PennSilverTaco's "Perfect 5-Lug Regular Cab" Build, Aspergers, and General BS MegaThread!
Discussion in '2nd Gen. Builds (2005-2015)' started by PennSilverTaco, Jul 15, 2014.
  1. Jan 7, 2017 at 4:41 PM
    #1221
    shabbs
    shabbs Well-Known Member
    Mark
    Toronto, Canada
    2014 Tacoma 4x4 V6 DCLB TRD Sport
    Skid plate - added 2014/10/23, Bed extender - added 2014/10/25, Tonneau Cover - added 2014/10/31, OEM Bed Mat - added 2014/11/12, AM/FM/CB AntennaX - added 2014/11/16, Smittybilt 27046B Beaver Step for 2" Hitch - added 2015/01/22, Trimax SXT3 Premium 5/8" Key Receiver Lock - added 2015/01/22, 2 x Grip 30' x 4" Heavy Duty Tow Straps - added 2015/01/23
    I switched to fully synthetic on my first oil change... and still change it every 5k.
    So... I'd say yes. Do it.
    rmepilot, willee51 and Taco Addiction like this.
  2. Jan 7, 2017 at 4:43 PM
    #1222
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    you're smart.. absolutely synthetic is better and always change it by at least 5k. the maint req light on our tacos is set to illuminate temporarily at 4,500 miles and go solid at 5,000 miles. not only does the syn oil resist burning/leaking past piston rings but it doesn't generate ash/soot (sludge). our engine have timing chains now with a very sophisticated variable valve timing system. good quality oil is essential for the proper life span of chains, guides, vvt-i spool valves, solenoids, etc. i also buy oem filters in bulk (worldpac or imc). my weapon of choice is a full synthetic by a company called MOTUL (i think it's french). we do a lot of MB, bmw, vw/audi and the motul is rated for all those engines
    Taco Addiction likes this.
  3. Jan 7, 2017 at 4:48 PM
    #1223
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    long life oil is a scam. i don't want metal particles circulating in my engine for 10,000 miles! after the engine gets over 100k it's going to start burning a little oil (normal) and people don't check the level because they got the extended life stuff. next thing you know the red oil can warning is coming on (or the check engine light w/ variable valve timing codes) and they're wondering what the heck is going on
  4. Jan 7, 2017 at 4:55 PM
    #1224
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    Yes, full synthetics are proven to protect better. I use either Mobil 1 or Pennzoil Platinum switching it up each time because different brands use different detergents and (to me) it keeps your engine cleaner. Also change it every 5K
    1Shifter likes this.
  5. Jan 7, 2017 at 4:56 PM
    #1225
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    I don't think it makes that much difference if you change your oil on a 5k basis. I do use syn oil in machines I don't change the oil on a regular schedule e.g., the snow blower.
    jsi likes this.
  6. Jan 7, 2017 at 4:57 PM
    #1226
    shr133
    shr133 Well-Known Member
    Muskego, WI
    2010 V6 Sport
    K & N filter, 275 70 17 Cooper AT3, OME Nitrocharger shocks, 884 Springs, Dakar leafs.
    Either way.
    But use a good quality oil.
    I run full synthetic oil, trans and gear oil.
    A good blend is a good way to go also.
    Full synthetic withstands heat better and is better for performance.
    A good blend has better cooling and lubrication.
    I change my oil every 3000-4000 in the cold north...
  7. Jan 7, 2017 at 5:06 PM
    #1227
    MTBFLOW
    MTBFLOW Well-Known Member
    Go Mobile 1 full synthetic, buy from Walmart in the 5QT container, then take it to the dealer to have it changed and ask for the container back... they shouldent charge you more than $15 for the labor and filter.
    rmepilot likes this.
  8. Jan 7, 2017 at 5:52 PM
    #1228
    1Shifter
    1Shifter Well-Known Member
    Jeff
    Outta the black and into the blue
    09 PreRunner
    Same as everybody else...
    This is Exactly what I use....I normally alternate between M1 HM and Penzoil Platinum HM with an oddball Quaker State UD. I always change between 4k and 5k with an OEM filter.At about 32 bucks a shot and about 30 minutes of my time it's cheap insurance. OP...I'd say full synthetic every 5k and let her roll.
    mach1man001[QUOTED] and MTBFLOW like this.
