PennSilverTaco's "Perfect 5-Lug Regular Cab" Build, Aspergers, and General BS MegaThread!
Discussion in '2nd Gen. Builds (2005-2015)' started by PennSilverTaco, Jul 15, 2014.
  1. Jan 1, 2017 at 5:41 PM
    #1161
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Not a lot of window stickers on 2 year old used cars.
    PennSilverTaco[OP] likes this.
  2. Jan 1, 2017 at 7:53 PM
    #1162
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    I was surprised even the Grand Cherokee is available in 4x2.
  3. Jan 1, 2017 at 8:00 PM
    #1163
    PennSilverTaco
    PennSilverTaco [OP] Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    When the Wrangler was redesigned for the 2007 model year, the 4-door Unlimited was available in 2WD. They are VERY rare.
  4. Jan 1, 2017 at 8:05 PM
    #1164
    koditten
    Kirk
    Central Michigan
    I'm not a jeep person at all, but it just seems wrong to offer Jeep vehicles in 2 wheel drive models.
  5. Jan 1, 2017 at 8:33 PM
    #1165
    MurderedTacoV2
    MurderedTacoV2 Booty Admirer
    Adam
    Hudson, New Hampshire
    06 Taco TRD OR
    3 inch lift, B110’s, Dakars, Dirty5’s, Dual Locked
    Can relate, its like you rip the thing up.....then realize it only telescopes a solid inch and a half and moves up maybe 2 inches. :(
  6. Jan 1, 2017 at 8:55 PM
    #1166
    03f5sp
    03f5sp Well-Known Member
    Bill
    Wisconsin
    2011 TRD Off Road dcsb
    Front 5100s @ 2.5, 1.5 AAL, 265/75-16 all terrains
    I'm pretty sure my 2011 TRD has tilt but no telescoping.
  7. Jan 1, 2017 at 8:56 PM
    #1167
    KenLyns
    Belly of the Beast
    Push forward ;) It's there but not useful unless you have abnormally long arms.
  8. Jan 1, 2017 at 8:59 PM
    #1168
    PennSilverTaco
    Charlie
    Go out and check...
  9. Jan 1, 2017 at 9:57 PM
    #1169
    03f5sp
    Bill
    Wisconsin
    We'll ain't that something... I must've pulled it out when I first got the truck and forgot about it.
  10. Jan 2, 2017 at 12:02 PM
    #1170
    Jumbafri
    Jumbafri Well-Known Member
    So short answer is yes but only as long as you have enough of the wire harnesses from each seat to splice them together. You are basically using the Bucket seat ECU and splicing that back into the Bench seat harness and then supplying power to the bucket seat module.
    What you will need to do is have the plug and harness section from the Bench seats that runs directly into the body harness, and cut the side that plugs into the Bench seat ECU
    Then take the harness from the Bucket seats, keep the side that plugs into the ecu, but cut off the part that would plug into the body harness.
    You will jump the wires that directly match and then supply power to the pin 3 B+ terminal at the new bucket seat module. note that there will be 2 full white wires, one for DLC and one for FSR+ once you determine which is which, you will be fine.
    Pin numbers listed first are from the bucket seat ECU the bucket ecu has two connectors and the bench seat ecu only has one.
    Bucket seat ecu you want splice the connector that has 8 wires
    Pin 2 White at the bucket seat module to white pin 10 at the bench seat module Both Labeled as DLC (Data link Connector)
    Pin 7 Beige at the bucket seat module to Beige pin 9 at the bench seat module Both labeled as IGN (ignition switched power)
    Pin 3 White/blk at the bucket seat module to White/blk pin 5 at the bench seat module both labeled as ground,
    Pin 8 White at the bucket seat module to white pin number 11 at the bench seat module both labeled as FSR+
    Pin 4 Black at the bucket seat module to Black pin number 12 at the bench seat module Both Labeled as FSR-
    Pin 5 P/G (i think it was pink with a green stripe) at the bucket seat module to P/G pin number 14 at the bench seat module both labeled as BGND for the front seat belt buckle sensor
    Pin 9 G (i think it was green) at the bucket seat Module to G pin number 13 at the bench seat module both labeled as BSW for the front seat belt sensor
    Now here is the kicker, You will need to supply Battery 12v power to pin #3 The red wire on the bucket seat airbag module. this is the key step since the bucket seat module does not get power from the battery this wire will not be existing in the body harness and you will need to run this separately from the battery to the seat module. I used a fuse piggyback to add a circuit off of the 12V power outlet circuit. always choose a circuit with a higher protection fuse than what you plan to wire in.
