PennSilverTaco's "Perfect 5-Lug Regular Cab" Build, Aspergers, and General BS MegaThread!
Discussion in '2nd Gen. Builds (2005-2015)' started by PennSilverTaco, Jul 15, 2014.
  1. Nov 29, 2018 at 1:28 PM
    PennSilverTaco
    PennSilverTaco [OP] Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    So that's a yes?
  2. Nov 29, 2018 at 1:30 PM
    Matmo215
    Matmo215 Well-Known Member
    Matthew
    Waco, TX
    2015 Sport DCSB
    Yes. Larger tire sizes require less revolutions to go the same distance. Speedometer/odometer measure the revolutions of the tire, so when you increase the circumference you are actually gong farther/faster than before.
  3. Nov 29, 2018 at 1:42 PM
    PennSilverTaco
    Charlie
    Thanks for the info! Looks like my truck actually has somewhere in the range of 95,000-96,000 miles, even thought the odometer is presently showing 90,139 miles.
  4. Nov 29, 2018 at 1:46 PM
    Fitz235
    Fitz235 Well-Known Member
    Rob
    New Hampshire
    Black '22 DCSB TRD Offroad 4WD
    - TRD T4R Pro Wheels - TRD Lift Kit - TRD Skid Plate - 265/70/17 Toyo Open Country 3's - OEM Bed Lights - OEM Bed mat - Alpharex Tail Lights - TacomaBeast LED Interior Lights - Green Lane Offroad Aluminum Sliders - Place Holder for More Bad Financial Decisions...
    Are there any tears in the fabric of space/time on your commute?
  5. Nov 29, 2018 at 1:51 PM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    Only if you SOMETIMES run stock size tire and other times run a larger tire?
    I kid
    Extra stops for food/gas/groceries?
    You sure your not starting out at xxxxxx.8 miles?
    That may account for your miniscule extra mileage?
    Same route to and from each time?
    1 mile is nothing
  6. Nov 29, 2018 at 1:56 PM
    JL8Jeff
    JL8Jeff Well-Known Member
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
    OME 885/nitros, SPC UCA, 305/65/17, AAL
    It may depend on each individual truck. I think the factory original setup is off a little since so many people go with taller tires. I have 305/65/17 tires which are close to 33" tall and just about every speed trap I hit, my speedometer is pretty much dead on with the speed trap display. I don't know if the previous owner had anything done to correct it (if that's even possible with the stock Toyota computer). So I would guess you are off a little, but maybe not as much as the calculator shows.
    timbobzimbob likes this.
  7. Nov 29, 2018 at 1:58 PM
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    Your speedo will be off if bigger tires
    If you go up 5 sizes let's say than your speedo will read 60 but your going 66ish
    Other way around is smaller. My buddy had 13 inch Daytons (dont ask me why) his speedo would read 80 and we were running 65ish
  8. Nov 29, 2018 at 1:59 PM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    my truck with 1 size up is dead nutz on. It was wrong stock.
  9. Nov 29, 2018 at 2:16 PM
    PennSilverTaco
    Charlie
    Maybe my truck is more accurate with the 16-inchers? For example, when I pass a sign on the turnpike saying an exit is a mile away, my truck has one more mile on it when I get to the exit...
  10. Nov 29, 2018 at 2:19 PM
    ridefreak
    ridefreak Well-Known Member
    NM
    2006 DCSB TRD
    minor tweaks
    It's caused by the Black Hole at the corner of Main and Spruce St.
    Ted Steel likes this.
  11. Nov 29, 2018 at 2:19 PM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    Yes. check it against that and try a GPS on it also.
    You could always break out a tape measure or maybe fit bit?
    GPS is pretty accurate. So is a cop with radar.
  12. Nov 29, 2018 at 2:20 PM
    motodude95
    motodude95 Well-Known Member
    Jim
    2012 MGM TRD Sport DCLB, OME 886s, 33s
    Sometimes I shit twice in one day
    Ted Steel and bzzr2 like this.
  13. Nov 29, 2018 at 2:33 PM
    bzzr2
    bzzr2 Well-Known Member
    I am taking poo number two of today as I type this
  14. Nov 29, 2018 at 2:57 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    What do you use to power your Tacoma to the required 1.21 gigawatts? Plutonium or garbage? I once saw a 3 part documentary that demonstrated the difference. They also tried a steam powered train as well.
    Maticuno and outlawtacoma like this.
  15. Nov 29, 2018 at 3:36 PM
    inwood customs
    Dave
    Ok, tire sizes effect mph/miles driven yes.
    As tires wear they will also change the mileage driven/read to a small extent
    But your saying your drives equal 10miles sometimes and 11 miles other times. That is not because of you having larger tires unless like I said earlier, you flip flop tire sizes multiple times a week.
    If your tire size remains constant, then look for other variables as I posted earlier.
    A 12" ruler is always a 12" ruler.... A 32" tire is always a 32" tire within tread depth wear variables (do the math if u want, but sounds like a pita for such a trivial question).
  16. Nov 29, 2018 at 3:41 PM
    hyper15125
    hyper15125 Headlight Retrofitting Hobbyist Vendor
    NJ (609)
    :rofl:
  17. Nov 29, 2018 at 4:12 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    When you leave your house the milage in your head (or google maps) starts from 0 but that doesn't mean the odo starts from "zero". the odometer may already be halfway or 3/4 through the next mile when you get in to leave. Next time you leave your house watch the odo for the first time it steps up. If it takes a few minutes to step to the next mile it may appear be 10 total for the trip. If you leave the house and it steps up quickly, like backing down the driveway, then you'll likely see a 11 mile trip. Make sense?
    Fords have odometers that read the 10ths of a mile in between miles (like xxx,xxx.00) Put the odo on trip and leave it there for a week, you'll see what I mean
  18. Nov 29, 2018 at 4:46 PM
    Nate-O
    Nate-O Well-Known Member
    Nate
    PreRunner
    Did you install one of these...o_O
  19. Nov 29, 2018 at 4:47 PM
    Ted Steel
    Ted Steel Well-Known Member
    Ted
    NC
    2018 Cav Blue Pro 6MT, 2014 Baja (sold)
    LOL!!!
    Fitz235[QUOTED] likes this.
  20. Nov 29, 2018 at 4:48 PM
    El Duderino
    El Duderino Obviously, you're not a golfer.
    Jeremy
    HI->PNW
    19 nautical blue SR5 premium 4x4
    Stuff, things, this, an ADS
    Take 3 shits before noon lol. As I’m typing on the throne right now.
    motodude95[QUOTED] likes this.
