Pennsylvania
Discussion in 'North East' started by Toy4Life, Jun 20, 2008.
  1. Apr 23, 2019 at 5:40 PM
    Redmann
    Redmann DILLIGAF
    Reds
    Philly
    2009 AC TRDOR
    Just goes to show the caliber of people/trucks we have out here
    skatefreak282 and Taco critter like this.
  2. Apr 23, 2019 at 5:42 PM
    TinyTech626
    TinyTech626 reverses st. signs & steals everyone's left shoe
    Liz
    Bucks Co, PA
    05 TRD AmoCat
    Stuff. Things.
    Ok, back to the college thing. I'll see all you tacos in 5 days!
  3. Apr 23, 2019 at 6:48 PM
    HomerTaco
    HomerTaco TOYWERX Vendor
    Craig
    Bucks County Pa.
    four sticks, dual cases, zero fucks...
    100% not stock... Core-Hurst short throw shifter & T-handle / Carbon Fiber Interior / custom console light / De-badged / leather interior / Heated Front seats / Red Line Hood Struts / Painted speaker grills /one-off TRD Satoshi Grill with 12-15 front-end swap/ Pioneer AVIC-X920BT HU / Scangauge II / Black LED Tails / Dash Mount for iPad mini / Safari Snorkel / Auto-pilot mode / Leer 100XQ Cap / 4x Innovations sliders / Rear Diff Breather Mod / front windows tinted to 35% / Brute Force Fab Hybrid Front Bumper / BAMF Rear Diff Skid / Budbuilt Skids / CBI Trail Master 2.0 rear hybrid bumper / Fox rr coils/ TC UCA's/ TC spindle gussets/ TC Cam Tab gussets / Dakar leafs / Defined Engineering shackles / All pro U bolt flip / Timbren Rear Bumpstops / BAMF LCA skids / Exhaust re-route / Fog Light anytime Mod / LowRange Off Road extended rear brake lines / ATO Shackle Flip / sectioned Bushwhacker flares / re-geared to 4.56 / ARB Front & Rear Locking Diff / ARB CKMA12 compressor / PrInSu full rack system / 1" body lift / Inchworm 4.7 crawlbox / twin stick FJ t-case / Davez off-road triple-stick kit/
    WANT.
    :facepalm: I can add lights when we template it silly... :rolleyes:
    For Gods sake... Don't buy one. I have my 48" Highlift just collecting dust in my shed. I have a 60" Reese one now becausr the 48" is too short.
    Yours for a 6-pack of Troegs my dear. ;)
    skatefreak282 likes this.
  4. Apr 23, 2019 at 6:49 PM
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB
    Some Stuff
    So I got one of my ABS wires pinched in a zip tie while putting my truck back together.
    When I started it up, I immediately had an ABS light.
    The speedometer worked for precisely 5.3 miles. I know this because I set trip A to track mileage for the diff break in.
    Then, no speedo, no odometer, P0500 code, and many lights.
    I can clear the P0500 code and some of the lights go out. But the code just comes back. Never have a speedo.
    So, from what I’ve seen, this could be caused by any of the wheel speed sensors. Any of the ABS wires, the gauge cluster, the ABS fuses under the hood, or the computer itself.
    I’ve already changed the harness that I stretched.
    Does anyone know how to begin to diagnose this without just swapping parts?
  5. Apr 23, 2019 at 7:04 PM
    WBF610
    WBF610 Member well known
    Carey
    Lehigh Valley, PA
    2016 DC OR
    mats, flaps, and stickers. Extang solid fold 2.0. Mobtown sliders and full skids. AVS vents
  6. Apr 23, 2019 at 7:06 PM
    TinyTech626
    Liz
    Bucks Co, PA
    05 TRD AmoCat
    Stuff. Things.
    REall.....DONE!!!
    Any particular flavor of Troegs.. I know you like that elf one don't you?
  7. Apr 23, 2019 at 7:11 PM
    HomerTaco
    Craig
    Bucks County Pa.
    Yes but mad Elf is out of season now.
    Tröegenator will do just fine.
    TinyTech626 likes this.
  8. Apr 23, 2019 at 7:17 PM
    loosnut
    loosnut Well-Known Member
    jerry
    feasterville pa
    06 dbl cab long bed
    ome 2.5lift leer cap
    You need a scanner that gives live feed info. You can then watch each wheel speed sensor and see which one is not reading right.
  9. Apr 23, 2019 at 7:19 PM
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB
    Some Stuff
    Thank you Jerry. Can you recommend a decent scanner that’s not ridiculously expensive?
