PennSilverTaco's "Perfect 5-Lug Regular Cab" Build, Aspergers, and General BS MegaThread!
Discussion in '2nd Gen. Builds (2005-2015)' started by PennSilverTaco, Jul 15, 2014.
  1. Dec 22, 2018 at 9:04 AM
    PennSilverTaco
    PennSilverTaco [OP] Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
  2. Dec 22, 2018 at 9:37 AM
    PennSilverTaco
    Charlie
    What parts do I need besides the obvious?
  3. Dec 22, 2018 at 9:52 AM
    BigEasy
    BigEasy Well-Known Member
    Rob
    PNW
    2020 Tacoma TRD/OR DCLB
    Nada
    The use of alcohol and other drugs changes the body in fundamental ways, hence it being characterized as a disease, but it it also acknowledged that it is within the behavioral health realm, and is therefore a "bio-psycho-social" disorder. There are ALMOST ALWAYS some underlying antecedent to use of substances in a pathological way. Coping, masking pain, etc. Unless the individual impaired by the substances addresses the concept of change from multiple perspectives, simply ceasing use rarely results in permanent change...
  4. Dec 22, 2018 at 12:54 PM
    RhodeIsland4bang
    RhodeIsland4bang Back seats are for freeloaders!
    Rhode Island, USA
    2011 DCSB SR5 6MT
    Count of one four legged freeloader
    I got approved
    Tacolvr79 and george101 like this.
  5. Dec 23, 2018 at 7:58 AM
    PennSilverTaco
    Charlie
    Does my truck have overdrive?
    b_r_o likes this.
  6. Dec 23, 2018 at 8:02 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Yes, all cars have some kind of OD, even manuals
    On a manual it refers to the higher gears like 5th (4th is probably the 1 to 1 gear on a truck like yours)
    On an automatic transmission OD refers to the taller gears, but it also means that the torque converter has the ability to lock completely
    PennSilverTaco[OP] likes this.
  7. Dec 23, 2018 at 8:04 AM
    xterra9171
    xterra9171 Well-Known Member
    Logan
    2011 super white tx pro
    Stock for. Ow
    Typically whatever your last gear is your over drive gear.
  8. Dec 23, 2018 at 8:10 AM
    Skyway
    Skyway Well-Known Member
    Ande'
    St.Pete
    White 2009 regular cab
    Sliding the gear shift down to D.
    Then slide it left is Overdrive Off.
    Basically making the 4 speed transmission a 3 speed transmission.
    I use OD Off while towing my boat.
    Approx. 1000 lb's with the trailer.
  9. Dec 23, 2018 at 8:19 AM
    Dens71TA
    Dens71TA Well-Known Member
    2014 SR5 ACLB 4x4 2.7L A4
    Majority of the non-overdrive transmission installations began to end in the late 80's and early 90's. Chrysler held onto their 3-speed non-OD automatics way longer than they should have. You could still get bare bones Chrysler trucks and minivans without OD in the early 2000's.
  10. Dec 23, 2018 at 8:32 AM
    PennSilverTaco
    Charlie
    My cousin has a 1998 Honda Civic hatchback, 4-speed auto, no overdrive...
  11. Dec 23, 2018 at 8:36 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Pretty sure on any auto if it has D (with a little box around it) instead of a number its got OD
  12. Dec 23, 2018 at 8:39 AM
    Flatout110
    Flatout110 Well-Known Member
    Tony
    Long Island, NY
    2019 Tacoma
    Engine oil By-pass filtration system. B&M transmission cooler Rustproofed
    I would check on that, as all 4 speed automatic transmissions that I know of, 4th gear is overdrive.
  13. Dec 23, 2018 at 8:41 AM
    Dens71TA
    '98 Civic with the auto should have a 0.60 overdrive 4th gear.
  14. Dec 23, 2018 at 8:44 AM
    Bishop84
    Bishop84 Well-Known Member
    D3 is od off, D4 is od on.
    The last non-OD trans that I know of is K Car's 3 speed trans and some Chevy trucks had 4 speed manuals. Both 1980s long gone.
  15. Dec 23, 2018 at 8:45 AM
    Flatout110
    Tony
    Long Island, NY
    2019 Tacoma
    That’s a wonderful thing !!
  16. Dec 25, 2018 at 2:24 PM
    ALI3N_123
    ALI3N_123 ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Eric
    Austin, Texas
    2021 Silver TuRD Squirt DCSB 4x4 // 2008 Black Rusty Shitbox DCSB PreRunner
    You have the wires?
  17. Dec 25, 2018 at 2:58 PM
    PennSilverTaco
    Charlie
    I honestly have no idea...
    ALI3N_123[QUOTED] likes this.
  18. Dec 25, 2018 at 4:00 PM
    ALI3N_123
    Eric
    Austin, Texas
    I saw a thread in which the guy had everything, just didn’t have a place to connect it. He listed everything needed with part numbers, I can’t seem to find it though.
  19. Dec 25, 2018 at 4:02 PM
    ALI3N_123
    Eric
    Austin, Texas
    My moms first RAV4 was this exact trim in MGM, and 2WD. Does it have the power seat save buttons on the door?
  20. Dec 25, 2018 at 5:36 PM
    PennSilverTaco
    Charlie
    Don't remember...? It was last week...
