PennSilverTaco's "Perfect 5-Lug Regular Cab" Build, Aspergers, and General BS MegaThread!
Discussion in '2nd Gen. Builds (2005-2015)' started by PennSilverTaco, Jul 15, 2014.
  1. May 1, 2019 at 10:09 PM
    PennSilverTaco
    PennSilverTaco [OP] Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    I would replace everything between the transmission and the spare tire...
  2. May 1, 2019 at 10:10 PM
    mynewtoy
    mynewtoy I like men
    greg
    Mississippi
    09 double cab 4x4
    Detriot locker rear ARB air locker front 4.56 gears OME 3" lift, SPC uca's , moto metal 951 wheels 315/75/r16 Treadwright guard dogs, homemade front plate bumper with smittybilt 9.5k winch, homemade skids, homemade Bed bars, Mobtown offroad high clearance rear bumper with tire carrier, Homemade rock sliders , U-bolt flip, Wheeler's super bumps, BORA 1" wheel spacers , Black headlight mod , black tail lights, Satoshi Grill , autoPage C3 RS-665 alarm with remote start, flowmaster 40 series exhaust, cruise control,bed/ground effect lights, wet okole seat covers, tinted,windows, weather tech floor mats, AVS vent shades, debadged, hidden cobra 19 cb, 7" offroad lights behind grill, rear diff breather relocate, abs kill switch
    hell you should be able to pick up a stock 3rd member from someone installing a locker most of them or 3.73 geared
  3. May 1, 2019 at 10:11 PM
    PennSilverTaco
    Charlie
    I don't even think they have true posi rear ends anymore...
    It's all lockers and limited-slip rear ends...
    If you punch "positraction" into Wikipedia, the article you get is entitled "Limited-Slip Differential".
    Did Toyota pickups EVER even have posi rear ends?
  4. May 1, 2019 at 10:24 PM
    jboudreaux1965
    jboudreaux1965 Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    But you want 5 lugs right? That's means 5-lug shafts.
    Your easiest option to keep 5 lug is just put a Truetrac in it or something.
    Your best option over all is just switch to 6 lug axle.
    I'm In the process of putting together a new axle for my truck at the moment. The housing I'm using came with an 8.4" TRD mechanical LSD 3rd member with 3.73's. when I'm done it will be for sale if interested.
  5. May 1, 2019 at 10:27 PM
    PennSilverTaco
    Charlie
    At the same time, my truck does fine in deep snow with chains on, plus I just got new Cooper Discoverer AT/3s...
  6. May 1, 2019 at 10:29 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Just get a different truck. Nothing on the 5lugger drive train is compatible or interchangeable. Even if you swap out the entire rear drive train and re-weld spring perches and shock mounts etc. you can’t do tire rotations and need 2 spares
    PennSilverTaco[OP] likes this.
  7. May 1, 2019 at 10:30 PM
    PennSilverTaco
    Charlie
    In that case, I'm definitely keeping this one...
    There's someone on the Tundra forum who has both a 5-lug 2011 Taco and a newer fully loaded Tundy! :drool:
  8. May 1, 2019 at 10:30 PM
    TireFire
    Olympic Peninsula
    Tundra axle!! It’s got 5 lugs yo!
  9. May 1, 2019 at 10:31 PM
    PennSilverTaco
    Charlie
    That's one thing I don't get...
    Why does the full-size Toyota pickup have a 5-lug setup?!?!
  10. May 1, 2019 at 10:32 PM
    PennSilverTaco
    Charlie
    @HomerTaco
    Sometimes people take a look at my front end and think my truck doesn't have a grille!
    HomerTaco and Taco critter like this.
  11. May 1, 2019 at 10:32 PM
    TireFire
    Olympic Peninsula
    Haha I was joking! It’s 5 lugs alright but the wheel hubs and studs are wayyy beefier
  12. May 1, 2019 at 10:35 PM
    PennSilverTaco
    Charlie
    And 4-wheel disc brakes...
    Someone on TW told me that it would be possible to convert my truck to 4-wheel disc, but there wouldn't be much point because I wouldn't see much of an improvement in braking performance...
    All Frontiers have had 4-wheel disc brakes since 2005! My uncle's base model 2011 Ford Ranger 2WD 4-banger, that doesn't even have tilt steering, has 4-wheel disc brakes!
    Even some shitty compact cars have 4-wheel disc brakes! What gives?!?!
  13. May 1, 2019 at 10:35 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    The axle is wider on a tundra
  14. May 1, 2019 at 10:36 PM
    PennSilverTaco
    Charlie
    And in Pennsylvania, not only will your vehicle fail inspection if the wheels extend past the fenders, but police can pull you over for it even if you have a valid inspection sticker!
  15. May 1, 2019 at 10:37 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    And smaller wheels. Axle ratio is one component of many that determine how a truck drives. 6-luggers have bigger wheels and higher ratios stock and guys go up on both from there.
  16. May 1, 2019 at 10:37 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    That sucks!
  17. May 1, 2019 at 10:37 PM
    TireFire
    Olympic Peninsula
    Perfect! 3.5 LT kit in front to match
  18. May 1, 2019 at 10:38 PM
    PennSilverTaco
    Charlie
    Also, my dad did not want a Yukon with the towing package and upgraded suspension. All Yukons come standard with a 3.08 rear. My dad test drove a Yukon with the 3.08 and said it felt underpowered. He's glad I talked him into getting the 3.42 ratio!
  19. May 1, 2019 at 10:42 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    Since I'm having to swap axles I was actually on the fence about doing tundra swap, but benefit vs cost wasn't there. Just going get me a used taco axle and ordered 3rd from ECGS, startin' over
  20. May 1, 2019 at 10:42 PM
    PennSilverTaco
    Charlie
    They're absolute nazis! Your vehicle will fail inspection in Pennsylvania if, among other things:
    • The foglights can be turned on concurrently with the high-beams.
    • Your check engine light is on.
    • Your window tint is too dark.
    • Your wheels extend past your fenders.
    • The PRNDL on your gear selector won't light up.
    • The mechanic doing the inspection is a dick and/or decides he simply doesn't like you.