  10. Apr 23, 2019 at 7:21 PM
    EatSleepTacos
    EatSleepTacos East Coast Conner
    Randy
    Chesapeake, VA
    4x4 2005 SR5 AC 6MT
    Try reading all the quotes in this link, and see if that helps any. There's some good info in it.
    https://www.tacomaworld.com/threads/subway4x3-shameless-copycat-build.459570/page-52#post-16614390
    HolyHandGrenade likes this.
  11. Apr 23, 2019 at 7:23 PM
    Redmann
    Redmann DILLIGAF
    Reds
    Philly
    2009 AC TRDOR
    I bought one from Ebay. I'll see if I can find it in my history.
  12. Apr 23, 2019 at 7:24 PM
    loosnut
    jerry
    feasterville pa
    06 dbl cab long bed
    I got nothing on that one the one I use at my night gig is pricey.
    HomerTaco and HolyHandGrenade like this.
  13. Apr 23, 2019 at 7:30 PM
    Redmann
    Redmann DILLIGAF
    Reds
    Philly
    2009 AC TRDOR
  14. Apr 23, 2019 at 7:31 PM
    HomerTaco
    Craig
    Bucks County Pa.
    Works though. That’s how we diagnosed my evap canister issue. My scangauge only read P0000 but that one you had spit out like 5 other code numbers that totally narrowed down the issue.
    Easy solution. $260 later. :rolleyes:
  15. Apr 23, 2019 at 7:34 PM
    HolyHandGrenade
    Tim
    Garage Most Likely
    DCFB
    Some Stuff
    Awesome. I bookmarked that. I’ll screw with it tomorrow. Thank you.
    Sweet. Thanks man.
    Redmann and EatSleepTacos like this.
  16. Apr 23, 2019 at 7:50 PM
    Cooktop86
    Cooktop86 Well-Known Member
    Jeff
    Hatfield, Pa
    2017 Tacoma TRD sport MGM
    Remember we looked at them they are to big for the grill the lights you sell will fit better. ;)
  17. Apr 23, 2019 at 7:53 PM
    Mugsy7
    Mugsy7 Well-Known Member
    Mugsy
    Delco, PA
    2016 TRD OR DCSB Black
    Whoa...Whoa. WHOA! It's Delco.
    stbear and Delcosfinest like this.
  18. Apr 23, 2019 at 8:34 PM
    Redmann
    Redmann DILLIGAF
    Reds
    Philly
    2009 AC TRDOR
    :facepalm::facepalm::facepalm:
    Also... I'm sure you and everyone else in Delco would rather not lay claim to Upper Darby :rofl:
    Cooktop86, skatefreak282 and Mugsy7 like this.
  19. Apr 24, 2019 at 3:13 AM
    Taco critter
    Taco critter Mall crawler proud , patw and ,ttc#0247
    Pottstown /stowe , pa
    02 tacoma 4x4 full mall crawler
    Leveling kit ,rims ,cold air intake ,hard bed cover ,4 crawler drings, 4 crawler body lift ,cb in ashtray mod,leds, jet maf,Satoshi grille,led roof bar,yakama roof basket ,smittybilt parts,spare tire mount in hitch ,rago fabrication parts,many more to come
    Morning all have a great day
  20. Apr 24, 2019 at 3:34 AM
    lynyrd3
    lynyrd3 Strength ,Determination ,Merciless,Forever
    Bill
    Capital District,New York ,Columbia County
    2008 SR5 AC SUPER WHITE V6 4x4 AT
    Bilstein 6112s at top setting ,1/4" top plate spacer driver side,Total Chaos UCAs ,SS extended brake lines ,Old Man Emu Medium Duty Dakar leaf springs,OME carrier bearing drop shim Bilstein 5125s for 2-3” of lift in rear ,Timbren SES bump stops , SS extended brake lines rear , Toytec dif drop , Hayden high performance transmission fluid cooler,aFe pro dry air filter , ,Powerstop drilled and slotted rotors.N-Fab light bar with 4 Hella OR lights , Devil horns by Andres ,Weathertecs floor protector, American Racing wheels Baja 17x8,4.5 BS , 285/70 Falken Wildpeaks AT/3W .Body Armor rear bumper . Extra D rings in bed ,Blue sea fuse block and 100amp breaker ,G-Tek Fab door sill protectors ,HomerTaco grill Painted pinch weld.Shorty antenna ,HVAC knob mod ,LED dome and map lights , Tri Fold bed cover ,UltraGauge ,Morimoto XB LED fog lights ,Energy Suspension poly body bushings and sway bar bushings ! Geartech Customs splash guards ,Salex center console organizer . Mobtown tailgate cap Mobtown weld on sliders with kick out ,0* , black wrinkle powder coated ! ,NEW frame courtesy of Toyota !
    Morning John :hattip: Gave you my vote !
    Taco critter likes this.
