PennSilverTaco's "Perfect 5-Lug Regular Cab" Build, Aspergers, and General BS MegaThread!
Discussion in '2nd Gen. Builds (2005-2015)' started by PennSilverTaco, Jul 15, 2014.
  1. May 10, 2018 at 7:23 PM
    PennSilverTaco
    PennSilverTaco [OP] Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    @Gr8fl
    Did you see the floorplan? What do you think of that house?!?!
  2. May 10, 2018 at 7:24 PM
    El Duderino
    El Duderino Obviously, you're not a golfer.
    Jeremy
    HI->PNW
    19 nautical blue SR5 premium 4x4
    Stuff, things, this, an ADS
    Like the house looks like a good flowing lay out
    PennSilverTaco[OP] likes this.
  3. May 10, 2018 at 7:35 PM
    PennSilverTaco
    Charlie
    I'm looking at it from an HVAC fanatic's point-of-view, too...
    In theory, heating and cooling (especially heating, with that massive wall of windows in the front) a one-story home should be easy, but it is over 3,400 square feet. In this area (Southeast Pennsylvania), that's going to require two A/C units. Actually, you probably could get away with a zoned 5-ton/60,000 BTU unit in this specific house, but I do not believe in cutting corners when it comes to HVAC. There appears to be attic space above both the bedroom area and the dining room, which would be prime space for air handlers. For heat, I would go with a huge gas-fired boiler, located in the basement and set up with three individually-controlled zones. Since the A/C ducts would exclusively be in the ceiling, this would pose a bit of a problem with getting A/C into the basement. However, I'd probably just go with a ductless mini-split or two for the finished basement area...
  4. May 10, 2018 at 7:37 PM
    El Duderino
    Jeremy
    HI->PNW
    I just wouldn’t want my master bedroom on the same side of the house as the other rooms
  5. May 10, 2018 at 7:38 PM
    PennSilverTaco
    Charlie
    In this case I wouldn't care that much...
    I love ranch houses!
    El Duderino[QUOTED] likes this.
  6. May 10, 2018 at 7:45 PM
    PennSilverTaco
    Charlie
  7. May 10, 2018 at 7:47 PM
    El Duderino
    Jeremy
    HI->PNW
    No clue what any of this HVAC stuff is. I don’t have AC or heat in my house lol
  8. May 10, 2018 at 7:49 PM
    PennSilverTaco
    Charlie
    It's top-of-the-line shit!
    Also, I'd want the kids' rooms to be close to me when they were younger, and when I looking for my first house, location of the master bedroom relative to all other bedrooms would not be a top priority...
  9. May 10, 2018 at 7:50 PM
    PennSilverTaco
    Charlie
    Yeah, but it has pretty much all the modern features you'd want in a new house today; master suite with full master bath and his and hers walk-in closets, three guest bedrooms, full basement, separate living room and dining room, and not one but two fireplaces!
  10. May 11, 2018 at 2:45 AM
    Gr8fl
    Gr8fl Some rise, some fall, some climb.
    JK
    Central Bucks, PA
    17 Cement Pro, 20 MGM Land Cruiser
    Looks like a big house, really nice setup.
  11. May 11, 2018 at 3:36 AM
    booted
    booted Well-Known Member
    Cambridge, MD
    I was thinking it looked a little like Brady Bunch.
  12. May 11, 2018 at 2:26 PM
    PennSilverTaco
    Charlie
    A "foster parent" for Wags Rescue brought this adorable little girl to the bar where I work! She was rescued from a high-kill shelter in South Carolina, along with her brother!
  13. May 11, 2018 at 2:38 PM
    PennSilverTaco
    Charlie
  14. May 11, 2018 at 4:09 PM
    PennSilverTaco
    Charlie
    Meet Maverick, 4-legged customer at work!
    gulzeb likes this.
  15. May 11, 2018 at 4:11 PM
    PennSilverTaco
    Charlie
    And here's a puppy named Fred!
    My shift has literally gone to the dogs!
    El Duderino and gulzeb like this.
  16. May 11, 2018 at 4:14 PM
    PennSilverTaco
    Charlie
    Someone parked their 2018 Wrangler in the valet lot at work this evening! I do believe that this is the first 2018 Wrangler I've seen outside of the Philly auto show or a dealer's lot!
    gulzeb likes this.
  17. May 11, 2018 at 7:59 PM
    TRVLR500
    TRVLR500 Well-Known Member
    Wyoming
    Tacoma SR5 4X4 2.7 4CYL
    I'm WAY late to respond to you're post but you're right.
  18. May 11, 2018 at 8:13 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Tanks are plastic but the tubes and fins are aluminum. Whatever you do, don't put a higher pressure than stock cap on it. It will cause both the radiator and heater core plastic parts to fail prematurely.
  19. May 11, 2018 at 8:14 PM
    PennSilverTaco
    Charlie
    I guess that begs the second question...
    Would the A/C have to be removed in order for the radiator to be removed?
  20. May 11, 2018 at 8:16 PM
    TRVLR500
    Wyoming
    I wouldn't ever do that. I'm OEM all the way these days. I have no intentions of "hopping up" my Tacoma. They last as long as they do because of Toyota engineering. Suspension is the only thing I ever changed. For reasons we all know of.
