PennSilverTaco's "Perfect 5-Lug Regular Cab" Build, Aspergers, and General BS MegaThread!
Discussion in '2nd Gen. Builds (2005-2015)' started by PennSilverTaco, Jul 15, 2014.
  1. Apr 13, 2018 at 9:09 PM
    PennSilverTaco
    PennSilverTaco [OP] Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    Gr8fl and Running Board Man like this.
  2. Apr 13, 2018 at 9:10 PM
    PennSilverTaco
    Charlie
  3. Apr 14, 2018 at 8:36 AM
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    My opinion vastly differs from you
  4. Apr 14, 2018 at 4:04 PM
    PennSilverTaco
    Charlie
    It's because kids use starting fluid to get high would be my guess...
    Total bullshit!
  5. Apr 14, 2018 at 4:15 PM
    PennSilverTaco
    Charlie
    I've had this issue before, and the first time it happened (June 2017), I ended up needing a recharge. My '10 RC 5-lug had about 75K miles on the clock at that time and I'd never had any problems with the A/C before.
    I realized something was wrong when I noticed that the two left vents were blowing ice cold, but the middle right vent was blowing only cool, and the far right vent was cranking out humid outside air...
    I took it to my dad's mechanic and he did a full test of the system (I saw him do this). Subsequent testing revealed that the system was in fact a bit low on R134a, but no leaks.
    My guess is that 8 years of freeze/thaw cycles as a result of Pennsylvania winters caused the rubber fitting to shrink and expand, releasing refrigerant in small quantities over the years.
    Today, my girlfriend and I went on a date to a car show in Jersey, and we noticed that the A/C was blowing ice cubes from the three of the four vents. The far right vent fluctuated from kinda cool to lukewarm, while the other three cranked out ice cold air.
    It was in the low 80s in my area today, but it's going right back into the 40s tomorrow so I'm gonna bother with it until it gets warm for good...
    What do people think is wrong?
  6. Apr 14, 2018 at 4:18 PM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    Shoot some dye in it and find the leak. I’ve seen evaporator cores leak in tacomas and 4runners before. Have the mechanic put some dye in it after he recharges it. Also an electronic freon sniffer is a good tool.
    Jeffs68 and PennSilverTaco[OP] like this.
  7. Apr 14, 2018 at 4:27 PM
    PennSilverTaco
    Charlie
    Is the evaporator core the one that requires the dashboard to be removed?
  8. Apr 14, 2018 at 4:46 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    Most a/c system leaks are caused buy the Schrader valve caps.
    PennSilverTaco[OP] likes this.
  9. Apr 14, 2018 at 4:47 PM
    PennSilverTaco
    Charlie
    High or low side caps though?
  10. Apr 14, 2018 at 4:48 PM
    desertrunner24
    Jake
    Fresno , CA
    Some
    I usually see it on the high side, but have seen a few from the low side
  11. Apr 14, 2018 at 4:49 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Yes and that's where mine has always leaked too :/
  12. Apr 14, 2018 at 5:01 PM
    Bebop
    Nick
    Dashboard has to come out.
  13. Apr 14, 2018 at 5:19 PM
    PennSilverTaco
    Charlie
    How much?
  14. Apr 14, 2018 at 5:20 PM
    PennSilverTaco
    Charlie
    Worth it to fix?
  15. Apr 14, 2018 at 5:31 PM
    Speedytech7
    With how much you're losing game very that much time maybe not. Really easy to take apart a 1st gen gen dash, yours is likely not as easy.
  16. Apr 14, 2018 at 5:34 PM
    PennSilverTaco
    Charlie
    But it's almost $170 to recharge it every year...
    That's how much it cost last June!
  17. Apr 14, 2018 at 6:23 PM
    PennSilverTaco
    Charlie
    And long to repair once they get the part?
  18. Apr 14, 2018 at 6:24 PM
    PennSilverTaco
    Charlie
    That made little sense...
  19. Apr 14, 2018 at 6:26 PM
    Speedytech7
    Sorry I'm in the middle of installing my supercharger and didn't read what autocorrect fucked up. I meant for how much you're losing it may not be worth the cost of labor
  20. Apr 14, 2018 at 6:33 PM
    PennSilverTaco
    Charlie
    I have every intention of driving my Tacoma until it dies completely (which by my calculations probably won't be for another 420K miles if I were to drive it that long ...
    I'm thinking I'm gonna have it charged and have my mechanic put dye in the refrigerant.
    Speedytech7[QUOTED] likes this.
