 at 3:54 PM
    #7015
    Sterdog
    Sterdog Offline
    I am Groot
    15 FoST
    My bad if you thought I was arguing. I was more adding to your point and I should of worded it that way. :fistbump:
    Sig45[QUOTED] likes this.
  16. Jan 1, 2018 at 3:55 PM
    #7016
    Sig45
    Mark
    Maine
    I didn't.... :cheers:
  17. Jan 1, 2018 at 3:55 PM
    #7017
    RogueTRD
    Cade
    So. Oregon
    It would make a difference, but unless it was an air or electronic actuated locker, you wouldn't like driving it on the street as much. Mechanical lockers aren't super street/daily friendly.
  18. Jan 1, 2018 at 3:59 PM
    #7018
    PennSilverTaco
    Charlie
    Yeah, with regards to my current truck, I already have a reliable daily driver. It definitely has it's shortcomings when it comes to driving comfort, but it suits me just fine. At this point, I want to add functional stuff that wasn't available on RCs from the factory. Just check out my signature for what I've done to my truck so far.
    If I ever get my hands on a 4x4 Tacoma, I might replace the rear diff...
  19. Jan 1, 2018 at 4:01 PM
    #7019
    PennSilverTaco
    Charlie
    My friend has a 2017 Silverado LT Z71. The G80 locker is standard by default on all Z71 trucks. Do you think his truck has the downsides associated with a locking rear diff, like the noise when you make a turn?
  20. Jan 1, 2018 at 4:02 PM
    #7020
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    All I know, Cade is give me a ding when you want to sell your truck ;)
