PennSilverTaco's "Perfect 5-Lug Regular Cab" Build, Aspergers, and General BS MegaThread!
Discussion in '2nd Gen. Builds (2005-2015)' started by PennSilverTaco, Jul 15, 2014.
  1. Jan 5, 2018 at 7:24 AM
    #7281
    PennSilverTaco
    PennSilverTaco [OP] Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
  2. Jan 5, 2018 at 9:51 AM
    #7282
    PennSilverTaco
    Charlie
    She did surprisingly good in the snow!
    ChadsPride likes this.
  3. Jan 5, 2018 at 10:19 AM
    #7283
    PennSilverTaco
    Charlie
    Jesus!
    Doylestown Borough?!?!
    Feels more like North Slope Borough, in Alaska!
  4. Jan 5, 2018 at 10:39 AM
    #7284
    PennSilverTaco
    Charlie
    HomerTaco likes this.
  5. Jan 5, 2018 at 10:47 AM
    #7285
    PennSilverTaco
    Charlie
    These pictures, along with the closeup pics of my ToyWerx grille, were taken after I parked in my usual spot at work today...
  6. Jan 5, 2018 at 10:59 AM
    #7286
    PennSilverTaco
    Charlie
    And don't even get me started on how cold it's gonna be at my friend's parents' place in the Poconos!
    Currently...
    We are leaving at 6pm-6:30pm, and should get there by about 7:30-8pm
    The keyword there is should...
    We will probably arrive closer to 9pm...
    Tomorrow morning, roughly the time we are going to the indoor water park...
  7. Jan 5, 2018 at 3:02 PM
    #7287
    PennSilverTaco
    Charlie
    More pics taken at work today, right before I went home for the evening...
    uurx likes this.
  8. Jan 5, 2018 at 4:52 PM
    #7288
    iamroddy
    iamroddy Well-Known Member
    I had a 4.0 V6 5 speed ranger. Short box, reg. cab. It had 3.73s and a t-lock (LSD)...good working truck. That wouldn't be a bad swap for a driver...same platform, and lots of available parts/donor trucks around. Regardless of the chosen engine, a rear end upgrade will be needed. Any Ranger that came with a 4.0 will also have an 8.8 rear diff. Most of the 4X4s had 3.73 or 4.10 gears and many came with LSD. It should be a straight bolt in upgrade to replace the 7.5" rear end in there now.
    That said...as much as I like the ford 5.0 pushrod V8 engine, it wouldn't be my first choice for a "hot rod" Ranger...too common. A 2.3 EcoBoost (like in the Mustang) might make for an interesting option. I believe Ford offers it as a stand-alone kit, but I'm not sure how much $$ that would be.
  9. Jan 5, 2018 at 4:54 PM
    #7289
    CedarPark
    CedarPark Master of Destroying CVs
    Dylan
    Cedar Park, TX
    '04 TRD V6 Taco, '11 2WD 5.7 Tundy
    Lights & Lockers & Duals
    I'll give ya $100 for it and you can be the first to see the video :thumbsup:
  10. Jan 5, 2018 at 4:57 PM
    #7290
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    leave it in the bad part of town unlocked with the keys in the ignition
    T4RFTMFW likes this.
  11. Jan 5, 2018 at 5:00 PM
    #7291
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    With an Unlimited Budget I'd replace it whit a Tacoma.
  12. Jan 5, 2018 at 9:25 PM
    #7292
    PennSilverTaco
    Charlie
    In the Poconos!
    And it is COLD!
  13. Jan 6, 2018 at 5:24 AM
    #7293
    ralfnjan
    ralfnjan Well-Known Member
    How goes it in the snow with those "all summer radials" Charlie? Winter tires for me from November to April. Softer rubber, good grip on the ice, and an aggressive tread. 4wd helps too.
    Ralhp
  14. Jan 6, 2018 at 5:45 AM
    #7294
    PennSilverTaco
    Charlie
    It actually does good...
  15. Jan 6, 2018 at 6:12 AM
    #7295
    PennSilverTaco
    Charlie
    Up in the Poconos at my friend's parents' house for the 29th birthday of that friend and a friend who has the same exact birthdate...
    Current temperature is like one degree and it feels like -18!
    Started the Tacoma to see how it would do, and it struggled a tiny bit. Discovered that the washer fluid lines are frozen. I popped the hood and discovered not only a thin layer of slush on the washer fluid, but that my coolant is kind of low and the coolant in the reservoir seems to be low!
    The truck ran fine for the drive up to the Poconos and the temperature gauge was not reading abnormally.
    The truck also started just fine and the temperate gauge most certainly did not rise quicker than usual. The heater is also working just fine (Isn't the heater core tied to the radiator, and uses the coolant as part of the heating process?)
  16. Jan 6, 2018 at 6:14 AM
    #7296
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Coolant doesn't appear to be frozen.
  17. Jan 6, 2018 at 6:15 AM
    #7297
    PennSilverTaco
    Charlie
    Up in the Poconos!
    My bed is not very comfortable, but I slept well enough...
  18. Jan 6, 2018 at 6:16 AM
    #7298
    PennSilverTaco
    Charlie
    When I tapped the reservoir, the coolant didn't slosh...
    Also, does the cold have anything to do with why it's so low?
  19. Jan 6, 2018 at 6:18 AM
    #7299
    Sig45
    Mark
    Maine
    It's between the lines, so technically it's within operating specs. Was that pic taken when cold or warmed up? Do you see any visible leaks?
  20. Jan 6, 2018 at 6:18 AM
    #7300
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    None of the pictures suggest your coolant is frozen. I think it has to be around -30 for that stuff to freeze.