    This circuit needs to be protected at 7.5A!
    I have done this swap directly on a 2012 reg cab, using the seats from a 2012 extended cab without any issues and got the airbag lights off without any drilling and without any seatbelt mods.
    You can leave the rest of the wires from the bench seat harness cut and taped off. And this should utilize all or most of the wires from the bench seat module though
    I know this is a little confusing without the OE wiring diagrams i have in front of me but ill try to explain and help anyone who needs assistance. Feel free to PM me
  11. Jan 2, 2017 at 2:11 PM
    #1171
    Pigpen
    Dan
    Northwest Montana
    I've been reading OP's posts mostly for the replies lately. koditten came through strong on this little gem!
    We have a prolific thread starter on our hand, boys...
  12. Jan 5, 2017 at 6:43 AM
    #1172
    PennSilverTaco
    Charlie
    In September 2014, my parents traded a 2008 Acura TL for used 2013 Nissan Murano SV AWD. My mom primarily drives it.
    It was purchased at Fred Beans Nissan with 11,500 miles on the odometer. My parents paid cash, so they have always owned the Murano outright; This is probably for the best considering that the sneaky change in Carfax took a chunk out of the vehicle's resale value. There was absolutely nothing wrong with the Murano and all records were clean, including the CARFAX. The Murano has not been involved in any accident since we purchased it, and there no evidence that it has been involved in one. In 2015, I did hit a bird that flew out of the bushes by the side of the road and presumably killed it, but the Murano did not sustain any damage.
    So, imagine my shock when about 2 years after my parents bought the Murano, I typed the license plate number into CARFAX and got a report that it had been involved in an accident with airbag deployment.
    Even weirder was that this accident was reported about 2 weeks AFTER my parents bought the Murano. Like I said, the Murano has never been involved in accident; never even been backed into anything.
    I have a number of theories here, but what do you guys think? Has anyone else ever had an accident that they weren't involved in pop up on their vehicle's CARFAX?
  13. Jan 5, 2017 at 6:45 AM
    #1173
    nh_yota
    nh_yota Well-Known Member
    Jeff
    Portsmouth, NH
    2010 DC V6 TRD-OR 6-SPD
    2" Lift with HS coils/AAL and 5100s, TRD Exhaust, TRD Skid Plate, URD Short Shift, AT3s
    Somebody may have fat fingered the VIN when they reported the accident. I'd call Carfax and complain.
  14. Jan 5, 2017 at 6:46 AM
    #1174
    PennSilverTaco
    Charlie
    That was my first theory. Somewhere in Pennsylvania, there's a similar 2013 Murano that has a clean record because someone typed in the wrong VIN.
  15. Jan 5, 2017 at 6:46 AM
    #1175
    98tacoma27
    Ben
    Not Beech Creek
    The accident may not have been entered into the system until after it was sold...which is shady in itself.
    RedRed and theredofshaw like this.
  16. Jan 5, 2017 at 6:46 AM
    #1176
    ETXTacoma
    ETXTacoma Someone gave me a plasma cutter.
    Steven
    Tyler, Texas
    2014 DCSB Tacoma TRD OR
    Send me the VIN and I will run an actual Autocheck for you instead of the Carfax to double check.
    RedRed likes this.
  17. Jan 5, 2017 at 6:46 AM
    #1177
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
    did you mean vin?
  18. Jan 5, 2017 at 6:47 AM
    #1178
    PennSilverTaco
    Charlie
    Yeah. The Acura was also involved in an accident in 2012 that was not my dad's fault. A RAV4 made an illegal left turn and did $5,000 in damage. Acura was fixed and accident shows up on Acura's CARFAX.
  19. Jan 5, 2017 at 6:47 AM
    #1179
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
    The Murano was involved in an accident before your parents bought it, and was reported to Carfax late.
    theredofshaw and 98tacoma27 like this.
  20. Jan 5, 2017 at 6:47 AM
    #1180
    PennSilverTaco
    Charlie
    Well, license plate number first, then VIN. You can do both...