  9. Jan 7, 2017 at 6:02 PM
    #1229
    MTBFLOW
    Why Penzoil Platinum out of curiosity? Specific detergents?
  10. Jan 7, 2017 at 6:13 PM
    #1230
    reefnfeef
    reefnfeef Well-Known Member
    Bridger, MT
    '14 Pyrite Mica DCLB TRD Sport
    Don't mean to hijack, but I've been wondering about synthetic gear oil. I am approaching 30k and want to change both diffs, and transfer case oils. The threads I've found on here are based on the LSD that wasn't based on brakes (I have a 2014), and so they used LS additive. Can I use mobil 1 75w-90 LS on my 2014? or do I need to find a synthetic that has zero LS additives?
  11. Jan 7, 2017 at 6:34 PM
    #1231
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    i don't think the additive would hurt your open diff. i use a standard 75w-90 (GL5) gear oil..
    reefnfeef[QUOTED] likes this.
  12. Jan 7, 2017 at 6:44 PM
    #1232
    o0oSHADOWo0o
    o0oSHADOWo0o Just lurking in the darkness
    Shadow
    Va Beach
    2012 Double Cab Short Bed 4x4 TRD Sport
    Just a few LEDs...
    Maticuno, Sugar Silva and b_r_o like this.
  13. Jan 7, 2017 at 6:47 PM
    #1233
    1Shifter
    Jeff
    09 PreRunner
    Just a personal preference. Everything I've read is that PP stacks up well when compared to M1. I can usually get it at the local WW for a few bucks cheaper. I don't notice any huge difference between the two, no significant knocking or anything like that.
    mach1man001 and MTBFLOW[QUOTED] like this.
  14. Jan 7, 2017 at 7:01 PM
    #1234
    14TACO4X4
    14TACO4X4 Mmmmm... Beer
    Shawn
    Temecula
    18 RAM EcoDiesel
    Laramie
    I have a 2014 as well. Changed my front, rear, and transfer case at 25k to Mobil 1 75w-90 gear oil. That'll work fine, no additive needed.
  15. Jan 7, 2017 at 9:42 PM
    #1235
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Yes, synthetic is better. My Corolla uses or leaks a lot more when I use synthetic in it so I've switched back to conventional. This is not conjecture, I've verified it more than once. It usually takes a couple of cycles of conventional oil to get it back to not losing oil. It has about 263,000 miles on it though.
    My Taco, Sienna mini van (wife's) and old T-100 all hold synthetic just fine.
    From what Eric The Car Guys says, Penzoil Platinum is derived from natural gas, so the polymer chain lengths are more consistent. With that said, Mobil 1 full synthetic is excellent oil in my opinion. I even use it on my guns.
  16. Jan 7, 2017 at 9:45 PM
    #1236
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    Changing your oil way before it needs it is a complete waste of money. There's absolutely nothing wrong with going over 3-5k IF your driving conditions permit it.
    And always use full synthetic.
    You can check your oil with the dipstick. Not trying to be condescending haha but you can tell if it's dirty with a rag or paper towel pretty quick and save yourself a whole buttload of money.
    PennSilverTaco[OP] likes this.
  17. Jan 7, 2017 at 9:47 PM
    #1237
    Sep1911
    Sep1911 Well-Known Member
    2016 Taco
    if you've maintained the car you shouldnt really have any sludge issues but I think the snythetic will help clean up what little there may be. The cleaner the engine the better as your seals wont dry out. Also you get better cold start flow.
  18. Jan 7, 2017 at 9:50 PM
    #1238
    winkel
    Corydon, IN
    My Corolla is 'easy' on oil. Even after 5,000 miles, I can easily see the dipstick through the oil. I use this as a bit of an indicator.
  19. Jan 7, 2017 at 10:04 PM
    #1239
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
  20. Jan 8, 2017 at 12:00 AM
    #1240
    BuzzardsGottaEat
    Some Toyotas
    Round tires
    I do a ton of interstate driving in good weather and have gone anywhere from 7500 to almost 10k between oil changes in my little 1.5 L Honda Fit. Kind of nice to go 30k miles in a year and a half and only have three or four oil changes haha.
